WTF - just over a 1000 miles...
Discussion in 'Suspension' started by goufcustom, Jun 24, 2012.
  1. Jun 24, 2012 at 2:38 PM
    goufcustom
    goufcustom [OP] 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    I just upgraded to 5100s in the front with Eibachs and new coil isolators and I was doing a check on everything today and saw this...
    See it on the right side, the isolator is split...
    :mad:
    I haven't even offloaded yet, I have just done a few trips to the airport for work.
    On the up side, it is yet another reason to go in and change my settings from 0 to .75
  2. Jun 24, 2012 at 7:56 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Are those factory or aftermarket isolaters/bushings and top plates?
    I am running 5100 and eibach as well but just reused my stock pieces.
    I aligned the eibach coils to sit where the factory spring left the imprint. Did you do the install or a shop?
  3. Jun 24, 2012 at 8:04 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    wouldnt let that ruin your day... just set them to 2.5 and get an AAL pack for the rear.
  4. Jun 24, 2012 at 8:06 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    NO, do not set to 2.75 w/ eibachs. Max is .85.:banghead:
  5. Jun 25, 2012 at 2:29 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Is there a shoulder in the top hat that would keep the spring centered without the isolator? Most coilovers don't use rubber isolators, at the expense of slightly stiffer ride.
  6. Jun 26, 2012 at 6:58 AM
    goufcustom
    MD
    They are aftermarket coil isolators from Energy Suspension, I bought them from Toytec, not that it makes a difference where I got them. I did the install, and they are on correctly. The 5100s are set to 0. The top plates are factory with new studs from Wheelers. I did not reuse my factory isolators because they looked pretty bad, and had 100k+ miles on them. That was one of the main reasons I got new 5100s, plut the added lift.
    Also already have a AAL in the rear, and I will be putting them at .85 to level it, I had some fear of .85 with eibachs being too high, so I went for the lower 0 setting, and I also feared needing UCAs, something I have no interest in replacing with aftermarket because of the cost.
    I plan to replace these with more new ones, and set the 5100s to .85. I will check to see if I saved my old isolators, and if I did, I may just use those, sadly I think I throw them away... And it looks like you cant just bu new ones.
  7. Jul 28, 2012 at 8:10 AM
    goufcustom
    MD
    Got in an went back to factory isolators and set my 5100s to .85.
    Some pictures of the broken isolator, looks like the sharp edge on the eibachs cut it.
