Wyoming B.S. Thread
Discussion in 'North West' started by Blackdawg, Mar 18, 2011.
  1. Oct 20, 2014 at 5:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Sadly...no ha :eek: not an easy to do it at all.
    Cleanest way is running all new cable but that sucks and is expensive.
    You can just extend them by soldering too but doing that with such big cables isn't always fun either.
    Too late to trade the battery??
  2. Oct 20, 2014 at 5:29 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  3. Oct 20, 2014 at 5:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That's not cheap
  4. Oct 20, 2014 at 5:37 PM
    PcBuilder14
    Brent
    Nor Cal
    Well considering he said he's using this chance to upgrade, why cheap out?
  5. Oct 20, 2014 at 5:49 PM
    Tonto27
    Tonto27 We came, we saw, we kicked its ass!
    Joey
    Denver, CO
    2004 double cab
    A bumper here, some tires there..... you know, stuff.
    bummer. yeah, too late to trade really. luckily i have side terminals also so after fiddling with it i think can flip the battery (terminals toward the cab) and reach the side terminals with the main power/ ground and use the top terminals for accessories. i'll have to re-run the power to the stock fuse block (6 gauge i think) but that shouldn't be that hard. hopefully i can find the conversion post for the side terminals and skinnier "military" style connectors. not a whole lot of room to work with in there:eek:
    would probably work but like monte said, not cheap by any means
  6. Oct 20, 2014 at 5:51 PM
    Tonto27
    Joey
    Denver, CO
    2004 double cab
  7. Oct 20, 2014 at 5:54 PM
    PcBuilder14
    Brent
    Nor Cal
    What's wrong with welding cable over power cable made for vehicles? I've never heard of people having issues with it before, other than some poeple complain it doesn't look as good for audio installs :rolleyes:
  8. Oct 20, 2014 at 5:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah I like what you posted Timmy. Not perfect but probably the best solution
  9. Oct 20, 2014 at 6:12 PM
    Tonto27
    Joey
    Denver, CO
    2004 double cab
    i think i might go that rout. thanks Timmy
  10. Oct 20, 2014 at 6:17 PM
    PcBuilder14
    Brent
    Nor Cal
    Cool, was just a question.
  11. Oct 20, 2014 at 8:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You could do a lot worse. :rolleyes:
    You got a link to an ebay seller of this kind of wire? I'd like to start looking a little closer at all this now that I picked up a 7622.
  12. Oct 20, 2014 at 9:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You finally gonna do duals mike?
  13. Oct 20, 2014 at 9:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'll kill you. And the juke
    I will kill you with the juke then take the juke out and drive it off a cliff with you still in it then stuff it full of tantarine and unload on it with a high powered rifle till it explodes
    No juke
  14. Oct 20, 2014 at 9:07 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    ha! funny guy. And really you're just gonna add gas to the fire with that comment Ben after driving the frs and FiST? lol
  15. Oct 20, 2014 at 9:10 PM
    PcBuilder14
    Brent
    Nor Cal
    I'd drive this :notsure:
  16. Oct 20, 2014 at 9:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :D
    But seriously...
    I will kill you
  17. Oct 20, 2014 at 9:14 PM
    SconnieHailer
    Marc
    oh stahhhhp. She'd probably get an auto frs if we're gonna be realistic. She has no patients for a manual at the time being. She can drive my truck just fine but just hates taking the time to do it...
  18. Oct 20, 2014 at 9:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    take the time? its so fun..and natural..i dont...
  19. Oct 20, 2014 at 9:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Thank you sir! :thumbsup:
    You read my mind. You must be psychotic. :p
    That has been my intention all along. Just picking up the necessary pieces. Found a good deal on the BlueSea piece the other day, $145 after shipping.
    I would still prefer to do both batteries on the stock location tho.
  20. Oct 20, 2014 at 9:17 PM
    PcBuilder14
    Brent
    Nor Cal
    Never cared for manual's... But now that I know how to ride a motorcycle I really want one....
