05 taco DRL Blown Lamps!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountaindrifter, Jun 11, 2007.
  1. Jun 11, 2007 at 9:08 PM
    mountaindrifter
    mountaindrifter [OP] New Member
    I have an 05 Tacoma and I'm constantly buying new lamps every few months because of the daytime running lights. Is there any way of bypassing the DRL feature? The least invasive the better. I've looked around and I'm having a hard time any info on the subject. Thanks for any help.
    Drifter
  2. Jun 12, 2007 at 5:17 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I recently installed DRLs on my 07 PreRunner. It requires that you replace a relay and a jumper underneath the dash...
    If you were to get a hold of a standard set (junkyard or parts dept.) you could reverse the process and have a "factory" setup without any real major modifications.
    I will have to do some research to see what the part #s are that you need, but it is completely doable. You just need to reverse the process that I did in this thread: 05+ DRL Install
    Good luck! :D
  3. Jun 12, 2007 at 7:43 AM
    flyman767
    flyman767 Well-Known Member
    Are they factory DRL'S or a mod that you performed? Especially if there factory, I would have your electrical system checked, most importantly your alternator/voltage regulator as this could lead to bigger problems down the road. I've had my factory DRL's for almost a year and have yet to replace them.
  4. Jun 12, 2007 at 7:47 AM
    stinger86
    stinger86 Well-Known Member
    San Diego, CA
    2016 Double Cab Limited
    Hey 007 just took a look at your DRL install very clean and well done just one question.. whats that little red button next to your automatic mirror switches?
  5. Jun 12, 2007 at 9:21 AM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    My truck came with an upgraded alarm system. It has the shock sensor, ignition disable, and a little LED light + Switch on the dash. The alarm is a little over sensitive, but otherwise I like the system. I have found that it automatically resets when you plug the battery back in.
    :eek: Scared the crap out of me.
  6. Jun 12, 2007 at 9:25 AM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    Yeah, this should be the case for almost all of them. I had factory DRLs on many prior vehicles, and I have put hundreds of thousands of miles on them without ever replacing a bulb (aside from the occasional headlight).
    I would go with flyman767's advice and get the electrical system checked - especially if you like having DRLs.
