WTS???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cwadej, Jun 28, 2020.
  1. Jun 28, 2020 at 11:14 AM
    cwadej
    cwadej [OP] Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    Installed a lightbar using its wiring harness, pulles main power off the battery. Switch illumination and relay trigger power come from the tail light fuse. Sitting here listening to the radio (weak stations due to locatio) when I turn on the lightbar, thhe station drops, and the "ST" indicator on radio goes off.
    Only one strong station here, doesnt happen to it.
    What the snoopy?
  2. Jun 28, 2020 at 1:07 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    RFI from the LED light bar.
    Jimmyh likes this.
  3. Jun 28, 2020 at 1:53 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
  4. Jun 28, 2020 at 7:34 PM
    cwadej
    Right Here
    2011 Access Cab 4x4
  5. Jun 29, 2020 at 1:48 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Does it say to wire the harness that way?
    I just did a light bar install last week and it has the main power going to the battery off the harness relay and then to the switch.indicator light goes to the dash lights.Black to black and then switch leg to led light bar. It does sound like some interference but the tali light fuse is the same circuit as the radio . I personally would find another power source
  6. Jun 29, 2020 at 3:44 AM
    BlkDakDave
    David
    CC TX
    I put them on LED spot wires near the spot head.
    These are the same little doohickeys that you sometime see on power cords for laptops.
  7. Jun 29, 2020 at 5:52 AM
    cwadej
    Right Here
    2011 Access Cab 4x4
    Bought used, no directions. The wiring harness had the switch constant hot, I dont want that, so I didnt use that. I'll try a different circuit to tap into for switch illumination and relay trigger, or maybe separate circuits for each
