xrunner and prerunner gears?
Discussion in 'X-Runners' started by AZsand, Jul 6, 2009.
  1. Jul 6, 2009 at 3:21 PM
    AZsand
    AZsand [OP] Well-Known Member
    As far as i know, engine, tranny and gearbox are the same on both models. Yet i can't find anybody that changed the 3.15 gears on an Xrunner with the 3.73 gears off the Prerunner. Does anybody know if it's a possible swap at all, or is it that nobody does it for other reasons...?
    I'm thinking a 3.73 set of gears coupled to a better clutch and short shifter should make for a bitchin time in an Xrunner...?
  2. Jul 6, 2009 at 3:22 PM
    Untamed_SS
    Untamed_SS Stayed Up Too Late
    Adam
    Haughton, Louisiana
    08 Speedway Blue Access Cab
    Alpine iDA-X200 Deck, Rockford P3, Infinity 1600 A Amp, Black Badges, "KnightRider Mod", Back-up lights. Painted Engine Cover. TRD QuickShifter & Shift Knob. MAF Calibrator. Doug Thorley LT Headers. Custom Y-Pipe. Flowmaster 50 series. Satoshi Grill
    I didn't know the X had 3.15 gears. What is the top speed? It would be higher than a PreRunner with 3.73s right?
  3. Jul 6, 2009 at 3:28 PM
    AZsand
    Its supposed to be 120 top for both. I think the Prerunner has the higher gears for the heavy wheel/tire combo and towing. But in an XR you could use the higher gears for some get up and go...that's what i want
  4. Jul 6, 2009 at 3:42 PM
    Untamed_SS
    Adam
    Haughton, Louisiana
    Yeah, I hear you. Who doesn't want to go faster. :D
    Maybe you could check around some junk yards or something. Or were you thinking about buying them new?
  5. Jul 6, 2009 at 4:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I thought the X runner used the same rear end as the 5 luggers......7.5"
  6. Jul 6, 2009 at 7:58 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    No. All 5-lug V6 Tacomas to date (1995.5 - now) use the so-called '8.4' rear end that's also used in the non-locker 4X4's and PreRunners.
    The '7.5' is only used with 4-cylinder 5-luggers.
  7. Jul 7, 2009 at 4:43 PM
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
  8. Jul 7, 2009 at 5:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I heard they were different, but never heard what the difference is. Being as the third had to be swapped, I guessed the X's ussed the 7.5" third. Good info, Jax! :)
  9. Jul 7, 2009 at 5:53 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    Find a 3rd member, and let's try it. I'll help you swap it out down at my shop. I've only driven a couple of the XR's, but they always seemed to be geared too (numerically) high as it is. I'd be interested to see what happens when you got to the 3.73's in the rear.
  10. Jul 7, 2009 at 6:33 PM
    jaxchrisfla
    flooriduh
    lots
    i think i remember hearing that in 6th at 60mph, the rpms bump up from 2k, to around 3k if not higher with 3.73s. 3k rpms is around 90 stock so that shows your the difference.
  11. Jul 7, 2009 at 7:04 PM
    AZsand
    I appreciate the help....though it got me more confused than anything. Apparently there are issues with the LSD and speedo. They don't talk prices much, but it sounds like a pricey mod, usualy it shouldn't be....i'll look more into it though, ive always been a big gear ratio beliver, clutch shifter and tires, before any horsepower mods
  12. Jul 7, 2009 at 7:13 PM
    jaxchrisfla
    flooriduh
    lots
    parts are pretty pricey as you either have to find a used setup, or go to the dealer. no company makes the gear sets for our trucks. also the same with the speedo. No one has made a correction tool/calibrator for us either as far as we know.
  13. Jul 7, 2009 at 11:17 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    The Hypertech one works for the 2005-08's I thought.
    http://www.hypertech.com/Products/Inline Speedometer Calibrator Module
    Part #730107
  14. Jul 8, 2009 at 6:06 PM
    jaxchrisfla
    flooriduh
    lots
    has anyone had sucess with it?
  15. Jul 8, 2009 at 7:43 PM
    johnecon2001
    Phoenix, AZ
  16. Jul 9, 2009 at 8:43 PM
    AZsand
    I'm still a little lost with the "3rd member" term. Never heard it before. Is that the rear end, like with the axle on it and all??
  17. Jul 9, 2009 at 8:50 PM
    jaxchrisfla
    flooriduh
    lots
    toyota axles use a setup similar to the ford 9" and old eaton axles. The differential and gear set are in a "chunk" that are easily removable and able to work on.
    so basically you can buy a fully built 3rd member, and just swap it in without having to do any addition work. If we had a semi-floater with c-clips, then we'd have to do the gear swap and everything in the axle, which sometimes is a pain in the ass.
  18. Jul 9, 2009 at 9:32 PM
    AZsand
    Nevermind...i got it now
  19. Jul 9, 2009 at 9:35 PM
    kevhogaz
    SR5 PreRunner
    I'll still help you swap out the 3rd members if you want. Shouldn't take but about 30-40 minutes, and I've got the gear lube on hand.
  20. Jul 9, 2009 at 9:38 PM
    AZsand
    How do i make sure that the 3rd member does not have e-locker? There's a guy around here that's trying to sell the whole rear end (axle and all) off an 07 Prerunner....maybe i can get him to sell me just the 3rd member ....which is why i wanna know what in hell i'm looking for....my construction background does not seem to help me understand diffs...
