X-Runner No Start - P0102 & P0335
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dmxanswerand1, Mar 2, 2022.
  1. May 27, 2022 at 6:20 PM
    #41
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Weird, I’m guessing it’s using a fail safe strategy to run.
    I can clearly see the sensor pickup plate in the picture above. So we know it’s there. Lol
    For some reason the ECM isn’t seeing a crank signal.
  2. May 27, 2022 at 6:27 PM
    #42
    Dmxanswerand1
    Dmxanswerand1 [OP] Well-Known Member
    Not sure if this helps regarding ECM signal but if I space out the air gap (air gap is about 0.030, so from what I've read it's in spec) between the reluctor wheel and the crank sensor then the engine will turn over but not even fire for a second then sputter out like it usually does with everything connected. Not even sure it shows RPM while cranking spacing it out but I can't remember.
  3. May 27, 2022 at 6:27 PM
    #43
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    So to be clear P0335 sets when the cam sensors are unplugged and the truck won't run and P0340, 343, 345, and 348 set with the sensors connected but the truck runs?
    TnShooter likes this.
  4. May 27, 2022 at 6:35 PM
    #44
    Dmxanswerand1
    P0335 sets with cam sensors plugged in. That is the only code set at this point with everything connected. Barely fires then dies immediately.
    P0340, 343, 345 and 348 set with cam sensors unplugged. P0335 does NOT set. Engine runs as in video.
  5. May 27, 2022 at 6:39 PM
    #45
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ok I gotta sit down and digest this and see what I can come up with.
  6. May 27, 2022 at 6:48 PM
    #46
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ok I have a hunch that the cam sensor connectors are possibly swapped, if I knew the year model of your truck I could tell you wire colors for the connector on each side so you could verify them.
  7. May 27, 2022 at 6:52 PM
    #47
    Dmxanswerand1
    2005 4.0 XRunner. Red wire one is plugged into passenger side, yellow wire driver side.
  8. May 27, 2022 at 6:54 PM
    #48
    TnShooter
    Deogee
    STOCK
  9. May 27, 2022 at 6:56 PM
    #49
    TnShooter
    Deogee
    STOCK
  10. May 27, 2022 at 6:57 PM
    #50
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Well shoot, according to the wiring diagram that appears to be correct.
    The only other things I can think of are physical timing being off or and incorrect or damaged reluctor on one or both cams.
    Since it will run on the crank sensor alone that leads me to believe that the crank signal is good, have you tried plugging one cam sensor in at a time and seeing if it starts with one or the other plugged in?
  11. May 27, 2022 at 6:58 PM
    #51
    TnShooter
    Deogee
    STOCK
    I have no more ideas.
    I’m gonna have to tap out here
  12. May 27, 2022 at 6:58 PM
    #52
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The OCV's don't come into play until higher engine RPMs, they wouldn't cause a no start if swapped I don't believe.
  13. May 27, 2022 at 7:06 PM
    #53
    Dmxanswerand1
    Passenger side cam sensor disconnected, it will fire for a second then die like usual (will attach video).
    Driver side cam sensor disconnected, crank only but no fire. No RPM signal either. P0335 and P0343.
  14. May 27, 2022 at 7:08 PM
    #54
    Dmxanswerand1
  15. May 27, 2022 at 7:16 PM
    #55
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Man I really don't have anything else that doesn't require a scope, I'd really want to see what the signals look like.
    There's really nothing else I can think of to do at this point as a next step besides verifying cam/crank correlation which requires at least a 3 channel oscilloscope.
    I have a known good capture if you track down someone that has one.
  16. May 27, 2022 at 7:24 PM
    #56
    Dmxanswerand1
    Thank you thank you. I'm guessing it would not be adviseable to drive to a shop with the cam sensors both disconnected for fear of rebuilding more heads and timing being off?
  17. May 27, 2022 at 7:33 PM
    #57
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's hard to say on how it would run, up until today I didn't know a 4.0 would even run without both cam sensors.
    If the timing was off far enough to bend valves I would think that would have happened immediately the first time it was cranked but I didn't do the timing job so I would have to say follow your discretion on that but I would advise against driving it until it's determined what's going on.
  18. May 27, 2022 at 7:36 PM
    #58
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Did you use a new timing chain or reuse the one it came with? It might have stretched during that ordeal
  19. May 27, 2022 at 7:38 PM
    #59
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Based on the evidence and the work that's been performed at this point I think a scope capture of the cam and crank signals is gona be the only thing that's gona give the answer to what's going on or at least provide some clues as to where to look.
  20. May 27, 2022 at 7:45 PM
    #60
    Dmxanswerand1
    I reused the same one. I was given the ebay receipt of it dated to a couple months before I bought it so I made the assumption it was good but assuming is dangerous.
    Since everything is pointing to ECM or at least electrical, I popped open the glove box to find this. It appears the purple wire in connector 2 has been messed with as well as blue and r/y in connector 3. Any or those ring crank wiring bells? Will do more tracking when it's light out.
    #60
