02 tacoma build!!
Discussion in '1st Gen. Builds (1995-2004)' started by eltacoutah, Nov 9, 2014.
  1. Nov 9, 2014 at 8:30 PM
    eltacoutah
    eltacoutah [OP] Well-Known Member
    Ben
    Utah
    2010 TRD Sport
    Just bought this bad boy a little over a month ago. Now I want to build this taco up. It currently has no mods done to it other than a bed cover and a couple stickers I got from Moab :)
    Currently it is stock. 2.7 liter 4 cyl 4wd. I bought it at 70k miles for a screaming deal!
    Ideas for build:
    3" lift (possibly) Any good ideas?
    Push bar and nerf bars
    Bigger tires to fill the wheel wells
    Fog lights
    I'm pretty much open for any ideas. If anyone has any ideas of what I can do or where I can get the stuff listed above for a good price let me know thanks!:)
  2. Nov 9, 2014 at 8:42 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    • Save your money from the nerf bars and get sliders! Much better for trails and they are a lot more functional than nerf bars.
    • As for push bars, idk. I dont like the look but you can always get some sweet offroad bumpers!
    Fog lights
    If you have any more questions fire away!
  3. Nov 9, 2014 at 8:58 PM
    eltacoutah
    Ben
    Utah
    2010 TRD Sport
    Where would I be able to get slider bars? Or would I have to make them?
  4. Nov 9, 2014 at 9:15 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    There are many vendors on here that make sliders for us and most offer a TW discount.
    Some good ones that come to mind are:
    Relentless Fabrication
    B.A.M.F
    4x Innnovations
    CBI Offraod
    and many others that I can't think no of right now
    Check out the vendors TW page and online website.
    http://www.tacomaworld.com/forum/vendors/
  5. Nov 10, 2014 at 2:00 PM
    eltacoutah
    Ben
    Utah
    2010 TRD Sport
    I don't know if I would want to weld those on in case I need to take them off or they get damaged. Do you make a bolt on one?
  6. Nov 10, 2014 at 3:53 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
  7. Nov 11, 2014 at 8:46 AM
    eltacoutah
    Ben
    Utah
    2010 TRD Sport
    Ok thanks. I'm getting the rims powder coated they should be done today i'll post pics later
  8. Nov 11, 2014 at 7:53 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Sweet! Powdercoat should hold up well!
  9. Nov 11, 2014 at 11:12 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    I would recommend OME for the lift. Or if you have a little more money you can get coilovers for the front and OME rear suspension.
  10. Nov 12, 2014 at 6:22 AM
    eltacoutah
    Ben
    Utah
    2010 TRD Sport
    Awesome thanks for the ideas! I think what i'm going to start out with after looking around on the site a little more is a satoshi grill and some retrofit lights.
  11. Nov 12, 2014 at 6:26 AM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
  12. Nov 12, 2014 at 9:43 AM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    If you have any questions on a Satoshi or retrofit, I've done both so I could answer any question you have!
  13. Nov 12, 2014 at 2:07 PM
    eltacoutah
    Ben
    Utah
    2010 TRD Sport
    Here are the rims powder coated. The tire is a little dirt but that can be cleaned easily
  14. Nov 12, 2014 at 2:13 PM
    eltacoutah
    Ben
    Utah
    2010 TRD Sport
    Do you have to use fiberglass and bondo for the whole grill or just the upper part? Noob question sorry haha
  15. Nov 12, 2014 at 3:50 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Hey, we all started out as beginners!
    I fiberglassed the top and bottom. That being said, I wouldn't fiberglass the bottom if i were to do it again.
    Instead i would either:
    Cut off the bottom middle mounting post and sand the grill inside smooth so you have a smooth edge. Even when cutting out the top two grill mounting posts the grill was very secure, I couldn't imaging cutting the bottom one off would change how secure it was.
    The other option would be just to leave it, it wouldn't look bad leaving it. Its about a 1cm x .5cm rectangle it would leave.
    I just wanted it to look smooth. If i were to do it again I would do one of those options.
  16. Nov 13, 2014 at 6:53 AM
    eltacoutah
    Ben
    Utah
    2010 TRD Sport
    thanks for the advice! I've never really done any fab work on cars before so it will be a fun experience. I'm thinking of just buying another grill online and use that so I don't jack up the grill I have on it haha
    I love waking up in the morning and seeing this sight!! giggity
  17. Jan 20, 2015 at 8:59 PM
    eltacoutah
    Ben
    Utah
    2010 TRD Sport
    just plasti-derped all the chrome. I think it looks mean :)
  18. Feb 16, 2015 at 2:54 PM
    eltacoutah
    Ben
    Utah
    2010 TRD Sport
    Put in a LED bar over the weekend. Looks clean
  19. Feb 16, 2015 at 3:11 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Nice! Looks good
  20. Feb 16, 2015 at 7:30 PM
    TacoTuck
    TacoTuck Well-Known Member
    NorthWest
    2001 4x4 TRD SR5
    Leer canopy, OME 881 lift with dakar leaf pack, 265/75/16 duratracs, 16x8 KMC enduros, line-x bedliner and more...
    how did you mount the light bar and what size/brand is it?
