Yellowing headlamp lenses
Discussion in 'Canada' started by markp, Mar 3, 2015.
  1. Mar 3, 2015 at 6:01 PM
    markp
    markp [OP] Member
    mark
    Canada
    2006 Tacoma TRD
    My wife has a 2008 Camry. The headlight lenses have started yellowing. This has significantly reduced visibility when driving at night. Is there anyway to fix this without replacing the headlamp lenses? I was think of putting in brighter headlamps. Will this work? Any help is greatly appreciated.
    Thanks
    Mark
  2. Mar 3, 2015 at 6:02 PM
    gtokarski
    gtokarski Well-Known Member
    George
    Dublin, CA
    06 4x4 xtra cab silver
    OME 886, AAL, ARB Bumper, XRC8 Winch, Sony MEX-N5000BT, and one angry beagle.
  3. Mar 3, 2015 at 8:57 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I believe that 3M stuff is more for pitting/smoking. I don't think it'll help if the lens is yellowing from the inside because of the bulb. It's worth a try, but if the damage is on the inside of the lens or in the lens like what was happening to some early 2nd gen Tacoma's then you'll need new housings.
  4. Mar 4, 2015 at 7:01 PM
    markp
    markp [OP] Member
    mark
    Canada
    2006 Tacoma TRD
    Thanks a lot for the info guys. I think I may try a stronger set of bulbs (the bright white) and see if that cures or helps the problems..Thanks again.
    Mark
  5. Mar 4, 2015 at 7:46 PM
    gtokarski
    George
    Dublin, CA
    In my experience the sylvania silver stars don't last long.
  6. Mar 4, 2015 at 7:56 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Spray them bug spray with highest amount of DEET you can find and wipe with a cloth. It works
  7. Mar 9, 2015 at 1:28 PM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    I used one of the kits to polish the headlights on my Tacoma at around 250,000 km. it worked well, however, by the next summer it needed redoing. Eventually I bought a set of used headlights and tail lights off a guy who had gone with aftermarket lenses all around.
    My issue was pitting on the outside but comparing the old lenses with the new I could really see the yellowing effect as well.
  8. Feb 8, 2017 at 8:10 PM
    TangoKilo
    TangoKilo Well-Known Member
    Republic of Alberta
    2007 TRD 300,000Km
    I bought a similar restoration kit (Permatex.... I think) at Canadian tire a couple years ago and it worked pretty well on my oxidized truck headlights.
    They are starting to get bad again so its time for another application.
  9. Feb 21, 2017 at 7:00 PM
    Twalt87
    Twalt87 Well-Known Member
    Travis
    Vancouver island Bc
    If its on the outside you can get them to look perfect with some work lol.
    Just did this to my gfs 97 civic. I grabbed 3 different grits of sand paper, 800, 1000, 2000. As well as turtle wax rubbing compund and turtle wax polish.
    Wet sanded the shit out of the lenses then buffed them with both waxes. When you do this you are supposed to reseal the lens with a uv protector but my town had no so i didn't, still looks good after 2 years.
    If its on the inside.... i have no idea. used lenses from a wrecker?
