08 Rugged Trail Services
Discussion in '2nd Gen. Tacomas (2005-2015)' started by XB21, Jul 28, 2015.
  1. Jul 28, 2015 at 5:02 AM
    XB21
    XB21 [OP] Member
    2008 Tacoma Rugged Trail
    K&N intake Dynomax Super Turbo single exit
    I recently purchased my 2008 Tacoma Rugged Trail. Truck has 140k mi and I want to do several services to it including; Spark Plugs, Transmission, and Rear Diff.
    Which plugs and fluids are best recommended and how bad is servicing the transmission? I have heard nightmarish stories about servicing this transmission.
    Thanks.
  2. Jul 28, 2015 at 6:46 AM
    Pigpen
    Dan
    Northwest Montana
    Welcome to TW!
    Use the regular copper Denso or NGK plugs. Which Transmission (auto or manual)? I vote Mobil 1 synthetic for the diffs. Are you 2wd? If 4x4, might as well do front diff too - the axles are always spinning.
  3. Jul 28, 2015 at 6:47 AM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    The search box is your friend, but here's to get you started.
    **This is assuming you have a 1GR-FE**
    Mods/tips/tricks for 2nd gens here: https://www.tacomaworld.com/threads/2nd-gen-tips-mods-more.7174/
    Plugs change here: https://www.tacomaworld.com/threads/how-to-spark-plug-change-1-gr-fe.30479/
    Rear diff: https://www.tacomaworld.com/threads/changing-differential-fluid-a-step-by-step-how-to.24545/
    You also probably want to lube the driveshaft (I used Lucas Red N Tacky): https://www.tacomaworld.com/threads/drive-shaft-lube-points-2nd-gen-4wd.225161/
    Fluid recommendations are included in the DIY threads. I'd go with Toyota for the trans fluid and Mobil1 for the diffs and transfer case.
  4. Jul 28, 2015 at 6:47 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    For rear diff most people seem to like the Mobil 1 synthetic 75-90 and stock replacement spark plugs. I would leave the transmission service up to the dealership since it is not as simple as drain and refill.
  5. Jul 28, 2015 at 8:32 AM
    XB21
    XB21 [OP] Member
    The truck is 2wd but has the RR diff lock button on dash. Transmission is Auto
  6. Jul 28, 2015 at 10:36 AM
    ChiefManyWrenches
    Florida
    The rear end is extremely easy just make sure you get enough fluid to fill it up, should be around 3 quarts I think. Also get the little pump that goes in the bottle to make it easier to refill. Make sure you can loosen the fill plug before you try to loosen and drain from the bottom.
