Yes, Another Manual Tansmission Question!
Discussion in '4 Cylinder' started by guitarjamman, Jan 25, 2013.
  1. Jan 25, 2013 at 6:16 AM
    guitarjamman
    guitarjamman [OP] Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    First off, I have performed a search but wanted to get some fresh opinions on the matter and ask a few questions that were never covered.
    For those of you with the 2.7 5spd manual transmission - I would like some input on your driving style. I am trying to get the best gas milage without hurting the transmission. I am slow off the starts and do not have a lead foot (a little embarassing when the old lady in a Ford focus beats me in the imaginary drag race :cool:), but once I am up to speed, I always wonder what cruising RPM would be the best to maintain. I could be in 4th gear and hold at 2K or if I head up to 5th, I will drop to 1400. Is one of these more preferrable than the other in your opinion?
    Second: I live in a condo complex that has a lovely 15% grade driveway off the main road. At the top of the entrance slope, the driveway immediately levels off to the complex's distribution roads which is flat. Trees block the view to the right so I have to come to a rolling stop to ensure no one is trying to exit the complex before I make my left. 2nd gear causes a terrible lug while making my left because the rear tires are still on the slope, first gear does not want to engage because most of the time I never drop below 5 mph. Is this a time & place to try and rev match to pop into first to make my left hand turn?
    Lastly, when you are at a stop and it's your turn to go, do you feather the throttle while releasing the clutch or do you just pop up the RPMs to 1200 or so and let off the clutch?
    I know I am probably looking into this too much but the tranny on the Taco is a beast. My older tacoma was an auto and my other car is a manual subaru WRX which is in a completely different league all together.
    Thanks for any input!
  2. Jan 25, 2013 at 11:37 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I run mine in 5th whenever possible. I don't generally shift down from any gear until the tach indicates about 1000 to 1200 rpm, where traffic allows. An engine seems to work most efficiently (best mpg) when it is straining.
    When in the situation you describe exiting your complex I generally do a quick stop and shift to first if it is important to get moving quickly into traffic.
    I don't know how to describe how I engage the clutch. I generally try to increase the engine speed and release the clutch for a smooth takeoff.
    FWIW it appears my truck gets significantly better mileage than most of those reporting on this forum--25 to 29 mpg in everyday driving.
  3. Jan 25, 2013 at 11:53 AM
    The Wombat
    The Wombat Active Member
    Mass.
    09 Access Cab 4WD 4-cyl
    none
    Agreed - I would stick to 5th whenever possible, even try and play the semi-truck game of 'speed down the hill to make it up the next' so you don't have to downshift. As for the starts - I usually blip the gas and then ease into it, same thing when rev-matching. So blip, then squeeze down with a toe. Almost feels like the blip pulls it into gear easier. Sounds like you'll have to down-shift to first to get up your crappy grade. I'd practice rev-matching in the higher gears to start with, as going down to first is the toughest (just like when learning to drive a stick). URD short throw helps (and worth every damn penny)
  4. Jan 25, 2013 at 11:57 AM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    I really disagree with the best mpg when engine is straining.
    you really shouldn't lug the motor. I am no expert with 4 bangers but many people experience a increase in mpg when they depress the ect button on the 3.4 (I had one for 285k) because the shift points are higher and it lugged the motor less.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/133243-ect-power-mpg-increase-why.html
    Motors today seem to be really good at letting you lug them because of electronics that help with timing and throttle control, but normally its really inefficient. I would suggest keep a light foot and only shift when you know that the next gear will be in a place where the engine is "happy". Remember that rpm are not the sole dictator of fuel consumption, vaccume (Manifold pressure) also plays a huge part. When you push the throttle down in too high of a gear your manifold pressure goes through the roof and you end up dumping a lot of excess fuel into the motor that isn't getting burned.
  5. Jan 25, 2013 at 12:11 PM
    CINER
    CINER Active Member
    Cindy
    Fresno, CA
    Tacoma TRD Off Road 4WD
    Brings up a question I have........Do you guys down shift?
    I used to have a 1992 4wd 4cyl...5 speed and I down shifted the crap out of that........
  6. Jan 25, 2013 at 12:51 PM
    Gus 524
    Gus 524 Well-Known Member
    Justin
    MN
    09 tacoma SR5 4WD 4-cylinder
    Yes I down shift. It is a lot safer then just holding in the clutch in when coming to a stop. Also you can have some fun if you need to get going and you downshift! :D
  7. Jan 25, 2013 at 1:03 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Keep it at about 3000 rpm going up your driveway and double clutch it near the peak to fly over whoever might be coming from the side.
  8. Jan 25, 2013 at 1:12 PM
    guitarjamman
    Zach
    Northeast
    2019 Ram 2500
    Didn't work - You owe me a new truck.
  9. Jan 25, 2013 at 9:49 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    haha, made me laugh
  10. Jan 26, 2013 at 5:12 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    You didn't do it right. I said over not onto, lol......consult insurance co for replacement :D
  11. Jan 28, 2013 at 10:59 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I run mine pretty hard, not super hard, but usually shift at 3k, I hate lugging on the clutch. I downshift all the time, and it is better to do that than hold the clutch in, riding a clutch will wear it out fast. 1st to 2nd shifts the smoothest at 3k, anything lower it grinds a bit.
  12. Jan 28, 2013 at 11:07 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    I run mine super hard so i guess i am out of this...
  13. Jan 28, 2013 at 11:10 PM
    Tommy27
    Tommy27 Well-Known Member
    Tommy
    Boise,ID
    White 09 AC 4x4 2.7 5spd SR5
    Leer shell, Bed mat, Grill Guard
  14. Jan 28, 2013 at 11:15 PM
    3RZ Taco
    3RZ Taco Well-Known Member
    Austin
    Oregon
    96 3RZ Stock
    K&N air filter, Toolbox, Window Deflectors, Bug Deflector, BFGoodrich A/T's
    I downshift until 20 miles per hour and use the breaks since 1st isnt an option until about 5-10 mph.
    At highway speed (60) in 5th gear im at about 2k rpms
    If you want to go into first just push the cluth in, neutral let clutch out, put clutch in and into first (double clutch)
    I do an average of "railing" and "normal" i get 19 miles to the gallon consistantly
  15. Jan 28, 2013 at 11:25 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    Honestly , I was thinking about it today. I beat the shit out of mine. I down shift a lot. And she just keeps taking it and I've got 70k on the stock clutch. But on the highway usually in 4th in the power band seems to get the same mileage as when lugging around in 5th.
  16. Jan 29, 2013 at 1:11 AM
    2004TacomaSR5
    Jon
    Montana
    Manuals can take quite a beating and have stood the test of time. Toyota seems to make a pretty hefty gear box, my all time favorites are Borg Warners that they used in old trucks. I don't think you can kill one of those, not sure if they are still used today or not. Don't know much about modern transmissions.
  17. Jan 30, 2013 at 9:20 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    I find no difference when babying it or getting up to speed by revving it higher. If you lug the engine you will use more gas period. Getting moving up to speed for second gear is tough with this enigne. When I rev to 3k on first gear it is moving fast enough and the drive-train can handle to load to second better with no clunks and lugging. The rest of the gears are smooth after that at 2500 rpm shifts. I average 20-21mpg all year with larger tires and a slight lift.
    The key is to understanding that being at 2000rpm and lugging is using more gas then 3000rpm on slight hill or flat road with this engine. People have confirmed this using meters. This also explains why letting the truck slow down in whatever gear you are in uses less gas as the injectors cut when in gear (not in N). You will feel the engine change its tone and it feels like a little surge when this is happening after a few seconds of coasting.
  18. Jan 30, 2013 at 3:02 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Hate to burst your MPG bubble, but I have a large hill that I go up every day at 40 MPH. If I use 4th gear my UltraGauge will show 14.5 MPG up the hill. In third it shows 12.5 or so. Lugging up the hill definitely shows more MPG. At a steady 30 MPH on level surface in third it will show low 20's and 4th will show low 30's. RPM's use more fuel plain and simple.
  19. Jan 30, 2013 at 5:24 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    id have to disagree, i also have a ultra gauge and mine does the opposite.
    if go up a hill in 4th, i have to mash the pedal down harder to keep speed.
    if go up in 3rd, im lighter on the throttle because im in the power-band of the motor.
    it all depends on your speed and how hard your pressing on the throttle.
  20. Jan 30, 2013 at 11:21 PM
    greenmonkey
    greenmonkey Member
    I find that using cruise control helps improve MPG a lot. I will use cruise in the highest gear I can. At times, I need to make every mile I can get out of the tank so I might set cruise at 52 or 53 or 57 if I think I have gas to spare ;)
    I picked up at 2008 4cyl 4wd access cab. I can get over 500 miles per tank, but that requires coasting when driving conditions allow it.
    The simplest way to increase your gas mileage is to drive your truck the same way you would drive a bicycle over a 100 mile trip; meaning (1) don't accelerate to the stop light, (2) don't hold the gas down when you are comfortably cruising down hill and (3) use just the energy needed to get you there.
    That's me now. If you asked me about 3 years ago I would have told you it doesn't matter what you do because you only get about 300 miles per tank ;)
