Year end Dec 31 2014 Shok deadener V3 # 3 group buy
Discussion in 'Closed Group Buys' started by manethon, Dec 30, 2014.
Thread Status:
Not open for further replies.
  1. Dec 30, 2014 at 12:26 AM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    NEW Group buy :
    Same rules apply but it won't be a inverse group buy again but a traditional
    : http://www.tacomaworld.com/forum/gr...hok-sound-deadener-group-buy-4-amps-subs.html
    :DImportant :
    This is a sale which expires by Dec 31 2014.
    No payment will be processed at these prices after this date and will be closed.
    This is strictly a TW Special price only!
    Material: Butyl Compound ( custom mix specified at the factory)
    $120 Shipped in USA Plus any applicable PP fees
    Mat Thickness: 1.85mm ( Conservative rating)
    Foil Thickness: 0.1mm
    Mat size: 4sq ft
    Pack side : 40 sq ft ( 10 sheets)
    Clients truck
    3Medium_zps3a0341e3_92310155032ae369f97c9f7874e8434d38857186.jpg[/URL]
    1Medium_zps5381f308_185b865534e2775ed214a36ea57d2e88bf2eeb3d.jpg[/QUOTE]
    Important :
    previous group buy
    http://www.tacomaworld.com/forum/group-buys/322087-gb-2-shok-industry-sound-deadener-v2.html
  2. Dec 30, 2014 at 9:35 AM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    2 packages processed.
    Who all wants one of the best deadeners on the market at one of the best prices :)
    Your time is limited!
  3. Dec 30, 2014 at 4:55 PM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    How much is needed for a 1st Gen double cab Tacoma, will the one kit do it?
  4. Dec 30, 2014 at 5:10 PM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    BAMF kick out sliders, SkidRow skids,Pro Comp 7069, Kelly Safari TSR 285's, Elite front bumpa, OME 883 & Dakars w/ D6XL AAL, Nitro sport shocks, Eddie209 Soft topper, Satoshi, k&n fipk, Clarion vx400, Ultra Gauge, Debadgination mod
    Great question.
    :popcorn:
  5. Dec 30, 2014 at 6:29 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I would like one Pkg. How do I order?
  6. Dec 30, 2014 at 6:47 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    replied.
  7. Dec 30, 2014 at 6:50 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    One pack will cover a first and second Gen Dc adequately but as i said there is 10 sheets of say 2 foot by 2 foot. So it also depends how much coverage your looking to do. IF you want to cover " just about " all of the cab's problematic spots you would need 2 pack, which essentially covers most of the interior.
  8. Dec 31, 2014 at 12:22 AM
    shaneckc
    shaneckc Fyntünd Designs Vendor
    Shane
    Thousand Oaks, CA
    2014 SR Package DCLB 4x4
    how much does one package weigh?
  9. Dec 31, 2014 at 9:03 AM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    This stuff is super thick, and is rather heavy due to the density and quality of the materials used. You only need one layer, its super sticky as well so time spent doing this job is rather fast. I had to double and triple layer some areas of my truck prior to shok that now only took 1 layer. Ill get an EXACT KG weight for you shane
  10. Dec 31, 2014 at 10:02 AM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    Each pack is 12.5kg
  11. Dec 31, 2014 at 11:27 AM
    shaneckc
    Shane
    Thousand Oaks, CA
    Wow, nice. That makes it 50% more dense than DynaMat Xtreme and 75 cents cheaper per square foot. Would you be willing to make a stress test video for us? Put a 1x1 sample on a piece of sheet metal and let it sit in the hot sun for a few hours, maybe. Let it sit in the freezer for a few hours, too. Soak it with water, spray some wd40 on it just so show that it's bond to the metal cannot be weakened with temperature or permeated by solvents. That would sell me on this stuff.
  12. Dec 31, 2014 at 11:35 AM
    shaneckc
    Shane
    Thousand Oaks, CA
    Actually, I just re checked my math and I missed a step. It's about 40% LESS dense than DynaMat but you get 50% more weight per square foot with shok mat due to it's much higher thickness.
  13. Dec 31, 2014 at 11:38 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    i'm considering purchasing 2 kits for my honda fit... only want to eliminate road noise. would dynamat be better for roadnoise?
  14. Dec 31, 2014 at 11:47 AM
    shaneckc
    Shane
    Thousand Oaks, CA
    No. This stuff is still better than DynaMat. More weight per square foot means more particles regardless of density, and mat based sound deadening really comes down to adding weight so that sound waves and other vibrations will not transfer or permeate thin surfaces like metal or plastic and cause audible rattles or vibrations. It also acts as an acoustic barrier which is where density comes into play a little bit but both of the butyl rubber compounds used in DynaMat and shok deadener are VERY dense to begin with, so the difference for that purpose is almost negligible.
    However, while mat deadener is the cornerstone of any good sound deadening setup, to eliminate road noise you will want a high density foam and a layer or two of mass loaded vinyl. These are what really stop the low frequency road noises from coming through.
  15. Dec 31, 2014 at 12:21 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    I hear what your saying and based on what your asking, there is enough out there that people can attest and the tests have been done ill just have to dig it up. The biggest complaint about this deadener is that its TO STICKY. Our adhesive is like no other!
  16. Dec 31, 2014 at 12:57 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    This deadener is exactly what you want.
  17. Dec 31, 2014 at 1:48 PM
    nd1979
    nd1979 2nd Tacoma
    East Texas
    '15 DC TRD OR 4x4, Super White
    Per PM, I am in for 1 pack when you are ready.
    Thanks!
  18. Dec 31, 2014 at 2:15 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    Thank you,
    okay guys, still few hours left to get in on it.
    If your unsure about it today, make sure to post in here so i can forward this to the owner and see if he can extend it by a couple of days:)
    Thanks
  19. Dec 31, 2014 at 2:30 PM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    Ok after a couple hours of debating. Im in. I need it for another mod im trying to install. I will take 1 pack
  20. Dec 31, 2014 at 3:48 PM
    nd1979
    nd1979 2nd Tacoma
    East Texas
    Just sent a PayPal PMT to you.
    Thanks.....(also posted on other thread by mistake)
Thread Status:
