Your unique mod on the 1st Gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by Desiel, Oct 14, 2010.
  1. Nov 28, 2016 at 12:30 PM
    #521
    cynicalrider
    cynicalrider #NFG
    Jersey
    Latest:
    Skid plate illumination with weatherproof switch:
    Tool box switches that control bed lights, lights on tool box, and tool box lights:
  2. Nov 28, 2016 at 5:47 PM
    #522
    1997tacomav6
    Denver
    Sure, there are a few people on eBay selling the complete kit with wires and sensor and etc.
    The gentex 177 mirror is a GM mirror, IT IS auto dimming so the lights in the rear mirror automatically
    dim the mirror, you also have a compass and a temperature indicator.
    The hardest part is fishing the wires through the front of the head linier one at a time and then fishing them all through the headlinier to the right side pillar. You need to remove the PLACTIC side pillar and run the wires for power and the wires for the temp sensor that you will attach to the very front of the truck by the horn. 2 wires run to this sensor, the other 2 wires run under the glove box area( remove the glove box) and find a ground by the glove box frame and hot wire to the cigarette light so that when the key is off the power to the mirror is off also. The mirror will drain the battery if you connect to a hot wire that is not controlled by the ingintion. My cigarette lighter does not work when the ingintion key is off. The mirror is larger than the original mirror and does hit the visitor on the drivers side when you flip it all the way down. But it's not a big deal
    I REPLACED THE 177 MODEL WITH THE 453 MODEL
    ITS MUCH BETTER
    https://www.tacomaworld.com/threads...mp-compass-auto-dimming.553041/#post-17999152
  3. Nov 29, 2016 at 1:34 AM
    #523
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    How did you mount the mirror itself to the headliner? I have the mirror that has the map lights, like this:
    So to clarify: Two wires (pos/neg for Thermostat) run to the engine compartment for the temperature probe, and two (pos/neg +-12v) runs to a power source. Is that correct?
    I want to get one of the mirrors with a thermostat and HomeLink so I can ditch the garage opener.
  4. Nov 29, 2016 at 5:58 AM
    #524
    1997tacomav6
    Denver
    Yes that's correct, I removed the metal mirror support from the lamp housing that holds
    the Toyota mirror and attached the gentex to the windshield with the glass tab.
    I wanted the homelink also but the problem for the 1st gen Tacoma is there is little room
    and this gentex is about as large(wide) a mirror you can install because if it's any bigger the sun visors
    on both side will hit the mirror when you drop them down. With the gentex depending how you
    center it on the glass one visor will hit the mirror. Also you need to cut in the plastic wire tab cover that covers the wires from the mirror to THE headlinier along the windshield.
    callmeammo likes this.
  5. Nov 30, 2016 at 1:57 PM
    #525
    mikeymike2189
    mikeymike2189 Well-Known Member
    SO....has anyone or does anyone know if a deck rail kit off a 2nd or 3rd gen tacoma will fit a 1st gen?
  6. Nov 30, 2016 at 3:06 PM
    #526
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    What do you mean by deck rail kit? The tracks the around the bed?
  7. Nov 30, 2016 at 4:07 PM
    #527
    mikeymike2189
    YES, i came across a set and wodmered if anyone has tried to mount them or not?
  8. Nov 30, 2016 at 4:15 PM
    #528
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    I remember seeing someone who did it. Can't remember who though. Shouldn't be hard.
  9. Nov 30, 2016 at 4:22 PM
    #529
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    land cruiser style brush bars are unique for a tacoma i guess :)
  10. Nov 30, 2016 at 4:46 PM
    #530
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    I have them installed, so nice.
  11. Nov 30, 2016 at 4:47 PM
    #531
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    I bought a homelink designed for a visor and installed it in my headliner. Connected it to my map lights for power.
  12. Nov 30, 2016 at 7:22 PM
    #532
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Got pics of it? How difficult was the installation? I assume it ain't too hard.
    Chipskip[QUOTED] likes this.
  13. Nov 30, 2016 at 7:26 PM
    #533
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    DustStorm4x4[QUOTED] likes this.
  14. Nov 30, 2016 at 8:25 PM
    #534
    BartMaster1234
    Tyler
    Flux Capacitor
    I loved the deck rails the moment I realized they existed. They cost an arm and a leg to buy genuine or aftermarket ones. I found a couple of solutions:
    You can use a product called "Unistrut" which is commonly used in the construction field for mounting or framing various equipment to walls like conduit, plumbing, utility boxes, junction boxes, wall supports, etc. It's basically an extruded "U" shaped track. They sell nuts that fit inside that have a 3/8 (or something like that) threaded hole so you can screw in an eye bolt or whatever you want. It's the closest thing to a factory Toyota bed rail. It's also incredibly cheap, with it costing like $15 for 10 feet.
    You can also use aircraft seat rails. Boeing, Lockheed Airbus, etc. use it to mount chairs and equipment to the fuselage on commercial airliners, and they're also commonly used for strapping down cargo and offering tie-down points. This is much much more pricey that Unistrut, but provide a cleaner and functional system. A user on here (can't remember their name) put down this type of rail in their 1st gen.
    EDIT: I'll be damned, it even looks like genuine Toyota OEM bed rail accessories will fit into the Unistrut. I was over on the 2nd gen forums and people use the Unistrut bolt and nut in their Toyota rail system, so it looks like accessories are interchangeable.
    Unistrut is the closest thing to the 2nd/3rd gen factory bed rails and you'll save a lot of $$$.
  15. Dec 1, 2016 at 7:34 AM
    #535
    mikeymike2189
    THAT IS ABSOLUTELY AWESOME!! THANK YOU SO MUCH, will be doing this in the immediate future!!
  16. Dec 1, 2016 at 8:16 AM
    #536
    BartMaster1234
    Tyler
    Flux Capacitor
    No prob! Make sure to post pics if you do it. I have to do it myself in the future.
  17. Dec 1, 2016 at 8:55 AM
    #537
    AZ4x4Taco
    AZ4x4Taco Well-Known Member
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Cheap spacers and blocks, 33's, poor man upgrades.
    I use the tiedown fitting with the quick disconnect(pucks we call them). nice to put them where you want rather then the whole rail, but preference is different. added 4 per bedrail(had to drill, oh well) works well. their use at work is extension and they are strong and light aluminum so if you find a deal would be worth it. if its expensive, let me know, might find some in the "trash" at work...
  18. Dec 1, 2016 at 9:06 AM
    #538
    BartMaster1234
    Tyler
    Flux Capacitor
    Do you have any pics? I'm a little confused on what you mean.
  19. Dec 1, 2016 at 9:28 AM
    #539
    AZ4x4Taco
    Jeremy
    Tucson AZ
    01 4x4 TRD
    This was my mini mod
    bowyer2002 likes this.
  20. Dec 1, 2016 at 10:55 AM
    #540
    BartMaster1234
    Tyler
    Flux Capacitor
    Ohhh I see, you drilled directly into the bed rail. What I like about the Unistrut is that it's adjustable and expandable.
