XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Aug 9, 2012 at 11:17 AM
    #381
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Still confused.. :(
  2. Aug 9, 2012 at 11:19 AM
    #382
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    I would draw a new one but I don't have Visio on my office computer
  3. Aug 9, 2012 at 11:22 AM
    #383
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Ok, no worries. Which one is which in that pic. The top one is the stock?
  4. Aug 9, 2012 at 11:30 AM
    #384
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Man you guys are all dumb!
  5. Aug 9, 2012 at 11:30 AM
    #385
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Top is Stock inverted config
  6. Aug 9, 2012 at 11:31 AM
    #386
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :mad: REPORTED!
  7. Aug 9, 2012 at 12:06 PM
    #387
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    so what if i did the shackles, and upgraded my rear shocks? good combo?
  8. Aug 9, 2012 at 12:53 PM
    #388
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    forget the right shackle, it was just comparing it to the inverted one.
    The left shackle is the one on the second gen tacomas. if you replace the stock shackle with an extended one it will push the bed frame lower, not move the springs higher. (which is what i used to think that happend too)
  9. Aug 9, 2012 at 2:37 PM
    #389
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Come on guys :facepalm:
  10. Aug 9, 2012 at 3:15 PM
    #390
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Ahhh I get it... was totally getting the pivoting point wrong in my head for some reason... but now it makes perfect sense and I feel like a dumbass lol.
    At first though it does seem pretty counter-intuitive though
  11. Aug 10, 2012 at 8:04 AM
    #391
    kyser13
    kyser13 Well-Known Member
    09 Tacoma/SR5 4X4
    Debadged, Inno bed rack blacked out brackets, Blacked out front Toyota badge, Interior red LEDS, 285/17-70 Duratracs, 17X9 Moto Metal 957s, Toytec 3" lift Bilstiens, Ultra Gauge, LED bed lights.
    Nice idea on the inner trim peices, hiw the heck did you get the steering wheel emblem off, and does the tweeter ring come off like guage rings? Why didn't you sondproof the doors while you had it off? Too much crap to deal with? great truck I'm usually not a fan of the white but yours looks good.
  12. Aug 10, 2012 at 8:05 AM
    #392
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Soooo after much thought and some texts exchanged.. I think I've decided on a set up
    For now, my taco lean spacer to bring it level.. and the defined shackles.
    Then.. hopefully sometime after, Icon 2.5" resi c/o's, Icon 2.5" resi's for the rear, and an Icon aal.
    Problem solved. Stance. Ride. Performance.
    What do you guys think? :)
  13. Aug 10, 2012 at 8:07 AM
    #393
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks man! Appreciate it :)
    Give me a sec, and ill link the thread with my write up..
    Here It is..
    http://www.tacomaworld.com/forum/2n...nished-interior-painting-sound-deadening.html
  14. Aug 10, 2012 at 8:13 AM
    #394
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    The 2.5s in the rear are way over kill but they will look cool lol you can save a few bucks there with the 2.0s other then that looks fine. It will ride well.
    Finally you listen :cool:
  15. Aug 10, 2012 at 8:16 AM
    #395
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Well, I might as well go all out. Lol.
    I just couldn't justify it at first.. but after alot of thinking.. this Is best. It should ride alot better.
  16. Aug 10, 2012 at 8:21 AM
    #396
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    The thing with c/o and stuff is it holds its value really well.
  17. Aug 10, 2012 at 8:22 AM
    #397
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I need to do this :eek:
  18. Aug 10, 2012 at 8:30 AM
    #398
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    True. I'm pretty stoked. :)
    Doooo it! :D
  19. Aug 10, 2012 at 8:34 AM
    #399
    Cr250jumper
    The moon
    50 shades of tan©
    I dont have a system anymore but it has to help with interior panel vibes from the solid motor mounts. The vibration doesnt bother me but the various loose panels are getting annoying
  20. Aug 10, 2012 at 8:35 AM
    #400
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Ext. travel C/O's, and if a used set of allpro leafs pops up in AZ you should jump on those instead of an add a leaf. The icon 2.5 rears seem as if they are designed alot better than the 2.0. the 2.0 look to still be the old Edelbrock design
