Yokohama Geolandar MT-G003
Discussion in 'Wheels & Tires' started by T6A1C9O, Oct 8, 2018.
  1. Mar 2, 2023 at 11:01 PM
    #1121
    45thparalleln
    45thparalleln Well-Known Member
    PNW
    '04 3RZFE / '99 5VZFE
    Looks like I'll have to store a spare set of 3-peak rated A/Ts for next Winter these M/Ts are terrible on icy road, it's doable if you drive slow--I was slipping here and there going down steep hills around my area, going uphill is OK. I run 33 psi on the daily, ran 28 psi on icy road, 20 or below in deeper snow/mud
  2. Mar 3, 2023 at 11:40 PM
    #1122
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Once again Amazon is unavailable. Hard to get a set out here or 33x12.50r15. I’m not paying 600 bucks for shipping to Hawaii.
  3. Mar 4, 2023 at 7:53 PM
    #1123
    45thparalleln
    PNW
    Heading to Maui in a few weeks I'll bring you a set :bikewhoops: :mudding: lol all jokes aside maybe check Costco if you have a membership? Possibly Walmart as well
  4. Mar 4, 2023 at 10:42 PM
    #1124
    Sebz13
    Shane
    Maui Hawaii
    Walmart I wanna see if they have em in stock
    45thparalleln[QUOTED] likes this.
  5. Mar 9, 2023 at 9:35 AM
    #1125
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Interesting video posted in another thread about another tire but I'm wondering if it's relevant here and wanted to get some thoughts. The G003's were my first MT tire and I tried the chalk test but experienced what they talk about in the video of having to go pretty darn low to get the desired chalk test result.
    https://youtu.be/iGB0f9qn8-o
  6. Mar 9, 2023 at 10:06 AM
    #1126
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    This is true for probably a lot of MT style tires yes. Problem is that if you go through the inflation tables to get the tire up to the OEM load capacities, you need to be at 35+ and out "trucks" are "light" compared to what LT tires are capable for, so its always "overinflated" by a chalk test.
    That said many still run 28, 30, 32 PSI and are fine....its probably just not up to the OEM load capacity at that point, but should hold the truck fine....air up before towing basically.
    Its all a balance of comfort , wear patterns, and longevity. I find with my G003 pizza cutters they are narrow enough that my 35 psi is close to good, and regular rotations seem to keep them wearing nicely.....wider you go, worse Id imagine the issue is.
  7. Mar 9, 2023 at 10:32 AM
    #1127
    clenkeit
    Colin
    Lakewood, CA
    Good points. I guess I was specifically referring to proper tire pressure for even wear during normal on-road driving. Then I just air down from there for offroading and air up from there for hauling/towing.
  8. Mar 9, 2023 at 9:00 PM
    #1128
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    I think I'm in love..
    rip ej1, Road_Warrior and iwashmycar like this.
  9. May 6, 2023 at 7:18 AM
    #1129
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    Can anyone comment on the road noise on these? Some reviews say they’re the quietest MT you can get, while others say they’ll blow your ear drums out.
  10. May 6, 2023 at 10:53 AM
    #1130
    DRob
    DRob Well-Known Member
    David
    Nor Cal
    2017 DCLB OR4X4 SW
    Fox w/DSC, Camburg UCA, SCS GEN5 17x8.5 -12,
    Ok I have 6k on these tires and they are as quiet if not quieter than BFG KO2s. I’ve had KOs on my Tacoma and previously on my 1st gen tundra. They are louder than Falken Wildpeaks which I had on for 10k prior to this set of Yoks.
    09-02-23 update:
    Got 11k on them and they are noisier now.
  11. May 6, 2023 at 11:12 AM
    #1131
    Nate88cool
    Nate88cool Well-Known Member
    Nate
    NE Ohio
    2020 Tacoma TRD OR MT (and 2 jeeps!)
    None
    We have a set of these on our Jeep (37s) and love them. I rotate all 5 and so far have about 15k miles on them with lots of heavy off-road use. Mostly rocks. The lugs have some signs of chunking but on highway they are still quiet and ride smooth and over 50% tread left. We have headlocks and depending on terrain I run an average of 8psi off-road. On road loaded for overlanding I run about 33psi. The only downsides I experienced with these tires is they are a bit on the heavy side and they pick up and fling rocks like no other. Other than that I don't know if I'll ever change to another tire and plan to add them to the Tacoma when I'm ready for new tires.
    Chapman likes this.
  12. May 6, 2023 at 12:52 PM
    #1132
    Chapman
    Chapman Well-Known Member
    Bay Area, CA
    2013 SW DCLB TRD Sport 4x4
    I've been lazy to rotate tires on my last few sets but I just upgraded to 35s, so I'm really going to try and rotate all 5 this time around.
  13. May 6, 2023 at 1:06 PM
    #1133
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Do you have a number for the weight? I'm currently running a used set of 315/75r16 Patagonia's but I'm looking ahead to when they burn up and it's either a new set of Patty's or these. Weight is huge since I'm not geared, but I can't find a solid number for wether or not these are the same weight or heavier
  14. May 6, 2023 at 7:26 PM
    #1134
    greymachine
    greymachine @taupetacoma
    SoCal
    19 Quicksand TRDOR 4x4 DCSB
    315/75R16 is 68.8lbs, 35x12.5R17 is 70.8.
    Brownmatthall and Thatbassguy like this.
  15. May 17, 2023 at 11:00 AM
    #1135
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    Got something to help turn my Geolanders
    ClassyTacos, ETBA, CowboyTaco and 9 others like this.
  16. May 17, 2023 at 12:33 PM
    #1136
    DRob
    David
    Nor Cal
    2017 DCLB OR4X4 SW
    DAMN!!!
  17. May 17, 2023 at 6:31 PM
    #1137
    619_TaCo
    619_TaCo Well-Known Member
    Luis
    San Diego, CA
    ‘08 Tacoma AC PreRunner V6
    -Duratrek Side Step Bars -Flowmaster FlowFX Cat-back Exhaust -‘Master Tailgaters’ Tailgate Backup Reverse Handle with Camera -‘StyleLine’ Smoke Tail Lights -Cooper Discoverer STT PRO 315/75/R16 -SCS F5 16X8 3.50” -25mm
    Broke my cherry today, boys :muscleflexing:
  18. May 17, 2023 at 6:37 PM
    #1138
    Nate88cool
    Nate
    NE Ohio
    None
    Tacoma is getting them next, love these tires!
    DRob and Thatbassguy like this.
  19. May 17, 2023 at 6:44 PM
    #1139
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Looks sic! What size? They look huge!
    619_TaCo[QUOTED] likes this.
  20. May 17, 2023 at 7:05 PM
    #1140
    619_TaCo
    Luis
    San Diego, CA
    Thanks dude!
    Huge is an understatement haha :laugh:
    They’re 35x12.50R17
