Write-Up: Torque APP OBD2 Reader
Discussion in 'Performance and Tuning' started by BrokenTusk, Oct 20, 2011.
  1. Apr 22, 2015 at 3:46 PM
    #581
    Aw9d
    Aw9d That one guy
    I take mine out if I won't be driving the truck for 3 or 4 weeks. Other than that I left it in for 2 years without issues.
  2. Apr 22, 2015 at 9:11 PM
    #582
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    It took 3 weeks for my obd2 Bluetooth adapter to drain the battery enough to not be able to start my truck.
  3. Apr 22, 2015 at 9:23 PM
    #583
    skygear
    skygear                    
    Left mine in too. Never had an issue with it. Went longer than that without a startup. But I have the larger single battery in at the time. Then the dual setup.
  4. Jun 10, 2015 at 5:32 PM
    #584
    dnl_tacoma
    dnl_tacoma Lead the Way
    Daniel
    Stover, MO
    2013 Tacoma TRD OR 6M/T Supercharged
    Supercharged 3° retarded exhaust cam gears, URD Short Shifter, Custom Pin Shift Knob from T.W. Member (Coupe) Pop&Lock, Total Chaos Bed Stiffeners, Full Bedrug, Toytec 2.5 Boss w/resi Durobump Stops, EMP Shield Meso V2 Dome and Map & TopperEZLift Morimoto XB & 4bangers Warfab front rear & bumper Smitty x20 gen 3 10k winch
    Brand New excuse my ignorance. I bought the BAFX Bluetooth OBD2 reader and the Torque Pro App. I am trying to use it on my 2013 Tacoma Access Cab V6 Off Road. All stock as well. I really want to use it for the Instant and Average MPG, Fuel levels/ Fuel remaining until empty. I went through all 30 pages and could not for the life of me see or understand what I need to do to get accurate readings for MPG ( the reading just kept raising during the whole test drive even tho i was going uphill, speeding up, stopped at and Idle) and fuel remaining. I was also wondering how to change the Speedometer from KMH to MPH, or just in general how to switch everything to what ever measurements we use here in the United States.
  5. Jun 10, 2015 at 6:09 PM
    #585
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Go to Setting > Units, and check the measurement we use.
    I use the option "Enhanced MPG Calculation" under the "OBD2 Adapter Settings" section. Our trucks don't have a fuel level sensor, so fuel range is only going to be an estimated calculation, and you'll probably have to manually tell it every time you fill the tank.
    dnl_tacoma likes this.
  6. Jun 19, 2015 at 7:09 AM
    #586
    Boosh63
    Boosh63 Well-Known Member
    Timmins, ON
    2013 Black Tacoma Limited
    Yep...the main reason I got mine was to monitor fuel economy too....oh well.
  7. Jun 19, 2015 at 9:51 AM
    #587
    replica9000
    2019 T4R ORP
    You can still do fuel economy, but for stuff like fuel range, you'll have to tell Torque the size of the tank, weight of the truck, etc, and reset the gauge every time you fill up. It will try to guess the range.
  8. Jun 19, 2015 at 12:49 PM
    #588
    Boosh63
    Timmins, ON
    Meh....the absence of a fuel level sensor makes much of what I want to do a bit cumbersome. I didn't want guesses...I wanted to have similar functionality to my wife's base model KIA. Call me crazy! I find myself wondering what is so great about my truck. I now think the "Limited" badge means that it is full of limitations. hahaha
  9. Jun 19, 2015 at 12:51 PM
    #589
    replica9000
    2019 T4R ORP
    I've had a couple GM cars with that feature, and it was usually off by quite a bit.
  10. Jun 19, 2015 at 12:57 PM
    #590
    Boosh63
    Timmins, ON
    My wife's 2011 KIA Optima's fuel monitoring is near bang on. I have to keep reminding myself that my $'s paid for a dependable ride. My 04 Colorado was a POS...period. All I ever wanted from it was heat, A/C, 4WD and brakes...at any given time one or more of those were out and in the most inconvenient times. I chose the 2013 Tacoma Limited over a 2015 Colorado.
    This Torque Pro app and OBDII adapter will absolutely have a use...no question.
  11. Jul 16, 2015 at 6:18 AM
    #591
    WHT.RUS
    WHT.RUS Well-Known Member
    I used the two PIDs. Sensor one always spikes when i give gas making me wonder if i made a mistake in the PID. Sensor 2 looks fine at idle.. How does sensor 1 measure the temp?Screenshot_2015-07-15-21-05-45.jpg
  12. Jul 16, 2015 at 6:59 AM
    #592
    Aw9d
    Aw9d That one guy
    I think your first sensor is wrong. What is the pid settings you used and hear of your truck?
  13. Jul 16, 2015 at 7:04 AM
    #593
    WHT.RUS
    Its a 2013
  14. Jul 16, 2015 at 8:06 AM
    #594
    Aw9d
    Aw9d That one guy
    I have a 2011 and my codes are different. I think the ECU might be different for the 2013's however.
    So the only difference I see is for tranny temp 1, I use letters A and B vs E and F and for temp 2 I'm using A and B vs G and H.
  15. Jul 16, 2015 at 10:56 AM
    #595
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    This is what I'm using for my '12 and it's working fine. If I understand correctly, it should be the same for '13.
    worth a shot anyway.
  16. Jul 16, 2015 at 11:03 AM
    #596
    scocar
    scocar hypotenoper
    Just got my BAFX, can't wait to download the app and give it a go this weekend when I fix my AF sensor.
  17. Jul 16, 2015 at 11:20 AM
    #597
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    hey are they're any other PID's for the 4.0 in the 2nd gens? Not that its a huge concern but i think i saw where on honda's u can add one for injector duty and stuff, and where would be the place to look for the formula's? (i have the Trans temp btw)
  18. Jul 16, 2015 at 5:26 PM
    #598
    WHT.RUS
    Well it worked with the new PIDs. Thanks! I do have few concerns. Just drove for about 15 minutes. 100 F outside temp. Looks like the tranny is pretty hot at 195 F. Has a towing package with a supercharger and the additional tranny cooler it came with. Also the AFR spikes to 18 when letting go of the gas. In boost mode runs rich as low as 11.
  19. Jul 16, 2015 at 5:30 PM
    #599
    WHT.RUS
  20. Jul 16, 2015 at 5:54 PM
    #600
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Can't speak to the afr but the tranny temps don't surprise me based on what I've seen. I've seen it get up to 218 or so going up the mountains and cool back down to 180 going down.
