02 to 04 cup holder tab replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by JLee, May 27, 2011.
  1. May 27, 2011 at 5:06 PM
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Okay guys I don't know if your cup holder tabs are as bad as mine were but here we go.
    Tools
    8mm socket
    10mm socket
    1/4" ratchet
    Philips screw driver
    Total cost was $8.60
    Items needed
    4
    To start remove all the bolts from the center console.
    One on each side of the back
    one on each side of the front
    & the two in the console
    Now remove the console, under the cup holders you will have 5 screws remove the screws one at a time and replace the tab.
    Note the tab with the arrow in the photo is the 66995-AD021
    New and the old
    All installed
    Note the 2 holes in the 66995-AD021 that's the way you install it so the holes match up with the little points on the console.
    Before
    After
  2. May 27, 2011 at 10:52 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Nice! Mine were gone when I got it :(
    firstgentacotuesday likes this.
  3. May 27, 2011 at 11:06 PM
    dagul
    dagul Well-Known Member
    SoCal
    01 RR SR
    Where did you order the tabs from? All of mine are missing...
  4. May 28, 2011 at 12:47 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
  5. May 28, 2011 at 4:37 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
  6. May 28, 2011 at 6:47 AM
    JLee
    Jerry
    Benicia, CA
    Yes he did that's crazy mine were 1.58 each just go to the dealer and pick them up.
    Roseville Toyota but you can go to any dealer and get them it's 8.60 for all of them.
  7. May 28, 2011 at 12:36 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Woot got 5 new tabs at my dealer today and only payed $4.67. Thanks for the post.
  8. May 28, 2011 at 12:59 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    I'll be heading to the stealership very soon. Thanks for posting this. It one of those things u just live with but would love to fix...lol.
  9. May 28, 2011 at 2:15 PM
    RacerP
    RacerP Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
  10. May 28, 2011 at 4:05 PM
    JLee
    Jerry
    Benicia, CA
    Yeah Ive seen it but I really didn't want to spend the time to cut all of them out.
  11. May 29, 2011 at 10:52 PM
    cheeko
    cheeko Active Member
    victoria
    Tacoma
    3" sus lift
    I used the neoprene mouse pad lying around the house. It is thicker and worked awesome. Just cut out the neoprene with pair of scissors. You can also pick the color.
    che
  12. May 29, 2011 at 11:30 PM
    fastguy95
    fastguy95 A man knows nothing
    SF Bay Area
    02 DC 4wd
    All Pro front/rear bumpers, OME 883's with Bilstein 5100 all around, Deaver J59 springs, TRD E locker, E locker Guard, Red Line hood struts, Weathertech floor mats, SS brake lines, EBC Rotors and green pads, Debadged, Line X, BAMF brake relocator bracket, Beefed Taco cb drop, Magnaflow muffler, Scuba Mod, live power outlet mod, disable door buzzer mod, tinted windows, light blinker conversion, Alpine HU, Infinity Kappa 600w amp, JL Audio 1000w amp for sub, JL Audio W3V4 12" sub, JL Audio 6x9's, Retrofit projectors bixenon 55w, Dynamat on all doors, and light bar.
    Thanks for the write up Jerry! I've always wanted to get new tabs, just haven't gotten around to it. Rep coming your way.
    Also, nice led bulb in between the cup holders. Were you replacing your interior dome bulb with one from vled?
  13. May 30, 2011 at 6:25 AM
    TejasYOTA
    TejasYOTA Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
    nice write up, but mine was free and made by me.... used an old mouse pad, the one with no hard covering on the mouse's surface.
  14. May 30, 2011 at 7:42 AM
    JLee
    Jerry
    Benicia, CA
    That bulb is and extra bulb I did the dome and reading lights and had to buy 4. you want to to buy it $5.00 bucks it's yours.
    Yeah that's all these tabs really are if you really feel like cutting then you can just get a mouse pad and do it that way. But when I found out it was 8.60 for all of them I said fuck it I'm buying the tabs.
  15. Jul 6, 2013 at 2:34 PM
    BioWheelin
    BioWheelin Well-Known Member
    California
    03 DC 4x4
    K&N air filter Wheelskin wrap
    Perfect! I was looking for the parts # for these. Thank ya.
  16. Jul 6, 2013 at 2:47 PM
    Madjik_Man
    Colorado Front Range
  17. Jul 7, 2013 at 7:27 PM
    Aught2TaCO
    Aught2TaCO Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
    I just went to Toyota and bought the stock ones. Found out they're made from better material so I was happy about that. Saved me time making them too, I have to be in that mood to do that these days.
  18. Jul 7, 2013 at 8:11 PM
    ALawrence
    ALawrence Well-Known Member
    Andrew
    Oklahoma City
    03 Tacoma Sr5 Double cab 4x4
    Nice write up! Did the same thing a couple month ago!
  19. Jul 18, 2013 at 7:37 PM
    Saguache
    Saguache New Member
    Boulder, CO
    Toyota Tacoma TRD
    Oh nice, need to do this
  20. Jul 18, 2013 at 8:46 PM
    BioWheelin
    California
    03 DC 4x4
    Thanks for the clear and concise write-up! I did this the other day and it took only about 20 minutes since I knew exactly where everything was.
