2004 Tacoma - Gear Shifter Console Won't Light Up
Discussion in '1st Gen. Tacomas (1995-2004)' started by DoubleTaco2004, Jul 2, 2014.
  1. Jul 2, 2014 at 1:34 PM
    DoubleTaco2004
    DoubleTaco2004 [OP] Member
    Kenneth
    Wilmette
    04 Black Beauty
    Does anyone have the drawing that shows how to remove the console in order to replace the light bulb that illuminates the gear letters on the console? For the shifter, the P (Park), R (Reverse)...etc.
    It won't light up. I appreciate it. Written instructions or a drawing from the manual would be great if anyone has those handy.
    Thanks.
  2. Jul 2, 2014 at 1:44 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    Fixed it for you :D
  3. Jul 2, 2014 at 2:04 PM
    DoubleTaco2004
    Kenneth
    Wilmette
    04 Black Beauty
    Taco302 - I'm not sure what you mean. You fixed what for me?
  4. Jul 2, 2014 at 2:12 PM
    Madjik_Man
    Colorado Front Range
    He's being a smartass by saying you should get a 5-speed.
    As for replacing the bulb, I'd imagine it's the same steps to remove the console as it is for my 5-speed.
    Unscrew the shifter knob.
    There are two screws at the front of the trim piece around your shifter and two screws at the rear. Lift up and forward at the same time. Underneath there you should be able to figure out how to change the bulb.
    Honestly, I've never seen under an automatic so I have no idea.
  5. Jul 2, 2014 at 2:13 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    My dads 2004 has the same problem lol. Maybe someone can help.
  6. Jul 2, 2014 at 2:28 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Wow!
    It has a light?
  7. Jul 2, 2014 at 3:25 PM
    Shabutie
    Shabutie Well-Known Member
    Zach
    Fort Stewart
    2002 Toyota Tacoma Limited 4WD 4dr
    Mines out too
  8. Jul 2, 2014 at 3:45 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC King Ranch Edition
    Me three. I'd like to know how
  9. Jul 2, 2014 at 4:05 PM
    synergy10
    synergy10 @synergy10.sd
    San Diego
    I haven't tried this yet but it might work (post #2 by Fuzzyman81):
    http://www.tacomaworld.com/forum/1st-gen-tacomas/118867-light-bulb-replacement-shift-console.html
    I'm not sure if you can remove the plastic trim around the gear shift lever without removing the cup holders and armrest? If you do need to remove the cup holders and armrest, follow the link below (I did this when I replaced my cup holder tabs):
    http://www.tacomaworld.com/forum/1st-gen-tacomas/159279-02-04-cup-holder-tab-replacement.html
  10. Jul 2, 2014 at 5:39 PM
    camptaco01
    camptaco01 Well-Known Member
    Eric
    Tempe,AZ
    2004 TRD Double Cab 4x4
    You can remove the shifter console without taking the cup holder/center console out. First take off the shifter knob, if you have 4wd.DSC01703_e60c3ff491f52ac78cce6d1e96da640a93ec003c.jpg Then undo the 4screws, 2 on each side.DSC01704_6de02ccb1d237be3ca944697f8c58d08111570d7.jpg
    Lift up from the bottom of the console and pull the back end out.DSC01705_aa3ab00bb10f0affa111c4715c4eef5279552598.jpg
    Then you can remove the console.DSC01706_6b3324b0ffda57ec384954bc492f1a477746b5fd.jpg
    You should see the bulb, just twist it out.DSC01707_e51e1900bf79fc07cce67d8bc4a695aa84d3b2d4.jpg
    unstpible likes this.
  11. Jul 3, 2014 at 12:07 AM
    synergy10
    San Diego
    camptaco01 - thanks for clearing that up!
  12. Jul 3, 2014 at 7:08 AM
    TacomaTRD4x402
    TacomaTRD4x402 Well-Known Member
    So Cal
    '02 Tacoma TRD 4WD 3.4 5spd S/C Long Travel
    Hey since we're on this subject... I have a 5spd and have my center console removed. So I just got the plastic attached below the shift knob. Anyways, after mytruck runs for a good while I got hot air coming into the cab from the gap right below the shifter. I'm thinking I must be missing some sorta boot or kind of insulation pieceto keep the air coming in. Can anyone snap some pics of ur manny shifter dissected like what camptaco did? So I can compare. Thanks!
  13. Jul 3, 2014 at 7:18 AM
    Madjik_Man
    It'd be easier to take a pic of your set up to see if you're missing anything.
    You should have rubber boots under the fake leather shifter boots.
    Like these guys:
  14. Jul 3, 2014 at 1:41 PM
    TacomaTRD4x402
    So Cal
  15. Jul 3, 2014 at 9:31 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    There should be a solid metal plate with boots that mount to the truck body. The pleather assy goes over that.
  16. Jul 4, 2014 at 11:05 AM
    motorhead310
    motorhead310 Well-Known Member
    Pomona , Ca
    2006 Taco Pre-Runner
    My shifter light was out too. Or it would turn on and off whenever it felt like it, but was mostly off. One day, I took apart the console to try to fix my rattling shifter. After playing with the shifter a bit, I buttoned everything up. Suddenly, my shifter light always works now. Must have been a loose connection and I accidentally fixed īt.
  17. Jul 8, 2014 at 6:44 PM
    TacomaTRD4x402
    So Cal
    Anybody see anything wrong that would be allowing all the hot air to enter the cab? I ended up taking it all apart as you can see in the pictures. and ended up leaving it without the pleather(like how Madjik Man has it). I screwed down the 4 metal plate crews really really tight to see if hopefully that fixes the issue.
  18. Feb 7, 2016 at 2:09 PM
    glass guy
    glass guy Active Member
    scott
    2004 tacoma trd
    got mine to work today it was the wires on the replacement bulb were wrong
