WS transmission fluid is garbage . Get it out of your transmission now
Discussion in 'Technical Chat' started by gearcruncher, Jun 3, 2014.
  1. Jun 16, 2014 at 11:29 AM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    ^^same here^^ Which synthetic? I always use mobil 1. Never really had any luck with redline or royal purple. Its just a matter of time before I flush the factory crap out.
  2. Jun 16, 2014 at 11:46 AM
    SpoilsofWar
    SpoilsofWar Well-Known Member
    Wilmington NC
    2014 DCLB 4x4 TRD Sport Super Charged
    Subscribed
  3. Jun 16, 2014 at 10:02 PM
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    Spill it already!
    :playball::playball::playball:
    RJM
  4. Jun 16, 2014 at 10:24 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    You cant just jerk us around and not finish the job.
  5. Jun 16, 2014 at 10:25 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I just got done pulling the pans on a '98 and an '04, If what you are stating, the '04 had WS and the '98 had something else. All I can say is the '98, with 280k on the clock looked much better than the '04 with 60k. I was very suprise that there was very little material stuck to the magnets on the '98, quite a bit more shaving were atteched to the magnets on the '04.
    I actually decided to keep the tranny out of the '98 as a spare because it looked so good.
    I'm sub'd
  6. Jun 17, 2014 at 4:28 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    The Tacoma didn't get WS till '05, not '04.
  7. Jun 17, 2014 at 5:33 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
  8. Jun 17, 2014 at 5:47 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
  9. Jun 17, 2014 at 5:49 AM
    mb911
    mb911 Well-Known Member
    Ben
    Burlington WI
    4X4 double cab
    none
    sub'd
  10. Jun 17, 2014 at 6:04 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Must be lesson time...
    How to subscribe to a thread
    -> select Thread Tools from top toolbar
    -> select Subscribe to this Thread
    Done!
    And with no thread noise :rolleyes:
    mpm likes this.
  11. Jun 17, 2014 at 6:20 AM
    nfs257
    DFW
    She gone
    It was easier to do it the way I did since I was on my phone. lol :rolleyes:
  12. Jun 17, 2014 at 6:38 AM
    BamaToy1997
    Bill
    Navarre, FL
    While I will patiently wait to hear what supporting evidence you have, I will state that you are making one statement that is incorrect.
    While Aisn Warner does say that the ATF should be changed every 30k, and 25k under severe use, Toyota DOES state that ATF should be changed at 60k under severe use, not 100k. GM says the same thing about their Dex VI, that is can last 100k or more under normal duty. As for compatibility I do know for a fact that in many transmissions using a fluid that is not compatible can cause unusual operation. I have seen 4L60E transmissions in a 2010 that shifted strangely when using Dex III, but then flush it with Dex VI and it started shifting normally again. While it was perfectly fine to use the Dex III in a 2002 4L60E transmission. Same model, but the detailed internal valving and solenoid operation was different.
    For example, just because a transmission has a valve body and internal parts that LOOK exactly the same, does not mean they will function the same. I would not take a valve body from a 2005 Tacoma and install it in a 2009 Tacoma and expect it to be fine. They have different part numbers, but will bolt up just fine. Hell, the valve body for a Tacoma access cab has a different part number than the valve body for a regular cab. Why? Because they are designed slightly different. Both will bolt right up to either transmission, but one will not properly function in the other.
    I think the key here also is what is considered "normal" duty and what is considered "severe" duty. Below is an excerpt from Toyota, stating what is considered "severe" duty. I think after reading it, NOBODY on TW drives under any condition OTHER than severe.lol.
    That being said, I would like to read what is being said about the WS fluid. I am not saying that WS fluid is good or not. I do know that if you don't use the fluid that Toyota says is the only compatible fluid available, they can deny a warranty issue if the transmission were to fail. But I know you know this Gearcruncher. I accept that you want to wait for copyright approval, but can you link us to an article? That is not copyright infringement.....
    I always do enjoy reading your input and information G.C. I will patiently wait to find out what your documentation states.
    BillsSR5 likes this.
  13. Jun 17, 2014 at 9:43 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Buy a manual.
    goonsquad08 likes this.
  14. Jun 17, 2014 at 8:56 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Some parts of the country, and our Prerunner and 4x4 brothers who spend more time in the dirt than the mall? Absolutely.
  15. Jun 17, 2014 at 8:57 PM
    #35
    Rich91710
    Rich
    Los Angeles
    08 Base
    I'd kill myself if I had to use a manual again in Los Angeles.
    lamjam and jetfishn like this.
  16. Jun 17, 2014 at 9:30 PM
    #36
    koditten
    Kirk
    Central Michigan
    Its got WS now.
  17. Jun 17, 2014 at 9:42 PM
    #37
    Rich91710
    Rich
    Los Angeles
    08 Base
    Only the 4.0 5 speed.
    The 2.7 4 speed still uses T-IV
  18. Jun 18, 2014 at 6:46 PM
    #38
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    I have a manual and drive in Miami all the time, and I'd kill myself if I had to drive ANYthing in LA.
    Are we even? LOL
    Flori-duh Taco likes this.
  19. Jun 19, 2014 at 6:09 AM
    #39
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    OP is casting such a shiny hook...
  20. Jun 19, 2014 at 6:20 AM
    #40
    PhillyTacoma1230
    PhillyTacoma1230 Well-Known Member
    South East PA
    '12 DCLB TRD Sport
    Santoshi Raptor Style Grill, Weathertechs, 33" General Grabber at2 265/70/18, Kobalt Slimline, Flowmaster 40, Outdoor Edition Bedside Decals, 5100's set at 1.75" with 1/4 toytec spacer both sides, Wheeler's 1.5" AAL
    I was experiencing rough shifting in my 2012 4.0 dclb as well. I recently did a complete flush, drained out the WS fluid and replaced it with Valvoline Max Life Synthetic. The tranny seems to shift much smoother now and it only cost me about 70 bucks and about 1hr and 30 mins of my time. Please note when I drained the WS fluid it was black and smelled burnt. I wish I had taken pictures.
