XM Ready Radio - 2012 tacoma AC 4X4 V6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by helibear, Jan 2, 2012.
  1. Jan 2, 2012 at 11:33 AM
    helibear
    helibear [OP] Member
    Greg
    Indiana
    2012 Tacoma Access Cab 4X4 V6
    I just bought a 2012 Tacoma SR5 Access Cab 4X4 V-6. The sticker indicates the truck is "XM Ready" and the single CD radio has a AM-SAT button on the face.
    Question: Is there an XM fit kit that will allow me to connect the XM receiver to the OEM radio behind the driver's side kick panel and not require the radio to be removed from the dash?
    I find the XM fit kit (PT546-35090) and the XM receiver (PT545-00080) for the 2009-2011 Tacomas that "appears" to allow this, but I do not find anything for the 2012's.
    Also, are all 2012's prewired for an XM antenna? Mine does not have an XM antenna, but I do not know if the wiring harness is there.
  2. Jan 12, 2012 at 6:53 AM
    TheWad
    TheWad Member
    Clint
    Tennessee
    Tacoma
    I just bought the XM radio Mounting Kit PT546-35090 and Tuner Assembly 86180-0W032 assuming the connections were going to be in the left side cowl side trim board.Sorry to say there aren't any connections present.I knew there wouldn't be one for the antenna as there is not one attached to the truck but was sure from what research I did there would be one for the radio.At this time I am waiting for a reply back from the Toyota Dealership as to what I can do.
    (Just found this out)If it does not have the satellite roof antenna,it does not have satellite,nor will these two kits connect to it to the stock radio:Mounting Kit PT546-35090 Tuner Assembly 86180-0W031.I ordered this equipment and just finished taking it back as my 2012 Tacoma doesn't have the radio or antenna connection in the left side cowl side trim board.If your truck had a sat antenna on the cab but no sat radio when pushing the button(sat/am)then these two kits would work as long as you could see the connections present.(I found all this out the hard way.)
  3. Jan 12, 2012 at 10:08 AM
    cixelsyd
    cixelsyd Member
    Portland, OR
    2012 PreRunner SR5 V6
    I'd like to find out about this as well, the truck I test drove had satellite radio, and I was assuming the one I was buying had it as well, but it doesn't. Not a deal breaker, but something I'd potentially like to have, so if anyone knows exactly what we need to buy to make this happen, I'd love to hear it!
  4. Jan 13, 2012 at 10:07 AM
    TheWad
    TheWad Member
    Clint
    Tennessee
    Tacoma
    After taking the equipment back (see above posts) to the dealership I ordered this: Isty11 Satellite Radio Kit With Auxiliary Input (toyota/scion/lexus) and this :SiriusXM SCC1 SiriusConnect Universal Vehicle Tuner from Sears.com but the orders are coming from two different online stores.The first order that I ended up taking back to the Toyota Dealership was $328.This order was $180.35.I will post results after it arrives and is installed.
  5. Jan 13, 2012 at 12:32 PM
    helibear
    Greg
    Indiana
    Clint,
    Is your 2012 an Access Cab 4X4 V-6?
  6. Jan 16, 2012 at 12:08 PM
    TheWad
    TheWad Member
    Clint
    Tennessee
    Tacoma
    no,it is a 2wd 4 cyldr
  7. Jan 17, 2012 at 9:58 AM
    helibear
    Greg
    Indiana
    My '12 Access Cab V-6 4X4 has the harness behind the driver's kick panel to plug in the antenna and the radio. I don't know that they are hooked into anything, however. I do not have an XM antenna, so I assume that connection goes nowhere ....
  8. Jan 20, 2012 at 12:58 PM
    TheWad
    TheWad Member
    Clint
    Tennessee
    Tacoma
    Installed all the equipment and got the SCC1 activated for $94 and some change.The display will not show over 9 characters and there is no way I can find to make this scroll.The sound is just fine and the units are installed behind the factory radio on the left and right sides behind the vents.I am disappointed in the lack of a scrolling as I thought it would show all the text.
  9. Jan 20, 2012 at 2:20 PM
    cixelsyd
    cixelsyd Member
    Portland, OR
    Is that a limitation of the head unit, or is it a dip switch on the interface unit? I installed one in my girlfriend's Honda, and the scrolling was a setting on the HON-SC1 interface there.
    EDIT: Nevermind, I saw in your post above which was the interface.
