Cooks 2000 4x4 build with some BS
Discussion in '1st Gen. Builds (1995-2004)' started by BYJOSHCOOK, Jun 19, 2014.
  1. Jun 19, 2014 at 7:49 PM
    BYJOSHCOOK
    BYJOSHCOOK [OP] Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Since I finally had enough mods on the truck I thought I'd start a build.
    If you have any questions don't hesitate to ask :cheers:
    Currently with 188k
    Currently with 167k
    Currently with~159k
    The earliest pic I have of when I bought it
    Truck is no longer a DD! Currently driving a 1991 Toyota Supra, follow that build too if ya want. Goal for this truck now is purely an offroading rig and will get little pavement time except going to trails.
    Here's some specs:
    2000 Tacoma TRD 4x4 V6 5-speed
    I bought it July of 2013 with ~128k miles from a member on here for a pretty good deal, nothing wrong with it except some bald tires and some surface frame rust.
    Videos:
    First wheeling video!
    https://www.youtube.com/watch?v=2zBReuC3vIQ&list=UUswQCLWkCcsrbMb1u1UkPAw
    https://www.youtube.com/watch?v=C3QpdVMmz7c&feature=youtu.be
    https://www.youtube.com/watch?v=FnXyMFLPFdI
    https://www.youtube.com/watch?v=fzzoKRDFpNE
    Links to Certain Spots:
    Sliders Install
    Skid Install
    RTT Install
    Bumper Install
    Prinsu Rack Install
    U-Bolt Flip Install
    TC UCAs Install
    Kings Install
    Tundra Upgrade
    Snorkel Install
    Winch Install
    Others are probably on the first page
    Current Mods:
    Suspension:
    First:
    Front: Bilsteins 5100s
    Eibach/Toytec coils
    Rear: Mid-West Territories Leaf Pack
    Second:
    Front: Kings 650# Extended Travel coilovers (installed 2/4/17)
    Plastics Guy Bumpstops (installed 8/4/18)
    Rear: OME Nitrochargers (installed 12/03/16)
    OME Greasable shackles (installed 12/23/16)
    OME Leaf Springs (installed 12/23/16)
    Toytec Diff Drop
    Sway-Bar removed
    All-Pro U-Bolt Flip kit (installed 5/28/16)
    Timbren Rear Bump Stops (installed 5/28/16)
    All-Pro CB drop kit (installed 12/23/15)
    Total Chaos UCA's (installed 10/15/16)
    Total Chaos UCA Gussets (installed 9/12/18 :welder:)
    Mechanical/Electrical:
    Magnaflow Catback Exhaust
    Relocated Rear Diff Breather
    Grey Wire Mod
    URD Short Shift Kit
    BAMF BPV Bracket (installed 5/28/16)
    sPod Fusebox (installed 2/23/18)
    BamaTacos Big 3 Electrical Upgrade (installed 12/23/15)
    Stock Intake (installed 4/7/17)
    Snorkel (installed 4/21/17)
    CS144 Alternator (installed 1/19/19)
    Champion Radiator (installed 4/7/19)
    Lighting:
    Retrofit H1 Mini
    Blacked out Gatling Gun shroud with Halos behind
    Relocated blinkers to side marker
    Cali-LED Sidemarking Ditch lights (installed 2/24/18)
    Rock Lights (installed 3/20/18)
    Amber Cali-LED Foglights (installed 1/25/19)
    22" Single Row Lightbar (installed 2/25/18)
    Ebay tail lights - (installed 3/6/21)
    Interior:
    JVC head-unit
    JVC speakers
    Sub-woofer
    Viper alarm system
    Mag Lite
    Ultra Gauge
    OTRATTW Blue Switches (installed 2/24/18)
    Custom Wet Okles (installed 12/15/17)
    01-04 Weather Techs (installed 12/10/17)
    Wheels and Tires:
    First: Weld Scorpio 15x8
    Tires: BFG A/T 32x10.5r15
    Second: Pro-Comp 7069 16x8
    Tires: Goodyear Wrangler Duratrac 265/75r16
    Third: SCS Gunmetal SR8 16x8 (installed 6/30/17)
    Tires: Cooper ST Pros 285/75r16 (installed 6/30/17)
    Matching full size spare (waiting for rear bumper)
    Tundra Brakes
    Coms:
    Firestik Antenna
    BAMF antenna mount
    Cobra CB with Uniden speaker
    PA Microphone
    Small Ham Radio
    Recovery:
    Hi-Lift Jack
    Wheeling bag full of rope, come along, hatchet
    RotoPax 2 Gallon Gas and Water
    TREDs
    Small Fire-extinguisher
    Warn VR8000-S (installed 8/28/17)
    Exterior:
    Custom Satoshi grille with Landcruiser Toyota and TRD emblems
    Tepui Ayer RTT
    Bashfab Bedrack
    Redline Hood Struts (installed 4/21/17)
    Toolbox
    Prinsu CabRac (installed 3/4/16)
    Tepui 6ft Awning
    46" Plano Case
    Color Matched Leer Camper Shell
    OBA (waiting to be installed)
    Yakima Tracks (installed 1/21/18)
    Prinsu TopRac (installed 2/2/18)
    Rago Bed Stiffeners (installed 3/6/21)
    Armor:
    4X Innovations Sliders DOM ( :welder:Welded May 17, 2015)
    RAT IFS Skid Plate
    BruteForce Hybrid Front
    BAMF LCA Skids (installed 12/22/15)
    RAT Gas Tank Skid (waiting to be installed)
    My future mods: :drevil:
    Armor:
    Bashfab Rear Swingout
    Custom Belly Skid (materials ordered)
    Relentless Tailgate reinforcement
    Interior:
    01-04 Center Console
    Exterior:
    Lightbar
    Flush Backup Lights
    Engine Bay Lights
    Fix Bedrack
    Redo Retrofit
    Recovery:
    CO2 10# tank
    Snatch-block
    Mechanical:
    Frame Reinforcement Plates
    Boxed Frame
    4.88 Gears
    Power steering cooler and filter
    Suspension:
    Relocated Rear King Shocks
    Long Travel (ways down the road)
    Longshots:
    Crawl-Box
    Tundra Axle
    Super Charger
    Air Lockers
    Maintenance Needed:
    Body Mounts - Amazon
    Valve Cover Gasket - from Gunny (https://www.tacomaworld.com/threads...ping-out-valve-cover-gaskets-pictures.469596/)
    #70 Spring - from ACE
    33403-39415 - Cobb Toyota
    19944-62010 - Cobb Toyota
    Get rid of dents
    Clean IAC/Throttle body
    Bando belts
    12204-62010 - Cobb Toyota
    90480-18001 - Cobb Toyota
    12261-62041 - Cobb Toyota
    Spark Plug clips
    19941-65040
    90464-00542 x 2
    90469-05012
    90464-00556
    90464-00561
    90929-01348
    Maintenance Done:
    Diff/Tranny Flush: (12/20/15)
    Driver Axle Seal/Bearing: 161k (9/24/16)
    New UCA's and LBJs: 161k (10/17/16)
    Oil Change/Tires Rotated: 161.7k (10/28/16)
    Rear suspension: 163.7k (12/23/16)
    Front suspension and outer tie-rod (2/4/17)
    Spark Plugs and wires 166k (4/8/17)
    Oil and Tire rotation: 168.3k (5/30/17)
    Cleaned window switch and new tire: 168.4k (6/2/17)
    Rims and Tires: 169.2k (6/30/17)
    Oil Change: 174k (1/6/18)
    Passenger side rear oil seal and tires rotated: 176k (3/3/18)
    Oil Change: 181k (5/4/18)
    New u-joints, brake pads, calipers and flush: 182k (6/23/18)
    OEM steering rack and flush: 183k (9/25/18)
    New LBJ bolts: 183k (9/24/18)
    CS144 Alternator: 185k (1/19/19)
    Champion Radiator: 186k (4/7/19)
    Idler Pulley: 186k (4/13/19)
    Oil Change: 187k (8/01/19)
    Slave Cylinder Flush: 188k (12/16/19)
    Starter Rebuild: 188k (12/16/19
    Front diff fluid flush and new driver oil seal: 188k (12/23/19)
    Aisin Clutch/Luk flywheel, shifter bushings, fluid flush, output shaft seal, rear main seal, fan clutch bracket: 188k (1/14/20)
    Tires rotated, UCAs greased: 191k (9/7/20)
    Oil Change: 193k (4/2/21)
    Timing Belt, WP new AC bearing: 195k (11/15/21)
    Trails Hit:
    -Hawk Mountain
    -Trey Mountain
    -Bell Mountain
    -Charlie's Creek
    -Gulches ORV Park
    -Beasley Knob OHV
    -Sheeps Wallow
    -Nimble Will Gap
    -Flatlands
    -Adventure Off-Road Park
    -Choccolocco Park
    -Cashes Valley
    -Windrock
    Helpful Links:
    http://www.toyodiy.com/parts/
    http://japan-parts.eu/toyota/us VZN170L-CRMDKAB
    https://www.tacomaworld.com/threads/first-gen-bulb-types-fyi.128857/
    https://www.tacomaworld.com/threads...-plus-bs-thread.333480/page-121#post-15483082
    https://www.tacomaworld.com/threads/hbtaco-build.298424/
    https://www.tacomaworld.com/threads/champion-radiator-aluminum-3-core-swap-3-4-supercharger.543859/
    https://yodateq.com/collections/grills/products/ssg2-teq
    http://gps.motionx.com/maps/6ec1cfd844dd92352739b95e710596e4
    https://www.tacomaworld.com/threads/gear-roundup-what-i-take-with-me-on-trips.594546/
    https://toyota.service-solutions.com/en-US/Pages/home.aspx
    https://www.toyodiy.com/
    Trails:
    https://www.trailsoffroad.com/states/GA
    Toyota 4Runner:
    https://www.offroadsolutions.com/tech-info/category/installation-documents/page/4/
  2. Jun 19, 2014 at 7:55 PM
    Madjik_Man
    Colorado Front Range
    :wave:
    First reply and with it, I'd like to say... nice truck.
    Love the tasteful build so far.
  3. Jun 19, 2014 at 7:56 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    First official mod TRD emblem, gotta love Amazon
    Sold the camper, kinda wish I hadn't but I need new tires
    It was raining so my bulldog need some shelter
    Did some small flexing in the back of my neighborhood haha
    Then I found a nice short trail on the other side of my neighbor hood
    Georgia got some snow which was weird but hey I got some TITS :D
    Went on my first wheeling trip! Meet some great guys from TW there, had lots of fun
    Here's some of the guys, Cam (ChamYota), Zac (Xaqori), Israel and Tyler (Gabassman)
    Chris (Iceman2448) and Greg (Meatman) came later but I didn't snag a pic
    And this is what happens when you bring an Isuzu Trooper to a Tacoma meet :rofl:
    Cleaned up the truck and the sunset looked awesome so I snapped a pic
    Finally got warm enough to paint some stuff, so I bought some 2nd ten emblems (they look so much better than 1st gen)
    Finally had enough cash to get my new rims and tires! :woot: :goingcrazy: Pro-Comp 7069 with Wrangler Duratrac 265's
    Now that I had that out of the way, I needed to get rid of that stupid spacer lift that the PO had put on….. :rolleyes:
    Got some billie 5100s and toytec coils from a member for a pretty good deal, brand new too!
    Damn things are beefy as hell!!
    From my first wheeling trip I figured out I needed some stuff, like better tires, cb radio and better suspension
    It was a great month of modding for me :D
    Here is my CB and antenna setup (you can sort of see my 2nd gen emblem setup here) and my TW sticker :thumbsup:
    It's an honor ha, thanks man. It's slow but I'm doing everything right the first time :D
  4. Jun 23, 2014 at 8:38 PM
    Iceman2448
    Iceman2448 Well-Known Member
    Ga
    5100 OME 3" front lift 1.5 rear All Injen cold air Intake N-Fab light bar Hella 500FF lights Alpine Heand unit Type R 10 sub r500.1 amp Alpine 6x8 comps up front Alpine 6x9 in rear
    Yes sir, I'd say so myself!!! We sat and talked truck for two days so I can say, I hope you take so of my advise brother!!! Btw like the av pic!! Truck has a changed a lot nice I first saw it.
  5. Jun 23, 2014 at 8:43 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Ha thanks man! Yea I sure will! Ha I knew you would, it looks better there so it's not as blurry! Yea hopefuly it'll change a bit more
    And so began the suspension!
    Coils and struts put together, looks so sick with the matching silver like they were made for each other
    All mounted up, aint it beautiful?
    Stupid HID kit kept going out on me so I said f#$k it and jumped on the TRS group buy.
    Awesome company with great customer service!
    Zombie truck.
    Getting em all mounted up, damn things are bright as hell!
    Just my halos on, shitty iPhone pics don't do these justice!
    Again shitty cell pics, I need a real camera haha
    Went on another TW meet! This one was a lot more fun because I knew what to do and had the right equipment this time :rolleyes:
    Stare down with Zacs truck (Xaqori)
    The only group shot I snagged the whole weekend, Chris (Iceman2448), Kevin, and Tyler (Gabassman) (the few of the guys I can remember)
    Pic courtesy of Chris (Iceman2448) wished my halos were on :(
    And then Isreal did this :facepalm: same guy with the Isuzu Trooper
    #TacomaWorld
  6. Jun 24, 2014 at 4:37 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Went camping this past weekend up at Tray Mountain.
    Didn't see too many people up there but it was a good time
    Sitting in the field
    Headed down the mountain in the rock garden
    And our setup
  7. Jul 2, 2014 at 10:35 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Haven't done anything recently, saving up for some sliders.
    But my air unit has been making a funny sound (and blows out dust a little) since my last camping trip. I think some dirt got in there some how. It looks (from the maintenance book) that its a lot of work just to get to the blower unit. So I haven't checked it yet
  8. Jul 7, 2014 at 6:19 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Hit a trail today with some friends on 4 wheelers, snagged a couple of pics
    Small flexing
    Bit more flexing, most I've ever done haha
    Stuffed
    seniorredwood likes this.
  9. Jul 7, 2014 at 9:34 PM
    cmj
    cmj Well-Known Member
    Oregon
    98 Tacoma 4x4
    Nice truck! I like your grill.. do you have any pics of the process?
  10. Jul 8, 2014 at 9:17 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Thanks! The previous owner must have done it because I bought the truck with it
  11. Jul 10, 2014 at 3:05 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Hey thanks for posting the antenna mount pic. Would you happen to have any pics of the install that was done. Thanks again. :cool:
  12. Jul 10, 2014 at 3:52 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    No problem! The antenna or the cb? I can go grab some more pics if you want
  13. Jul 10, 2014 at 3:56 PM
    quetzal
    Mario
    Long Beach, CA
    The antenna would be perfect. Their website doesn't have a good shot of it. I'd like to see it w/the tailgate open. Also, how are you running your coaxial cable to the antenna? As for the cb, I have a general idea how to mount it. Thank man, much appreciated.
  14. Jul 10, 2014 at 5:12 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    There is a grommet in the storage compartment behind the driver, I just slit that open and shoved the wire through then up my taillight
  15. Jul 10, 2014 at 5:28 PM
    quetzal
    Mario
    Long Beach, CA
    Cool man, did you have to drill new holes or use the existing holesfor the mount? It looks like you're using the stock holes foe the latch. Is that correct? Thanks for the info and pics, greatly appreciate it.
  16. Jul 10, 2014 at 5:38 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Yea there was no drilling at all (except to keep the antenna from grounding out, we made the antenna hole bigger and threw in a rubber washer) BAMF makes a great product for this. Just have to paint it and that's it
  17. Jul 10, 2014 at 6:00 PM
    quetzal
    Mario
    Long Beach, CA
    Cool thanks, I'll be using a ngp antenna so I won't need to ground it. :cool:
  18. Jul 10, 2014 at 6:04 PM
    quetzal
    Mario
    Long Beach, CA
    By the way, sweet build and I spy a 4Runner :D :cool:
  19. Jul 10, 2014 at 6:06 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Oh even better!
    Ha thanks! Thats what I used to drive until a mechanic said I had 2 months till the thing died. So I started to look for Tacomas. A year and half later damn thing is running better than before! :D
  20. Jul 11, 2014 at 9:54 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Anybody got any good mounting spots for this?
