Yokohama Geolandar MT-G003
Discussion in 'Wheels & Tires' started by T6A1C9O, Oct 8, 2018.
  1. Oct 6, 2020 at 2:47 PM
    #281
    Dampahee
    Dampahee Well-Known Member
    So Cal
    2019 TRD Off Road
    Fox Factory 2.5 extended travel w/DSC Eibach 650x14 springs Fox Factory 2.5 x 12 in smoothies with rr and DSC / Accutune Adventure tune Archive Garage shock relocation Archive Garage hammer hangers with 3.6" shackles Archive Garage high clearance cross bar Deaver Expedition u402 stage1leaf pack Camburg Racing Uniball UCA's Total Chaos Gusseted Spindles Marlin Crawler HD LCA/cam tabs Frame Brace gussets @weldstaco front diff reinforment kit Wheelers u-bolt flip kit with super-bumps Crown performance SS 24 in extended rear brake lines SS extended front break lines Exhaust re-route mod Dirt King Cab Mount Relocation OV Tune-91 Performance Nitro 5.29 Gears ARB Front Locking Differential ARB High output in board compressor Slee On-board compressor mount Blais Bros Taco differential breather mod Schmellfab 12.5° sliders with kick out RCI steel IFS skid RCI steel transmission skid RCI steel T-case skid RCI LCA skid BAMF Rear differential skid Relentless Fabrication hybrid front bumper Relentless Fab High Clearance rear bumper ATHF rear fender supports SOS performance rear disc brake conversion Trimmed Fenders 2.5" Softopper TRD Heritage grill RFT Raptor lights Morimoto XB headlights Baja Designs amber S2 flush mount chase lights Baja Designs S8 30 in lightbar Cali Raised Relay Mount Cali Raised cubby switch mount Smittybuilt X20 10 k winch Factor 55 Fairlead Factor 55 Flatlink E Factor 55 Flatlink Ropeguard Tandem Off Road Manor winch solenoid mount 1.25 inch Spidertrax wheel spacers 17x9 Ultra Wheel x103 beadlocks 35/11.5/17 Nitto Trail Grapplers Fend-X Wheel Liners Clazzio leather seat covers Taco Garage DMM Mount Taco Garage Anytime Front/Rear Camera MESO Customs Chrome Delete MESO Extended fuse cover AVS in channel low-profile wind visors Kicker CS tweeters, 6x9, 6.5's Kicker Key amp Kilmat sound deadening
    can anyone take a measurement of mounted hieght of 285/75/17's?
    I purchased 285/70 ridge grapplers a few months back but with the wheeling I'm doing now I need more clearance. it's either 285/75 or the 315. It seems to be a minimal difference between the two sizes. Im trying to find the hieght difference between the two sizes while mounted. I'd appreciate it if anyone could chime in
  2. Oct 6, 2020 at 3:27 PM
    #282
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    I got 32 15/16 that’s at 32psi. 33-1/16 in the rear at 30psi. 285/75/17
    truckbeans, boostedka and Dampahee like this.
  3. Oct 6, 2020 at 3:28 PM
    #283
    Asianguywithatruk
    CenCal
    05 taco DCSB
    forgot to quote you. See above.
    truckbeans and Dampahee[QUOTED] like this.
  4. Oct 6, 2020 at 4:15 PM
    #284
    Dampahee
    So Cal
    2019 TRD Off Road
    Thank-you! man I was hopingnit would at least measured just above 33 in. I read somewhere else 315's measures 3.5 in on a 17x9 rim. what size wheels are you running? maybe I'll get a little more height since I'm only running 17x7 wheels.
  5. Oct 6, 2020 at 4:16 PM
    #285
    Dampahee
    So Cal
    2019 TRD Off Road
  6. Oct 6, 2020 at 4:26 PM
    #286
    Asianguywithatruk
    CenCal
    05 taco DCSB
    I’m running Scs sr8. 17x8.5
    Dampahee[QUOTED] likes this.
  7. Oct 6, 2020 at 4:28 PM
    #287
    Dampahee
    So Cal
    2019 TRD Off Road
    thank you buddy, I appreciate it. I might stick with this size. not sure if .5 inches would be worth the amount of work to fit 315's. There is always the 35x10.5 Kendas, but just can't wrap my head around that tire, not sure if it's the look or how skinny it is.
  8. Oct 6, 2020 at 6:42 PM
    #288
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    If you have the right backspacing itll look good
  9. Oct 6, 2020 at 6:45 PM
    #289
    Dampahee
    So Cal
    2019 TRD Off Road
    it's already skinny as is, and on my 7 in wide rim, it might look even worse lol. the BS is 4.5.
    I just don't want to end up buying 3 sets of tires in 3 months if I cant get over how it looks.
  10. Oct 16, 2020 at 8:50 AM
    #290
    andbeyond
    andbeyond Insta @brett.acree
    Brett
    Poplar Bluff, Missouri
    2011 Magnetic Tacoma DCSB TRD Off Road T|X
    Bilstein 6112 up front set at the third notch with SPC UCA’s, Bilstein 5160 in the back. 285 75 16 Yokahoma Geolander MT
    I just had these put on yesterday. 285 75 16. They seem a lot skinnier than my previous tires of the same size. When I pulled away from the shop I was dumbfounded by how smooth they road. I had to get out and make sure they put the right tires on. With only about 10 miles on them I can’t give a good review, but they look mean as hell and the ride is as smooth as the highway tires on my work van. I wish they were a little wider, but I’ll get over it. They do rub a little on the passenger side in reverse, but I’ll work that out this weekend.
  11. Oct 18, 2020 at 6:32 AM
    #291
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    They claim 8% better tread wear than the competitors, what mileage does that actually mean before they need replacing? Around 40K? Im at 55K with my Duratracs and there’s another 10K left with these.
    Here’s a pic bc threads are worthless without em:D
    Road_Warrior and Dirk Diggler like this.
  12. Oct 18, 2020 at 11:46 AM
    #292
    NWTacoTime
    NWTacoTime Well-Known Member
    Nate
    WA - Seattle/Kent
    Cement SB 2019 TRD offroad -
    Car Seats
    Took a road trip out to Utah- on the way I went off-roading in some sand/dirt/rocks and they again had no issue, great traction. On my trip home I drove through torrential downpour going 65-80 mpgs through a twisty turny mountain pass with standing water on the road, no hydroplaning or any signs of slipping . Need to test snow but so far they’ve been awesome still (7000 miles in roughly )
  13. Oct 23, 2020 at 8:09 AM
    #293
    tacotoospicy
    tacotoospicy Well-Known Member
    Luke
    P'cola, FL
    2019 TRD OR
    sirius xm
    Any of you guys running the 255/75r17s?? here are the specs on them. Curious if they'd look too skinny
    specs.jpgm
  14. Oct 23, 2020 at 8:38 AM
    #294
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I’m interested in that size as well. I like that it’s a 6ply c rated.
    Dirk Diggler likes this.
  15. Oct 23, 2020 at 10:56 AM
    #295
    Burmapeak
    Burmapeak Well-Known Member
    Oregon
    2017 Tacoma TRD PRO Cement
    I'm still trying to figure out why tire manufacturers offer 17's in C-Load but in 16's they always have E-Load
    Road_Warrior likes this.
  16. Oct 24, 2020 at 4:55 PM
    #296
    boostedka
    James
    NM
    That perplexes and frustrates me as well.
    :confused::confused::confused:
  17. Nov 3, 2020 at 4:51 AM
    #297
    MDUBIE
    MDUBIE Well-Known Member
    mike
    MA
    2019 White dcsb sport 6mt
    Just got a set installed last night, had rain and snow this morning. Felt the same as the ridgegrapplers they replaced. I was pretty surprised.
    Asc_0989, boostedka and NWTacoTime like this.
  18. Nov 3, 2020 at 7:47 AM
    #298
    NWTacoTime
    Nate
    WA - Seattle/Kent
    Car Seats
    would love to hear a further review as the day/week goes on (assuming the snow sticks)
  19. Nov 3, 2020 at 12:34 PM
    #299
    andbeyond
    Brett
    What air pressure is everyone running in these? When mine were installed I checked them and they were about 37 lbs and I was bouncing all over the road. I lowered them to the recommended pressure on the door frame (29 front 32 rear) and they don’t bounce anymore, but they are louder with the shoulders firmly on the road.
  20. Nov 3, 2020 at 1:03 PM
    #300
    NWTacoTime
    Nate
    WA - Seattle/Kent
    Car Seats
    I've been running them at 32-34 and have enjoyed that
