Write-Up: Torque APP OBD2 Reader
Discussion in 'Performance and Tuning' started by BrokenTusk, Oct 20, 2011.
  1. Oct 6, 2014 at 1:06 PM
    #481
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    I think there's an option to account for different tire size in the vehicle setup.
  2. Oct 7, 2014 at 11:46 AM
    #482
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Do you use the 'Enhanced MPG calculation' option?
  3. Oct 11, 2014 at 6:05 PM
    #483
    replica9000
    2019 T4R ORP
    Figured out how to get the Roll and Pitch meters into a digital format.
  4. Oct 11, 2014 at 6:49 PM
    #484
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    I tried to replicate your display and couldn't get anywhere near that setup. Almost like the display was different dimensions or something.
    I also need to find a way to get a MAP sensor that's bluetooth so I can display boost on the same screen. Someone needs to make one of those. That would be super sweet! Plumb it, wire it to 12v and then pair it. Easiest boost gauges install ever! Well, other than on cars that already have MAP like my Optima.
  5. Oct 11, 2014 at 6:55 PM
    #485
    replica9000
    2019 T4R ORP
    I changed the DPI to 160 to cram more stuff on a smaller screen. It's only a 3.7" 480x800 screen.
  6. Oct 11, 2014 at 7:12 PM
    #486
    Ostrichsak
    Jer
    Ah, that makes more sense. My SGS4 has pretty high resolution so I figured I should be able to get the same gauges on mine. Nope.
  7. Oct 13, 2014 at 8:56 AM
    #487
    Pete0247
    Pete0247 Well-Known Member
    Kentucky
    2007 BSP DCSB TRD Off Road
    5000K headlights, 3000K fogs, fog mod, 2014 LED tail lights with LED reverse lights, interior LED dome/map, and license plate lights, Pioneer radio, WeatherTech window visors, 20% tint, bed door locks, Mobil 1 synthetic fluids throughout
    Sub.
    I purchased my Tacoma about 2 months ago, just got a OBDII reader the other day, and purchased the Torque Pro app, very cool stuff, haven't had much time yet to get a good setup yet, but some good ideas in this thread.
  8. Oct 13, 2014 at 9:33 AM
    #488
    replica9000
    2019 T4R ORP
    I don't have a supercharger (yet), but the vacuum gauge works on my truck, but I can't test for boost.
  9. Oct 13, 2014 at 9:35 AM
    #489
    Ostrichsak
    Jer
    There is no MAP sensor from the factory and the app just reads whatever is available at the OBDII port so there's no way to add MAP sensor.
  10. Oct 13, 2014 at 9:49 AM
    #490
    replica9000
    2019 T4R ORP
    Is boost/vacuum not the same sensor?
  11. Oct 13, 2014 at 9:59 AM
    #491
    Ostrichsak
    Jer
    Whatever 'vacuum' you're seeing isn't actual vacuum that the ECU/OBDII is seeing because there is no manifold pressure sensor or MAP. That's why there is no boost read by the ECU because there is no sensor for it so if there is no sensor there can be no readings available for the app to display.
  12. Oct 13, 2014 at 10:29 AM
    #492
    replica9000
    2019 T4R ORP
    Yeah looks like it's reading -12 psi when it should be reading around -18 at idle. My last car, which had an actual boost/vac gauge, read about -18psi as well. I wonder where it's getting it's data from....
  13. Oct 13, 2014 at 11:06 AM
    #493
    replica9000
    2019 T4R ORP
    Is your SGS4 rooted? If so, you could use an xposed module to manually change the DPI for Torque with affecting the rest of the phone.
  14. Oct 13, 2014 at 11:17 AM
    #494
    Ostrichsak
    Jer
    Yeah it's rooted but not that important to me really. If I could get the sensors I wanted to display it would be more valuable but no boost makes it a novelty more than anything to me.
  15. Oct 13, 2014 at 11:18 AM
    #495
    Aw9d
    Aw9d That one guy
    I've tested with it on and off and I don't seem to notice any difference. I leave it on.
  16. Oct 13, 2014 at 11:23 AM
    #496
    replica9000
    2019 T4R ORP
    Without it, it's a lot more generous on the MPGs I'm getting. No way I'm getting 20mpgs city after heavy 33's.
  17. Oct 13, 2014 at 11:49 AM
    #497
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I need to set mine up again.. :eek: used to use it regularly, but replaced my phone since then.. and lost all the settings, displays, etc. need to dive deeper into the settings as well. would love an accurate MPG reading..
  18. Oct 13, 2014 at 11:55 AM
    #498
    replica9000
    2019 T4R ORP
    I've compared Torque with the enhanced calculation to what I logged with Fuelly. It's pretty close. Once in a while Torque seems to revert the MPG dial to the last reading before disconnect though.
  19. Oct 14, 2014 at 2:37 PM
    #499
    Pete0247
    Kentucky
    Anyone have oil temperature working? Did you use custom PID?
    Share some pictures of your setup
  20. Nov 8, 2014 at 1:49 PM
    #500
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Can anyone tell me what I should change the obd speed multiplier to for larger diameter tires as it says, to help with correcting the Speedo in torque? Running 33 12.5 15's. I messed with the GPS and ecu difference, but it was screwy. Seemed way off. Plus when I came to a stop, GPS was saying I was still moving, and it was at the same difference it was showing while driving. (?)
    Think I may need to change the mpg trim too but still tweaking everything. Also trying to figure out how much my truck weighs.. I guesstimated it is about 5600. Door sticker says 5100. With heavier tires and wheels, extra misc weight in truck like lights, me, gas, small gear in cubbies.. Sound about right? I think I might go to a weigh station just for the heck of it. I'm curious now. Plus I'm not sure how much it affects torque. Would be nice to have it spot on though.
