Transporting Suzuki DR650 in my DCSB - suggestions pls.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kryten, May 22, 2011.
  1. May 22, 2011 at 11:09 AM
    kryten
    kryten [OP] Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Is anybody around here that has a DR650, KLR650 or some similar type/size of a bike? I would like to hear some suggestions how you transport these around on your Tacomas? I have a DCSB so obviously the tailgate will have to remain open and the bike angled. Does anyone have any pics with their bikes in the truck?
    1) How do you load the bike in the bed? What kind of rails work best?
    2) How do you secure your bikes? I have two D-rings by the tailgate. Would I need to get atleast two more for the front?
    3) Do you use the bed rail tie downs? Probably not by themselves as they are not rated for such weigtht, but together with the d-rings maybe? Or that not necessary?
    4) How does the tailgate hold up long-term with the bike resting on it. I won't be transporting this bike too often but when I do it will stay there for several hours.
    5) Do you guys use a bed extender in these situations?
    6) Anybody using a hitch mounted rack for their bike?
    7) Would a small trailer be better? (probably too much $ for me now)
    If anyone can give me some suggestions that would be greatly appreciated.:)
  2. May 22, 2011 at 11:37 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I put 2 more D-rings in the front of the bed. I wouldn't trust the side rails with a motorcycle. Check out the link below, it's how I load and tie down my bike.
    The tailgate holds up well. Your bike isn't that heavy so I wouldn't worry about it.
    I do not use a bed extender but they can be handy if you want to haul equipment in the bed like riding gear, fuel tanks, etc.
    A trailer would be easier but definitely not even close to required for a single bike.
    I don't have any experience with those hitch mounted ones but people use them and don't seem to have any problems. I figure you have a pick-up, use the bed, it's a lot more stable.
    http://www.tacomaworld.com/forum/motorcycles/120955-loading-motorcycle-dcsb-pics.html
  3. May 22, 2011 at 11:46 AM
    dirtfondler
    dirtfondler Well-Known Member
    San Jose, CA
    00 F250 7.3L Diesel
    Get ready for a plug for something I am selling, but here is a solid setup if you want to spend the money. I am pretty sure that a bike wont fit diagonally in a short bed. Regardless of tie down setup, keep the back of the bike to one side, not the middle. This will help the load on your tailgate since the middle is the weakest point!
    www.Readyramp.com. Nice long ramp to make pushing a heavy bike a little easier and it doubles as a bed extender to keep the rest of your gear in.
    http://www.tacomaworld.com/forum/2n...-bed-buddy-motorcycle-tie-down-bar-200-a.html
    Just did a trip this weekend over some rough dirt roads with two dirtbikes in the bed and nothing budged.
    I have also used a hitchmount (also homemade) and it works great too. Easy to load because it is much lower. It is a lot of weight hanging off the back of a taco though. I also use an enclosed trailer on some trips, but it sucks to go the reduced towing speed!!
  4. May 22, 2011 at 12:18 PM
    BLKTRD6SP
    BLKTRD6SP Well-Known Member
    Tim
    Crane Lake Alberta
    09 Black TRD 6 Speed
    2 way remote start,3M rockguard
    Picture of my setup
  5. May 22, 2011 at 8:05 PM
    kryten
    Canada
    Thanks to everybody for some great advice. I will definitely add atleast 2 more D-rings to the front. I'm liking the AMP Research Moto Extender as I'm thinking it could be used with my 10 foot kayak in summer aswell those days when I'm lazy to put in on the roof rack. Looks like it should not interfere with a roll up tonneau cover? I've got the Truxedo LoPro one. That ReadyRamp is pretty sweet but I will need 2 ramps anyway since I'm a noob.
  6. May 23, 2011 at 7:57 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    I usually just buy a truck with a big enough bed to haul my shit.Kinda like the saying,"trying to dump 10 gallons of shit in a 5 gallon bucket." Dbl Cab LB FTMFW!
  7. May 23, 2011 at 8:01 PM
    kryten
    Canada
    If they made DCLB with 6spd that would have been my truck. Did not plan on motorcycle when I bought it and apart from that it does everything else I need. I will make this project work too cause this Taco is staying for next 15 years with me!:D
    xaqori likes this.
  8. May 23, 2011 at 8:06 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    is your front tire against the front of the bed ?
  9. May 23, 2011 at 9:14 PM
    daredevildave
    daredevildave Well-Known Member
    Orange County, CA
    How bout 10 gallons in a 1 gallon bucket. It's not how big it is, It's how you use it;) SB ftw
    I did add 2 d-rings to the front wall, you can kind of see one of them in this pic[​IMG]
  10. May 24, 2011 at 4:42 PM
    BLKTRD6SP
    Tim
    Crane Lake Alberta
    Yes.
  11. May 25, 2011 at 7:38 AM
    kryten
    Canada
    So I got a pair of Toyota D-rings on order from ToyotaPartsStore, pt#:pT785-35054. http://www.toyotapartsstore.com/pro...5827&oszCsid=5b9de389117d123968480af3a24b21d1
    1) Now does anyone know if this comes with bolts? I would like to mount it to the frame, can I reuse existing bed bolts or do I need to get longer ones?
    2) Bought the Kinedyne Steadymate Cinchtite 2 straps at a local motorcycle store. http://steadymate.com/ca/product/1/25/cinchtite-2-tie-down-strap.html I keep reading that most people use the Canyon Dancer Bar Harness II. Is there any reason why I would want those instead of these. The Steadymate are rated for 835lbs which is more that double my bike weight. Looks like they have sewn handlebar loops which don't show on the product picture well.
