Yet another TSB/5100 thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bfoster133, Jun 24, 2011.
  1. Jun 24, 2011 at 10:55 AM
    Bfoster133
    Bfoster133 [OP] If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    so im planning on running my 5100's at 2.5 and getting the rear leaf tsb
    i also am going to run 285/75/16 General Grabbers (im doing the cab mount chop)
    i do offroad also, not a mall crawler...
    so my question is, how much down travel will i have in the front? will my truck be level, or close? and how will the ride be?
    also what problems should i expect?
    Thanks in advance
  2. Jun 24, 2011 at 10:57 AM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Tagging this as I am about to order up and do the exact same thing, save the tire upgrade but I may do that in the future too.
    Where are you getting the 5100s from? Any good deals on those around?
  3. Jun 24, 2011 at 10:59 AM
    Bfoster133
    Blake
    i got mine from offroad unlimited simply because they are 30 min away from me
    got em for like 220 for the pair
  4. Jun 24, 2011 at 11:02 AM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    I think dsm sells them for 170 shipped
  5. Jun 24, 2011 at 11:06 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    DSM* Downsouth Motorsports
    This has been covered at length multiple times in many many threads. Search 5100 and you can read to your little heart's content. To the OP, you have a TRD Off Road which means you have progressive coils in the front. It will ride stiff because you're preloading a progressive coil. EricT, you have a TRD Sport so your coils are linear which means they'll still be stiff but not quite as bad. If you want to maintain, or improve the ride quality, get coils with the 5100's and let them do the lifting rather than preloading the stock coil.
    "Level" at 2.5" is in the eye of the beholder. I think it's nose high at 2.5 personally and would set them to 1.75".
  6. Jun 24, 2011 at 11:14 AM
    Bfoster133
    Blake
    can i clear 33's still? (i am doing the cab mount chop)
  7. Jun 24, 2011 at 11:17 AM
    Pugga
    Massachusetts
    You'll have to wait til someone else chimes in about tire size. I haven't ventured much into that territory, I'm still running stock size tires.
  8. Jun 24, 2011 at 11:20 AM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    Dude, that place is a ripoff!! They'll steal your money with a smile on their face.
    http://www.yelp.com/biz/off-road-unlimited-burbank
  9. Jun 24, 2011 at 11:23 AM
    Bfoster133
    Blake
  10. Jun 24, 2011 at 11:25 AM
    carcharias
    Los Angeles, CA
    '11 AC MGM OR
    They got you a bit more on the price, but thankfully you're installing them yourself; otherwise they would've brought out the lube for YOU.
  11. Jun 24, 2011 at 11:34 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    At 2.5 and only a TSB in the rear you will sit nose high by about an inch maybe a bit less. I don't think 285's will fit without some modifications ...
  12. Jun 24, 2011 at 11:39 AM
    Sheppymach
    Sheppymach Well-Known Member
    Sheppy
    Philadelphia, Pa
    2014 4Runner trail edition
    BLU LOGIC bt, avid, weather tech mats & rain guards, 285/70/17, BenWA's totally AWESOME power sliding window mod.
    I'm running same lift already with 285's and come nowhere close to cab mount
  13. Jun 24, 2011 at 11:42 AM
    Bfoster133
    Blake
    really, can you post your specs, just to double check, 5100's at? rear tsb only? 33's with what rims with what backspacing, sorry for the interrogation :p
  14. Jun 24, 2011 at 11:46 AM
    Sheppymach
    Sheppy
    Philadelphia, Pa
    Check my pics. I did just add a aal but that was for added weight in bed. Stock rims with 1" spacer
  15. Jun 24, 2011 at 11:54 AM
    Bfoster133
    Blake
    how did you cut the spacers? i think ill rub the uca
  16. Jun 24, 2011 at 12:00 PM
    Sheppymach
    Sheppy
    Philadelphia, Pa
    With the revo 2's I didn't rub uca. Used spaces just to push rims out. Cut them on a lathe cause I didn't want them past wheel well. the only thing I rub on is the very edge of the plastic bump hanging down in front
  17. Jun 24, 2011 at 12:03 PM
    Bfoster133
    Blake
    well im going with 285/75 general grabbers on my stock rim, im pretty sure ill rub, whered you get the lathe? id imagen its too expensive anyway, i want 1" spacers but no one has them :(
  18. Jun 24, 2011 at 12:45 PM
    Sheppymach
    Sheppy
    Philadelphia, Pa
    Yeah no one makes a 1" spacer for hub centric rim. Find a local machine shop to cut it down for you. I worked in one and can use all the equipment after hours. But I am sure u won't hit cab mount I am far from it.
