YotaShop Engine Rebuild Install
Discussion in '1st Gen. Tacomas (1995-2004)' started by 96tacomasr5, Jun 18, 2013.
  1. Jul 3, 2013 at 6:57 AM
    #41
    BamaToy1997
    Bill
    Navarre, FL
    Yeah, I have been working on cars/trucks since I was a little one. My stepfather started me off and taught me the basic skills needed: Patience and openmindedness. After that I just started tinkering with stuff. I was replacing universal joints at 12 and went from there. When I got my first car I was just thinking "What can I do to this thing to make it do better" and went from there. I bought books and books and books....you know, those things we used before the internet. I would spend countless hours reading and looking at the car... Eventually I knew every piece and particle. I fell in love with working on things back then. It was a no-brainer when I enlisted what I was going to do. I scored so high on my ASVAB that they were wanting to send me to intel school! You should have seen the look on the recruiters face when I told him I was either going to be a tank mechanic, or I was not going to sign!
  2. Jan 4, 2014 at 6:14 PM
    #42
    Doc McCoy
    Doc McCoy Untitled Offroad
    Calgary, Ab
    '98 TRD
    TRD Supercharger, TRD Headers, Borla Exhaust Custom Front & Rear Bumper, Allpro Sliders IVD Extended Front Coilovers, Total Chaos UCAs, TC Spindles, Alcan Rear Leafs, IVD Omega Rear Shocks Regeared to 4.88s, Front ARB Airlocker, Manual Hub conversion Also Mastercraft seats and sick cue ball shifters :D
    Hows the engine holding up?
  3. Feb 24, 2014 at 8:15 PM
    #43
    96tacomasr5
    96tacomasr5 [OP] Active Member
    Roy
    AZ
    96 SR5 4x4
    Hey Doc….. I have put little over 5,000 mils on the engine. Shortly after I installed the engine I drove to Texas. I drove in overdrive. My highway speed between 65 to 85. My RPM between 2000 and 2900. Average 17.6 MPG… With a loaded truck..
    I was going to pull a compression test when I got back home… But the engine is running as good as the day I drove it off the show-room floor back in 1996. One day I may still pull a compression test. It would be good to know..
    All I can say….with my experience with YotaShop’ s craftsmanship …… if YotaShop rebuilds aToyota engine you need……..
    It would serve you very well to look no further….
    5 Stars in all categories
    I would defently recommend YotaShop…:thumbsup: :cheers:
  4. Feb 25, 2014 at 4:02 PM
    #44
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    If you don't mind me asking how much did that rebuilt engine set you back? I was considering a reman for my 04 taco 4x4 that i bought with a bad engine but i found a complete 3.4 from a rolled over 2003 prerunner with only 69k miles on ebay from a salvage yard in Arizona for $1400 including the shipping. I got it together and just tagged it about a month ago and it's funny because i'm also planning it's 1st roadtrip to Texas.
    #44
  5. Feb 26, 2014 at 10:49 AM
    #45
    96tacomasr5
    Roy
    AZ
    96 SR5 4x4
    The cost was $3000 + $300 core charge. I kept the core because it was going to cost me another $200 to ship it back.
    It sounds like you have a very good deal. Toyota builds a strong solid engine and with good maintenance, 69 thousand miles is nothing… for that engine…
    I chose not to go that route. I’m allergic to using certain salvage parts and engines was one.
    Note…. just in case:
    Removing the engine on my 96, I had to secure the starter to the block after removing the starter bolts. also I secured the started to the block when installing the motor. I used bailing wire. This may not be necessary on your 04??
    Good luck…
    #45
  6. Feb 26, 2014 at 1:18 PM
    #46
    WThomas1250
    WThomas1250 Well-Known Member
    Extremely off-topic question: I was looking at the first page pics and I realized that isn't a bug shield on the front. Is that Plasti-Dip? It looks really good
  7. Feb 26, 2014 at 1:31 PM
    #47
    68dave
    Dave
    Thanks Roy $3000 that's a good price for a remanned long block. So far my used engine has been performing very good. I couldn't believe how new the engine from Az looked compared to mine, you west coast guys don't know how good you got it.
  8. Feb 27, 2014 at 10:02 PM
    #48
    96tacomasr5
    Roy
    AZ
    96 SR5 4x4
    No.. I used Rust-Oleum truck bed coating. I had a lot of rock chips in that area. I did not want to paint the hood so I used the black truck bed coating to cover those chips in the paint. I carried the paint around the head lamps because it looked better…….Turned out nice.
    You can still see where the chipped area are, but it still looks good…
    Down side.. the finish is rough so have to be careful with polish.
  9. Feb 27, 2014 at 10:28 PM
    #49
    96tacomasr5
    Roy
    AZ
    96 SR5 4x4
    I thought so too.
    Before I found YotaShop I was looking at 5 thousand plus shipping from other rebuilders. It was going to cost me around 4 thousand for a machine shop to rebore my block and resurface the heads with all parts necessary to build and assemble it myself.
    I was very skeptical when I found a long block for 3 thousand completely assembled. I could not find any consumer or customer reviews on YouaShop. Thats why I posted my results here.
    I am very satisfied with their performance…and the results….
    I convinced myself to use YotaShop because I did not trust myself to use the TTY head bolt torque procedure…
    Sounds crazy hu….. But dat da truth. I sure as hell glad I took the leap because that was the slickest install I ever did.
    A simple bip-bam- thank ya mam…:)
  10. Aug 22, 2014 at 10:18 PM
    #50
    famtoy
    famtoy New Member
    Joe
    San Diego, CA
    '01 Tacoma
    Hi, Roy. I just ordered a 5vz from Yotashop. I was wondering how your engine is doing and if you have any install tips. I hope that engine is doing great and you have plenty of trouble-free miles ahead of you. I'm new to this site and am very appreciative to all for the info i've been able to get from all the posts.
  11. Aug 24, 2014 at 2:46 AM
    #51
    wkndboost
    wkndboost Active Member
    Good stuff, I'm getting the same mpg with nothing but me. I think it's time for a good tune up
  12. Oct 8, 2015 at 9:09 PM
    #52
    JakeInGrayTacoma
    JakeInGrayTacoma Active Member
    Jake
    SoCal Mtns
    95 4x4 gray tacoma
    Get back up to snuff cuz it wasn't maintained. I got xm radio in it.
    So did you get a new engine from YotaShop? I need a new one and have begun looking for one...
  13. Jan 30, 2016 at 6:07 PM
    #53
    life as ben
    life as ben Well-Known Member
    Thinking about ordering one from YotaShop, 96tacomasr5 got any updates?
  14. Mar 9, 2016 at 10:37 AM
    #54
    Bugzzy2002
    Bugzzy2002 New Member
    Michael
    2002 tacoma prerunner
    Struts
    How did your Yotashop motor turn out? I'm talking to them now on a 3rz motor.
    Stout890 likes this.
  15. Apr 28, 2016 at 11:37 PM
    #55
    Colin_M
    Colin_M New Member
    Colin
    Toyota 4 Runner
    TRD Super Charger
    Hi - I have a 2000 Toyota 4Runner Supercharged and I was thinking of getting the Dressed Long Block from YotaShop - could you give my our long-term review.
    Thanks in advance.
    Colin
  16. Dec 29, 2017 at 1:10 AM
    #56
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    I'm looking at a 3rz from them now and their core charge for the 4cylinder is 600$!!! That's double the price for your 6cyl for half the engine what gives?
  17. Jan 2, 2018 at 2:51 AM
    #57
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    For some reason the 4 cylinders are priced higher than the 6 cylinders. Probably because more trucks came with the 5VZ.
