xd addicts how will these look?
Discussion in 'Wheels & Tires' started by RDAY, Feb 23, 2011.
  1. Feb 23, 2011 at 9:55 AM
    RDAY
    RDAY [OP] Well-Known Member
    NY
    07 Tacoma SR5 4x4
    with 5.71 in" backspacing and +18 offset
    vs
    the 4.5 backspace and the +12 offset?
    Thanks for any advice
  2. Feb 23, 2011 at 3:04 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    If the wheels are the same width, the 4.5" backspacing ones will stick out 1" further.
    But I can see these rims are not the same width because of the offset (or the offset is wrong).
    The rim needs to be 7" wide for +12 offset to equal 4.5" backspacing. I assume you (or the website you got the specs from) actually meant -12 mm offset, which would be 4.5" BS on a 9" wide wheel (which is much more common aftermarket size).
    5.71" backspacing is +18mm offset only for a ~9" rim.
    As for which wheel is better suited for your needs: What size tires do you want to run? Do you have a lift?
  3. Jun 17, 2011 at 4:18 PM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    The KMC addicts only come in 9" wide for 17' and 18" rims. As for the offset, I believe the 5.71" bs is +18 and the 4.5" bs is -12.
