Yokohama mud terrain 255/85 r16
Discussion in '1st Gen. Tacomas (1995-2004)' started by Outlama3, Oct 29, 2021.
  1. Nov 2, 2021 at 5:50 AM
    TheColoradoAthlete
    TheColoradoAthlete Well-Known Member
    Colorado, USA
    2020 DCSB TRD OR
    First post here; I am installing my suspension on Friday after work and then picking up a set of the G003's in 255/85/R16 Saturday morning, keeping the stock TRD OR wheels for now. If we don't break anything installing everything after work Friday night, I'll post some pics Saturday night here of it all together. I'll also make a "build thread" so I can be cool like everyone else detailing everything I've done so far. I took a very basic approach to building my truck... so far...
    Nevin likes this.
  2. Nov 2, 2021 at 6:00 AM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    If you're going to be putting on SPC UCAs, you might have to go with wheel spacers to clear the control arm. Not sure if the stock UCA is small enough to clear.
    It's a big maybe because I had the alignment shop set 2.4° caster on mine and ended up about middle of the road on all LCA adjustment cams, near center on the SPC camber slot and at position D on the ball joint and had to go with 1.25" Spidertrax to clear. There might have been enough adjustment to swap to position E/F/G and tweak everything else to max, but pushing everything to get that extra 1.25" from the adjustments would've been a stretch.
  3. Nov 2, 2021 at 6:02 AM
    TheColoradoAthlete
    Colorado, USA
    2020 DCSB TRD OR
    Interesting. I went Dobinsons for everything because of a discount, so we will see
  4. Nov 2, 2021 at 6:04 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You're in the 1st Gen section; different options exist for these trucks vs your 2020.
  5. Nov 2, 2021 at 6:07 AM
    TheColoradoAthlete
    Colorado, USA
    2020 DCSB TRD OR
    Whoops, sorry fellas. Wish I had a 1st gen, I think they look so good. Have a good one
