Yet another question
Discussion in 'Suspension' started by nytmarecoma88, Jan 9, 2010.
  1. Jan 9, 2010 at 9:28 AM
    nytmarecoma88
    nytmarecoma88 [OP] Well-Known Member
    07 tacoma
    Tonnuea Tint euro Tail lights halo head lights billet grille- black debadged black powdercaoted 17's "knight rider" mod aero turbine exhaust black bull bar multicolor halo fogs
    Is it a good idea to install 5100's in the front with blocks in the rear? just to level and lift about an inch overall? or should i get a leaf pack?
  2. Jan 9, 2010 at 9:30 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Do an AAL. Its a cheaper way of lift opposed to a full leaf pack.
  3. Jan 9, 2010 at 9:32 AM
    choptop
    choptop Molōn labe!
    Scott
    Austin, TX
    2014 4Runner TEP
    Short blocks should be ok on the rear if you want to bump up a bit. I wouldn't use blocks much over 1" though.
  4. Jan 9, 2010 at 9:38 AM
    Afwrestler1986
    Johnstown, NY
    The only thing about blocks is that they just provide lift, where an AAL is actually functional. AAL's are not too bad price wise, and you have to take it all apart to install blocks anyways, so why not do the AAL.
    .02
  5. Jan 9, 2010 at 9:40 AM
    nytmarecoma88
    07 tacoma
    i bought the "cheap" lift before i really read anything about it, decided to ditch the front spacer lift for 5100s, but didnt kno if i should keep the blocks, is there much a different between blocks and aal? in the ride i mean
  6. Jan 9, 2010 at 9:57 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
  7. Jan 9, 2010 at 10:04 AM
    nytmarecoma88
    07 tacoma
    ok thanx yall, i guess thats the way im going then
  8. Jan 9, 2010 at 10:16 AM
    nytmarecoma88
    07 tacoma
    one more question, any site that i can order 5100s and the aal?
  9. Jan 9, 2010 at 10:25 AM
    Afwrestler1986
    Johnstown, NY
    Down south motorsports i know have the 5100's. And you can get the AAL from Toytec.
  10. Jan 9, 2010 at 4:53 PM
    choptop
    choptop Molōn labe!
    Scott
    Austin, TX
    2014 4Runner TEP
    Yes, added leafs or spring packs that provide lift will stiffen the ride a bit. In most cases stiffening the rear suspension on a Tacoma is not a bad idea since OEM leafs are known to be weak straight from the factory. Putting 5100s on the rear will also help ride quality regardless of which way you go with the springs.
