09 Always-On Rear View Camera
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aalders, Jun 28, 2009.
  1. May 20, 2010 at 2:23 PM
    #101
    Aalders
    Aalders [OP] Well-Known Member
    Logan
    Dover, Delaware
    2009 Double Cab TRD off road
    Pop-n-Lock Tlailgate handle, TSB Rear Leafs, 12V bed outlet, Back up camera in mirror mod, Roof Rack, TRD Exhaust, Front Skid Plate, Running Boards, 4 100w KC SlimLites, Westin brush guard, Fog lights in the bed pockets, extra D rings in the bed, Fog light mod, seat belt chime mod, 75,000 candlepower StreamLight rechargeable flashlight
    that switch is the right one. "12v lead" is the wire to the mirror and the two "on" labeled posts are the 12v from the reverse and the 12v from the jumper your installing.
  2. Jul 23, 2010 at 4:15 PM
    #102
    derekAV
    derekAV Well-Known Member
    derek
    Humboldt
    2000 4x4 reg. cab
    damn it! not working, check engine light is on, traction control light is on...:mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad:
  3. Jul 23, 2010 at 4:28 PM
    #103
    Aalders
    Logan
    Dover, Delaware
    seems like you got some wires crossed...
  4. Jul 23, 2010 at 4:32 PM
    #104
    derekAV
    derek
    Humboldt
    2000 4x4 reg. cab
    i thought so too, but i checked it multiple times..i took it all off and the lights are still on..
  5. Jul 23, 2010 at 4:35 PM
    #105
    Aalders
    Logan
    Dover, Delaware
    The lights will stay on until you disconnect your battery... what type of switch did you get?
  6. Jul 23, 2010 at 4:55 PM
    #106
    black_magic2010
    black_magic2010 Well-Known Member
    South Texas
    10 Tacoma TRD Sport DBL Cab
    Yup buddy happened to me also when I completed this mod. Just make sure you have everything wired up correctly. Once you've finnished with the mod just disconnect your battery for a few mintues and reconnect. That will fix the problem. EXACT SAME THING HAPPENED TO ME:D
  7. Jul 23, 2010 at 5:31 PM
    #107
    derekAV
    derek
    Humboldt
    2000 4x4 reg. cab
    the lights did go off!..but i still cant seem to get the switch to work..oh well im over it haahahaha
  8. Aug 9, 2010 at 4:22 PM
    #108
    BlackRig
    BlackRig Well-Known Member
    Craig
    NE Ohio
    2021 SR5
    In this mod does anyone know where those wires lead to? I want to do this also but don't want to have the switch on the mirror. I'd like to put it near the rest of the switches. I think I read somewhere that the wire ended up near the fuse panel behind the cubby but I can't find the thread to verify.
  9. Aug 9, 2010 at 5:11 PM
    #109
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    You could just run extender wires down there. It's not that difficult to stuff the wires into the gap between the headliner and the roof, I have a bluetooth cable stuffed up in mine and it hasn't came down yet. You would just have to take off the handbar pillar (just those two bolts) and the kickpanel.
  10. Aug 10, 2010 at 8:19 AM
    #110
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    Alright...im'a give this one a shot this weekend. Gotta head out to the shack to pick up some stuff first.
    Any reason why you used the quick-connect to tap into green but used the small crimp connectors on the other 2? I suppose there is not enough space to use 3 quick-connectors?
    I have used quick-connects and they are fairly dummy-proof but how do the crimp connectors work?
  11. Aug 10, 2010 at 9:23 AM
    #111
    Chad
    Chad
    Cary, NC
    Each wire goes into an end and you crimp the sides and middle of the butt connector with a crimping tool. Pretty simple process. When you get them you'll see that it's basically dummy proof also.
  12. Aug 10, 2010 at 9:38 AM
    #112
    H0LLYW00D
    H0LLYW00D Well-Known Member
    I want to do this mod on my 09, but want to wire it down to a switch on the dash, is there an easy to do this. i will be adding a front view camera aswell and want two small switches side by side for both cameras. does anyone make a switch set that has two rocker switches side by side that would fit in the blank spots on the dash?
  13. Aug 11, 2010 at 3:59 AM
    #113
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    yea my truck has a hugeeee front view.. its literally the entire space between the dash and the roof.
    J/K.. I often think it would be awesome to have a front view camera for those tricky parallel parking and tight turning times. just as the back view lets you get super close, the front would be the same, and pretty helpful without risking a little bump to the other car.
    how do you plan to do this? would it be displayed on your head unit or on the mirror same as reverse cam?
  14. Aug 11, 2010 at 9:04 AM
    #114
    H0LLYW00D
    In my head unit. I plan to make this truck and off road machine so it will help on the trails and in the parking lots.
  15. Aug 11, 2010 at 10:53 AM
    #115
    Paul's TRD
    Paul's TRD I'm Not Your F***ing Brother
    TX
    2011 Z71 4x4 5.3L V8
    subcribed, so when i find the time. been wanting to do this
  16. Aug 11, 2010 at 12:30 PM
    #116
    MUDFISH
    MUDFISH Well-Known Member
    Syracuse
    12 Double Cab SR5
    I need to try this, but I'm always nervous messing with electrical... Next time I'm at the Shack, I'll pick the stuff up...
  17. Sep 13, 2010 at 1:58 PM
    #117
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  18. Sep 13, 2010 at 10:11 PM
    #118
    slick_711
    slick_711 Well-Known Member
    DFW, TX
    '09 TRD Off Road
    Avid light bar w/2x Hella 4000C, Bilstein 5100s, Demello sliders
    Just to clarify: are you saying once you did the mod your reverse lights do not come on even in reverse? Or just that using the switch in the "always on" position does not cause your reverse lights to come on?
    Either way, very cool mod, I think I will be partaking. My reverse lights not coming on would sketch me out a bit, but I think that must not be what you were saying, or not many guys would have done this.
  19. Sep 15, 2010 at 10:43 AM
    #119
    honejim
    honejim New Member
    Jim
    Colorado
    2010 Tacoma
    Killer mod! I already did the "brighter stock reverse lights" mod. If I can figure out how to turn them on whenever the jerk behind me is blinding me with his bright lights. I could use both mods to see the expression on his face when I turn those babies on. LOL
  20. Sep 15, 2010 at 2:14 PM
    #120
    BGrutter
    BGrutter Well-Known Member
    Baron
    Kansas City, MO
    2010 4x4 DCSB TRD OR
    Rear-View Camera Mod, Anti-theft Tailgate, No Mud-Flaps, Diff Breather Mod, Color-matched Mirror/Handle covers, Front Valance mod, Phone/GPS/Camera mount, and Illuminated 4x4 Switch ToyTec Ultimate Lift Light Racing UCAs
    I did this recently and this was my FIRST real electrical modification I've done to a car. All and all, it was a very simply process.. I followed the step by step and tried to document as well as I could (pictures and write-up). I added a few details, such as many of the specific Part #s from Radio Shack. Also, I encountered a few small hiccups. So, hopefully my experience might helps those others that are considering doing it.
    Check my build thread for details and HUGE thanks to the OP.
