YEP..I have axle wrap!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grow4hobby, Jun 17, 2012.
  1. Jun 17, 2012 at 8:45 AM
    grow4hobby
    grow4hobby [OP] Active Member
    Let me start off by saying hello tacomaworld. I have been reading thread after thread on this site for the last week and wow have i learned alot about my newly purchased 08 DC TRD off-road. My truck has 80,000 miles and I was concerned about the thud whenever I was braking at red lights and then after accellerating. After research on the problem i found that many of you have this same problem.
    MY QUESTION IS, what fix do you guys recomend for me to do? I have read of a couple like changing leafs, adding a traction bar, or u-bolts to the leafs. I am also going to check the torque on the U-bolts to see if they are tight to around 70lbs. I like the idea of the u bolts because it is cheap. I currently cant afford to spend a ton of money on a new rearend. Tacoma experts let me know what you think.
    ps. it is bone stock
    hresendiz25 likes this.
  2. Jun 17, 2012 at 8:55 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    It sounds like you've done your research and discovered an option that fits your budget. Job well done! I think that would work well and solve your issue. I'm in a similary boat and may need to do the same thing.
  3. Jun 17, 2012 at 9:14 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    That's how I eliminated most of my axle wrap clunk. I put clamps exactly one inch in front of the U-bolt.
    It's a cheap fix but it works.
  4. Jun 17, 2012 at 1:48 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    '06 RC, 4X4, 5 speed
  5. Jun 17, 2012 at 4:32 PM
    grow4hobby
    How well did the helper do with the axle wrap? Did it effect your ride at all. Also, what is your new weight capacity?
  6. Jun 17, 2012 at 4:35 PM
    grow4hobby
    I like the clamps you put in front of the U-bolts. I am definitly going to try this out sometime next week until i can afford a more expensive solution. Shoot it might do the trick.
    Thanks for the input guys.
  7. Jun 17, 2012 at 5:01 PM
    seric007
    seric007 Well-Known Member
    haven't installed my airlift airbags yet, I'm wondering if anyone that has installed them noticed the annoying pop disappear? Might be an alternative to a nice upgrade and an annoying axle-wrap solution!
    Sephira likes this.
  8. Jun 17, 2012 at 6:01 PM
    AbqTRD2010
    AbqTRD2010 Well-Known Member
    Michael
    Rio Rancho, NM
    '10 4x4 DblCab Long Bed Sport
    TRD FJ TeamTrail Blk Rims| BFG AT KO 265/75/16| TRD Cat-back Exhaust | TRD CAI | UNICHIP Installed| 5100 Billies @ 1.75 | Rear Leaft TSB & 1" Block| Grillcraft Satoshi Grill | Exclusive Element Light Bar w/ Hella 500FF | Aftermarket Black Headlights & Black LED Tail Lights| Preimium Hook Struts | SungTop LS Tonneau Cover |Black OEM Running Boards | Window Tint @ 20%| Blacked Out Emblems| Shortened Antenna | Flyzeye LED Interior Accent Lighting
    I had axel wrap that was very annoying during both stopping and taking off 90% of the time. I considered the helper spring but didnt want it to stiffen up the ride so I gave the clamp a try first. I added the clamp 2" in front of the axel and now the wrap feeling is all but eliminated. About 10% of the time I feel a very minimal wrap when stopping and that is about it.
    Since adding the clamp, I added a 1" block in the back to level out the back of the truck once the rear TSB springs started to settle more due to my tonneau cover. The axel wrap did not return. I have been very satisfied with the ride and feel during taking off and stopping.
  9. Jun 17, 2012 at 6:28 PM
    Noslow100
    Noslow100 Well-Known Member
    Josh
    VA
    08 SR5 4x4
    Toytec 3 Inch lift kit with Bilstein 5100's, and more
    Damn now I gotta try this
  10. Jun 17, 2012 at 8:55 PM
    grow4hobby
    That is awesome. I can't wait to try out the clamps and see what results i get. I will try to get the parts Thurs or Fri and clamp her down. Ill post an update when i get some miles on the project.
  11. Jun 18, 2012 at 4:13 AM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    What did your axle wrap sound like when braking? I have this noise that has gotten worse when stopping. The bigger the tires, the worse it gets and the more miles I put on doesn't help.
    It use to only happen when I would brake really hard but now does it under almost normal braking. In my case it sounds like the U joint binding and making a knocking sound as I slow down. It only makes this noise it if I gas it in reverse or under braking. When I brake over bumpy roads it gets really bad, like the rear end wants to fall off.
    Both the braking and hard reversing torque the leafs in the same direction (I think). I also hear it going fast over speed bumps sometimes as a single loud knock, which leads me to believe maybe it's loose U bolt/'s. I might have 2 things going on at the same time.
  12. Jun 18, 2012 at 4:39 AM
    09 Redneck
    09 Redneck Well-Known Member
    Ga
  13. Jun 18, 2012 at 9:51 AM
    grow4hobby
    What is aal and TSB pack? Excuse my noobness lol.
  14. Jun 18, 2012 at 11:42 AM
    BTO
    California
    AAL = Add A Leaf
    TSB = 4 leaf pack Toyota came out with as an upgrade that helps the bottoming out problem the standard 3 leaf packs have. Toyota dealers will install them no charge if you complain properly and are still in the 3/36k warranty. The TSBs are only a temporary fix for the axle wrap problem. Once the TSB springs break in the axle wrap comes back.
  15. Jun 18, 2012 at 3:27 PM
    grow4hobby
    The dealership does it you say. Well im well past the original 3/36. It is a 08' with 82,000 I did however get a new 3/36 when i purchased the truck a month ago. Was it like a recall or something? So do you now have 5 leafs?
  16. Jun 18, 2012 at 3:43 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    I like that. Double nutting shows you know some things.
  17. Jun 18, 2012 at 4:14 PM
    monkeyface
    Colorado
    Yeah, after stomping on it from 1st to 2nd, I can feel the clunk. Weird how this is probably the baddest truck on the planet other than a Unimog and a deuce and a half, but they just can't get it perfect.
  18. Jun 19, 2012 at 4:44 AM
    Noslow100
    Josh
    VA
    08 SR5 4x4
    It was only for trucks within the factory warranty. I have an 08 that I bought with 42000 miles and I brought it to there attention with a extended warranty that I purchased from the same dealership and they told me no. Your better off going after market. look inyo some Bilstein 5100 adjustable shocks and an aal. That will help out tremendously.
  19. Jun 19, 2012 at 3:49 PM
    ecoterragaia
    Central Virginia
    The helper springs did stiffen the back end up, but not to the point of being uncomfortable. In fact, cornering seems a lot tighter with them on and there's no load in bed. Hellwig advertises a weight capacity of up to 2500 lbs I think, but they caveate that with "never exceed manufacturer suggested capacity". I haven't hauled anything above ~1100 lbs in the bed, but I can say that there's absolutely no excessive sagging in the back end with that kind of weight. The springs keep the back end level with, or higher, than the front when carrying heavier loads >800 lbs.
  20. Jun 20, 2012 at 9:05 AM
    BTO
    California
    You may have seen my spring clamp fix but turns out to be only a band-aid solution. It did help point me to the real fix but I'm kicking myself because I missed the actual problem when it was right under my nose and it's so easy and makes so miuch sense. Forget the clamp thing (sorry if you took my advice and bought clamps). The real fix is free and requires no parts.
    I saw thread http://www.tacomaworld.com/forum/2nd-gen-tacomas/222674-ubolts-under-torqued.html , put two and two together and realized this has been the problem all along. I removed the spring clamps and torqued my axle u-bolts down to 70 lb/ft. This has completely fixed the axle wrap, firmed up the rear suspension back to where it was when it was new and also fixed the 60 mph drone problem I was having.
    All this time I thought my leaf springs had wore out but all that happened was the u-bolts gradually loosened over time. I think the u-bolts should be checked and retorqued on a regular basis like say every 30k miles. This should be in the Tacoma maintenance manual.
    Kudos to TW user 4WD for posting that milestone thread.
    hresendiz25 and Kolter45 like this.
