Write-Up: Torque APP OBD2 Reader
Discussion in 'Performance and Tuning' started by BrokenTusk, Oct 20, 2011.
  1. Feb 15, 2018 at 5:09 AM
    #681
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Straight through all speeds. N/A, no engine mods other than a snorkel.
  2. Feb 15, 2018 at 5:11 AM
    #682
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Could be the snorkel but i would reset the ecu by pulling the battery cables for an hour.
  3. Feb 15, 2018 at 5:11 AM
    #683
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Its normal for it to just to 18.xx when you are decelerating. There is a fuel cut and the truck is using the momentum of the driveline to keep the engine running for the most part and doesnt require enough fuel to correctly meter the afr.
  4. Feb 15, 2018 at 5:14 AM
    #684
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Cool. Thanks.
    yota243[QUOTED] likes this.
  5. Feb 15, 2018 at 5:24 AM
    #685
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I'm trying to figure out a rather large drop in mpg. Only thing I can think of was an accidental short from fuse box positive cable to engine block while I was replacing my stock wires. Or possibly brake drag from the rear....maybe a faulty injector.....gotta figure this shit out I'm getting like 275 km/tank. Thanks for the info though. I'll start a new thread.
  6. Feb 15, 2018 at 5:32 AM
    #686
    yota243
    E.J.
    north Alabama
    Winter gas, and are u warming ur truck up before you drive? How big of a drop is that? I usually get a 10-20% drop from summer to winter driving
  7. Feb 15, 2018 at 5:43 AM
    #687
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I should be getting around 375 to 400 kilometers per tank.
  8. Feb 15, 2018 at 7:22 AM
    #688
    yota243
    E.J.
    north Alabama
    Do you have your instant mpg readout on torque? That will tell you if your driving habits are doing it and if so where. How are your tires? Aired up and aligned properly? Any new driveline vibrations that could be causing additional load on the engine? Have u for some reason swapped to a heavier oil or diff fluid?
    Thyces[QUOTED] likes this.
  9. Feb 15, 2018 at 7:37 AM
    #689
    Thyces
    Ontario
    2009 DCLB TRD Sport
    All of the above except oil. Switch tires from 265 7017 to 255 80 17 @ 34 psi. I did drive into a ditch during a bad snow storm going 90 km/h so an alignment will be necessary but I want to swap the springs on my 5100s first so I don't have to re do it afterwards. Driving habits....well.... Let's say I'm not easy on the skinny pedal. But that's always been. Recently added a 1 inch block spacer on the rear sitting at about four and a quarter lift from original height. I'll be doing a poly carrier bearing soon so I'm planning to align my drive shaft and angles at that time.
    yota243 likes this.
  10. Feb 15, 2018 at 8:53 AM
    #690
    yota243
    E.J.
    north Alabama
    You are also goin about 8% farther than your odo says with those 33's
  11. Feb 15, 2018 at 9:08 AM
    #691
    Thyces
    Ontario
    2009 DCLB TRD Sport
    7.7% to be exact...guess I'll have to do all my repairs before I see whats what.
  12. Feb 15, 2018 at 9:47 AM
    #692
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Mine does that also
  13. Feb 16, 2018 at 6:15 PM
    #693
    bdbrown
    bdbrown Well-Known Member
    Benjamin
    Canada
    '06 SWB DCSB MT
    lucky rocketship underpants
    I just pulled myself out of a mpg nightmare with a spark plug change.. if its been a while, try pulling a passenger side plug to check the gap/condition.. if i am to trust my torque app I've doubled my mpg for about $30.. and maybe a little lighter foot..
  14. Apr 14, 2018 at 5:15 PM
    #694
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    i have the elm327 mini and have not been able to get the ecu to connect.
    The red light just stays on and cycles through the phases.
    Does anyone have any input,
    I really need to scan to see what the air bag code is.
    Input ?
  15. Apr 14, 2018 at 11:11 PM
    #695
    bdbrown
    Benjamin
    Canada
    '06 SWB DCSB MT
    I have the same one, it's a bit finniky.. Truck is running, or acc power on at least? Phone can find it listed in the bluetooth settings?
    You have torque or similar app running, and set to pair thru bluetooth?
    if you haven't already figured it out of course, bit late to the show, sorry.. took me a while to establish connection as well..
    even now sometimes i have to pull the adapter from the obd2port and reseat it to get it to connect to ecu.. it's picky
    inwood customs likes this.
  16. Apr 15, 2018 at 7:04 PM
    #696
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    so keep going at it... Yeah i had to connected, but sometimes it shows up as a wireless head phone logo as well... i dunno strange
  17. May 14, 2018 at 3:56 PM
    #697
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    I think my ELM 327 crapped out on me, it wont connect to the ecu or even Bluetooth now.
    What is another brand everyone is using with no problems?
  18. May 14, 2018 at 3:58 PM
    #698
    replica9000
    2019 T4R ORP
    I have the OBDLink LX. Works good, although sometimes I have to unplug it and plug it back in for the phone to see it.
  19. May 14, 2018 at 5:20 PM
    #699
    Dennisi01
    Dennisi01 Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    I just discovered this even exists. Any specific models recommended? The 11 dollar one from Amazon any good?
  20. May 14, 2018 at 5:30 PM
    #700
    lilgerber
    Aaron
    Fresno, CA
    I just bought another elm 327 v 3.0 different brand this time off eBay and a boost gauge .
    Still need to get a AFR gauge and wideband sensor.
