'05+ Tacoma Clutch Shuttle Valve Removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rat107, Jun 4, 2015.
  1. Jun 4, 2015 at 1:55 PM
    rat107
    rat107 [OP] Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
    https://youtu.be/gNWWoNDpmDE
    The removal of the clutch shuttle valve (clutch accumulator) is required when installing a twin disc style clutch to gain more travel in the hydraulic system. I run a Competition Clutch Stage 3 dual friction clutch in my 2013 4x4 Tacoma and even with all the play taken out of the clutch pedal i had a difficult time getting it into 1st gear at a stop. This solved the problem. It also made the clutch a little bit easier to depress and gave it better feel.
    Notes:
    -I clamped the fluid hose at the clutch master with clamping pliers to keep the master from draining. Bleeding was super fast too.
    -I accessed the upper shuttle valve bolt through the fender well with a long extension, shallow 12mm socket attached to a universal joint.
    -The fitting to join the two hydraulic lines is metric thread available at a local parts store.
    FinnJ likes this.
  2. Jan 29, 2019 at 8:34 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Is there any benefit to this mod for those of us with factory clutches?
  3. Jan 30, 2019 at 10:24 AM
    kidthatsirish
  4. Jan 30, 2019 at 12:53 PM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Not sure that the four cylinders even have it. But, otherwise, yes. The fluid accumulator is garbage.
  5. Jan 30, 2019 at 1:02 PM
    kidthatsirish
    What is its purpose? I think the 4 cylinders have it....my pedal likes to stick to the floor in really cold weather till I've been driving for a while.
  6. Jan 30, 2019 at 5:54 PM
    Pigpen
    Dan
    Northwest Montana
    My clutch works fine, but I like to fix things until they're broken. I like this.
    81shark likes this.
  7. Jan 30, 2019 at 6:10 PM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    Yes, removal brings consistency back to the clutch travel. That is, it will always engage and disengage at the same point in the pedal travel and the action is predictable and consistent. There is a discussion thread in the 3rd gen area as well as a one where a member is making up pre-bent kits for guy that don't want to mess with flaring or bending brake line.
    I realize this is a 2nd gen thread, but I am a strong advocate for this mod and highly recommend it.
    https://www.tacomaworld.com/threads...dm-and-bs-thread.568303/page-40#post-19737960
    https://www.tacomaworld.com/threads/clutch-accumulator-delete-kit-sold-out.583387/
    Norton and gearcruncher like this.
  8. Jan 30, 2019 at 8:14 PM
    kidthatsirish
    So what is the purpose of the accumulator?
  9. Jan 30, 2019 at 9:22 PM
    Pigpen
    Dan
    Northwest Montana
    As a bullet caster and reloader, I love your avatar
    This accumualtor business is news to me too. It's not broke, but I want to fix it.
    Norton and kidthatsirish[QUOTED] like this.
  10. Jan 30, 2019 at 10:26 PM
    kidthatsirish
    I'm in the same camp you are about this accumulator.
    The avatar was a "technical diagram " my friend sent me the day before he taught me to hand load my own ammunition. :)
    My wife than made t-shirts for us both with it on the front...its a good chuckle amongst us all.
    Norton and Pigpen[QUOTED] like this.
  11. Jan 31, 2019 at 5:19 AM
    fatboyfirebass
    General consensus is that Toyota added it to "slip" the clutch a little for the driver. It basically slows down the engage or disengage of the plate by slowing down the fluid traveling to and from the slave cylinder. And this makes it easier for drivers with less experience on a manual transmission. Best guess is, it's an attempt to prevent the "dumping" of the clutch and stall or buck the engine
  12. Jan 31, 2019 at 5:41 AM
    gearcruncher
    Canadain bumper technician
    I dont have a manual in my truck , but if the delete kit gives you more pedal travel , I also highly recommend performing this mod .
    These trucks dont come with enough adjustment to keep everything performing properly over the lifetime of the clutch and I have the proof . If this is something that can be done to increase clutch longevity as well as " throw out bearing " longevity , get er done .
    A cheap fix to a serious design flaw .
    How many of you actually adjust your clutch pedal according to the FSM ?
  13. Jan 31, 2019 at 7:22 AM
    Pigpen
    Dan
    Northwest Montana
    Not I. I' haven't even bled the fluid in the clutch system - something I keep meaning to do. I'm (over)due for another full brake flush. I'll be waiting for warmer weather. That'll be a good time to do it.
    The original post says this part is available at the local auto parts store. Can we get a part number, or more details than "metric thread"?
    Thanks
  14. Jan 31, 2019 at 7:41 AM
    fatboyfirebass
  15. Jan 31, 2019 at 7:48 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks! @rat107 's video is what started me down the rabbit hole. @RedBeard1 closed the circle when he confirmed the suspicion that our brake lines and fittings are the same as the clutch side.
    Also, a huge thumbs up for @Trident904 for making drop in kits.
    Trident904 likes this.
  16. Jan 31, 2019 at 11:20 AM
    shaeff
    Hudson Valley, NY
    Yep, and makes people who have driven stick since day one look like a novice. If I drive my truck like ANY of my previous manual vehicles, I look like a novice. I can drive it smooth, but refuse to change my habits because of a crappy device designed for n00bs.
    Previous manual vehicles include:
    ‘71 Chebby c-10 stepside
    ‘86.5 Toyota Supra Turbo (#1)
    ‘94 Toyota 4x4 pickup
    ‘86.5 Toyota Supra Turbo (#2)
    ‘95 BMW M3
    ‘02 Toyota Tacoma 4x4
    Current ‘07 Tacoma DCSB 4x4 with the WORST clutch feel of any vehicle I’ve owned or driven.
    Edit- oh, it’s broke, you just didn’t KNOW it was broke! ;)
  17. Jan 31, 2019 at 11:51 AM
    Pigpen
    Dan
    Northwest Montana
    Yeah, I've been driving manuals since I was 13 (I'm 44). This one definitely has its own feel.
    Norton likes this.
  18. Jan 31, 2019 at 1:33 PM
    DLillest
    DLillest Well-Known Member
    Quebec, Canada
    2007 SBM DCSB 6MT 4x4
    I agree with the rest. All I've owned are manuals and this manual by far is the worst. No matter how much I drive it, I cant seem to get a consistent or smooth shift.
    I try changing up the way I drive or shift each time and I still can never get smooth transitions. Not sure if this mod would help.
    Norton likes this.
  19. Jan 31, 2019 at 3:33 PM
    fatboyfirebass
    This mod is what you're looking for.
    DLillest[QUOTED] likes this.
  20. Sep 21, 2020 at 2:54 AM
    NCAmother
    NCAmother Well-Known Member
    2006 Tacoma 2.7L
    Does the 5 speed have an accumulator? The pedal in my Tacoma leaves a lot to be desired
