Zero Tolerance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clincher16, Oct 2, 2009.
  1. Oct 2, 2009 at 1:24 PM
    clincher16
    clincher16 [OP] New Member
    dave
    chicago, Il.
    2008 sr5 4cyl auto
    Does my 2008 2.7 - 4 cyl. have one of those 0 tolerance engines where you screw up the head if the timing belt breaks ?:confused:
  2. Oct 2, 2009 at 1:36 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    The 2.7 has a chain. I believe you are talking about an interference engine like Honda. If the belt breaks the valves hit the pistons causing big damage. Honda's newer 4 cylinders have switched to chain drive.
  3. Oct 2, 2009 at 1:37 PM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Bump for you....only because you are from my home town....:):D
    BTW...Welcome to TW!!
  4. Oct 2, 2009 at 1:38 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
  5. Oct 2, 2009 at 3:36 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    If the timing belt/chain breaks on ANY engine while it's running, you're done. If it skips a tooth... maybe not full damage. I'm not sure what the 2.7L would do if it skipped one tooth.
  6. Oct 2, 2009 at 3:42 PM
    NAAC3TACO
    Sparks, NV
    2014 SR5 DCLB 4x4
  7. Oct 2, 2009 at 3:54 PM
    TacoMOnster07
    TacoMOnster07 Well-Known Member
    Pennsylvania
    07 DC 6speed 4x4 BSP Sr5
    BHLM, Grillcraft, Urd SS, Urd TCAI, Urd MAF Calibrator, AeroTurbine Exhaust, TacoTune Single Din, Two 8" Infinity Subs, 12-13000 HID's, Xtreme Bedrack light bar with two KC 4 by 6 lights.
    Toyota does not make any interference engines I believe. If our cam chains break they would not cause any damage whatsoever. We can spin our crankshaft without worrying about pistons at TDC (Top Dead Center) hitting an open valve.
  8. Oct 2, 2009 at 3:57 PM
    TacoMOnster07
    Pennsylvania
    This makes it very easy to work on and change belts on non interferance engines. When I change a timing belt or chain on an interference engine I probably mark 10 more spots on the pully/belt/casing/housing to make sure nothing goes wrong. If there is slack in the wrong spot it can cause a skipped tooth and that's an expensive repair if you crank engine without checking and pistons and valves collide.
  9. Oct 2, 2009 at 4:03 PM
    TacoMOnster07
    Pennsylvania
    I do correct my self that if A chain breaks like we have that might do some damage, not to the pistons or valves but to whatever parts the chain may hit. I don't worry much about our cam chains, I like them more then belts.
  10. Oct 2, 2009 at 4:40 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    That is most definitely NOT true. Only "interference" engines will result in engine damage from a broken T-belt or chain. ;)
    The 2.7L Toyota engine is not an interference engine, so rest assured that your engine will not be damaged in the event of a timing chain failure. T-chains rarely break, although they are known to become derailed or skip a tooth. This is most often caused by broken guides and or tensioners. The chain might last 'forever,' but the guides and tensioner often do not.
