05 truck with 4.0 wrong rpms
Discussion in 'Technical Chat' started by specter208, Apr 17, 2022.
  1. Apr 17, 2022 at 3:14 PM
    specter208
    specter208 [OP] Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    have an 05 Tundra with 4.0 V6 and RA60 6MT. The truck doesn’t have a OEM tachometer. I have an ultra gauge and techstream that reads about 150rpms low from what it should be. For example 65mph should be almost 2600rpms in 6th with OEM 29.5” tires. My gauges will read about 2400rpms instead. Is this normal? I wonder if the gauge cluster affects these rpms because the dash was replaced at one point, I bought the truck used.
    I am asking here because there is more info on TW for the 4.0 and what is basically 1st gen Taco technology than on Tundras which is more for the v8s.
  2. Apr 17, 2022 at 3:26 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    How is your pickup [for the RPM read] happening. I'd bet it's correct and either your gauge is off or you have another factor. Lets face it, 150 RPM is a single digit percentage ''off'' at 65 mph and even a small difference of tire diameter could cause that.
  3. Apr 17, 2022 at 3:29 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Are you certain of your axle gear ratios?
  4. Apr 17, 2022 at 3:43 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Make sure you're using GPS speed as the speedometer is usually 2-3 mph off.
    Make sure you're using your specific tire's "revs per mile" spec when calculating rpms, not the diameter from the nominal size.
    Is the discrepancy only apparent in 6th? 6th gear in the RA60 is either 0.80 or 0.85 depending on application: https://www.tacomaworld.com/threads...on-your-6-speed-transmissiom-write-up.338840/
  5. Apr 17, 2022 at 5:04 PM
    specter208
    California
    Axle ratio is 4.08 for 00-06 Tundra manual V6s.
  6. Apr 17, 2022 at 5:08 PM
    specter208
    California
    I will check the revs per mile. The tires are Firestone destination LE3 245/70r16s Also the trans is 0.85 for 2wd version of the Tacoma RA60F.
    According to tire rack, revs per mile should be 705. Not sure how to calculate the speed.
  7. Apr 17, 2022 at 5:13 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
  8. Apr 17, 2022 at 5:19 PM
    specter208
    California
    The Ultra gauge and techstream connect to the obd port under the steering wheel.
  9. Apr 17, 2022 at 5:28 PM
    specter208
    California
    Thank you. According to these instructions
    705x65/60 = 763.75
    763.75 x 4.08 x 0.85 = 2658.6rpms
    Not 2450rpms according to ultra gauge.
    Even in 5th gear at 55mph it will read about 2450rpms instead of 2638rpms. Strange.
    3JOH22A[QUOTED] likes this.
  10. Apr 17, 2022 at 5:30 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Whatever engine speed is reported over obd should be correct as it is actual engine speed that the PCM is reading.
    Not sure how the Tundras gearing compares to the 2nd gen Tacoma but mine runs around 2300 @ 65.
    specter208[OP] likes this.
  11. Apr 17, 2022 at 5:38 PM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Most OE tachs read about 200-300 rpms higher than actual if you are getting the "what it should be" from. I know you don't have one.
    I dyno'd my '00 Tundra 4.7v8 and the tach was reporting limiter cut at 5500, but dyno was saying it was maybe 5200rpm
    Put down a healthy 205hp and 275lbft to the wheels on a Dynojet vs OE ratings of 240hp/315tq with 235,000 miles
    If I remember correctly, my '05 Tacoma 4.0 6MT is about 2,500rpms at 70mph with 265/75-16 and OE 3.73 gears.
    specter208[OP] and Bishop84 like this.
