Zero point calibrate your VSC?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Haws, Aug 8, 2013.
  1. Aug 8, 2013 at 4:00 PM
    Haws
    Haws [OP] Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
  2. Aug 8, 2013 at 4:27 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
  3. Aug 8, 2013 at 5:02 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    It's not difficult to accomplish. I did not check all the links. When I did mine, I had the page from the service manual and used two paper clips. Took about 1 minute.
    PK
  4. Dec 17, 2013 at 11:49 AM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    And did it solve your issues??
