Y-pipe Problems
Discussion in 'Performance and Tuning' started by DelinquentTaco, Jan 23, 2013.
  1. Jan 23, 2013 at 6:57 AM
    DelinquentTaco
    DelinquentTaco [OP] Active Member
    Colin
    '11 4x4 TRDOFFROAD
    TRD cat-back,TRD CAI,TRD quick shifter,N-fab lightbar & 2 Hella 700ff,AirHorn&compressor&2gal tank, LowRange Offroad leveling kit 3"and1", XDSeries Badlands Chrome 18x9, 285/65/r18 Nitto TrailGrapplers
    Hello, I have a 2011 TRD OffRoad and I was looking under my truck and noticed that my y-pipe seemed to be flattened where it crosses just behind the front cross member. Has anyone else noticed this? Does anyone know if the Doug Thorley performance y-pipe stays above the cross member?
    Thanks.
  2. Jan 23, 2013 at 7:15 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is a factory form. Nothing out of the ordinary.
    If you want an aftermarket Y-pipe that is worth the money, hands down get the URD Y-pipe. It is superior. Not an opinion.
  3. Jan 23, 2013 at 10:43 AM
    DelinquentTaco
    Colin
    '11 4x4 TRDOFFROAD
    Will an aftermarket y-pipe stick below the cross member? Will I have to worry about bending it?
  4. Jan 23, 2013 at 11:24 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The URD Y pipe will not. You will only have a problem with it fitting, if you have a 6" lift which uses drop brackets. Because it will lower the front diff, which in turn lowers the front drive shaft. Which would then make them hit.
  5. Jan 23, 2013 at 11:36 AM
    DelinquentTaco
    Colin
    '11 4x4 TRDOFFROAD
    I have 3" in front and 1" in back so it only has a 1/2 inch or 1/4 inch rake. But i do have diff spacers. what about the DT y-pipe?
  6. Jan 23, 2013 at 11:44 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I don't have any experience with the DT Y-pipe on anything really. Sorry.
