09 tacoma climate control lights
Discussion in 'Lighting' started by rektech, Dec 4, 2011.
  1. Dec 4, 2011 at 4:40 PM
    rektech
    rektech [OP] Member
    ohio
    2009 tacoma double cab 4X4 TRD
    additional bed storage door
    I have a 09 tacoma double cab and one of the climate control light burnt out. Ive been looking all over the web for a replacement but cant find a definet type to get. I found a thread that suggested superbrightled.com #74. I order these but they do not fit and it doesn't look like i can modify them to fit. Can someone help
  2. Dec 4, 2011 at 4:47 PM
    ty.s07
    ty.s07 Well-Known Member
    Alabama
    I went to the dealership with my old bulb assembly and they were able to match it with a cheaper version of the same thing ($0.19 to be exact) only difference is the base for the bulb was green and the bulb had a green cover on it (which I removed to make the climate control light up amber like the oem stuff) no problems so far :cool: I meant to keep the package so I would have the part number but I think I trashed it on accident, I'll see if I can get another bulb.
  3. Dec 4, 2011 at 4:57 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Have you tried takeing the bulb out of the back.
    Remove the a/c panel and on the back you will see the two things on both sides the twist out. Get twisers or fine needle nose and twist them out or the one that is broken. Then take the needle nose and twist the wires till the there straight and pull the burned bulb out then take it too a radio shack and see if there is a match.
    I'm gunna do it tomorrow because I'm changing the color to blue and I almost got it.
  4. Dec 29, 2011 at 3:01 PM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
  5. Jan 1, 2012 at 10:33 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    The light you need from Toyota is p/n 84999-10090. There are two small bulbs located on the back of the cluster that twist right out. This one has the brown base and a clear bulb that matches what's in there now.
    hresendiz25 likes this.
  6. Jan 1, 2012 at 6:11 PM
    docbrown
    Tampa, FL
    05 Tacoma SR5 4X4
    The ones from Candlepowerinc are direct replacements and are a lot cheaper.
  7. Jan 1, 2012 at 7:09 PM
    08TacoTrD
    08 TRD Offroad
    Per unit they are cheaper but if you only need one or two, the upfront cost is greater.
  8. Aug 23, 2012 at 8:42 AM
    jtnyc
    jtnyc Well-Known Member
    Anyone got extras? I just need a couple. Candlepower has been out of stock for a while now...
  9. Aug 24, 2012 at 9:10 AM
    big red taco
    big red taco Active Member
    Mississippi
    08 TRD sport
    Pro Comp 6" lift, 35" Mickey Thompson Baja ATZ, 20" KMC XD Diesel, Train horns, HIDs, LED interior lights, LED tag lights
    Is this the same bulb that controls the flow of air knob? My light went out on that knob
  10. Oct 7, 2012 at 4:11 PM
    bra
    bra Well-Known Member
    2008 AC 4X4 TRD sport
    Badges off
    Thanks for that bro, but are you sure it is the KT928?
  11. Dec 30, 2012 at 12:59 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    http://autolumination.com/74.htm
    Middle of the page, search for "79674-S3N-941"
    You want the incandescent clear lamp, Type-B
    They're $2 each
    The enviro controls are lamps, the rest of the dash is LED.
    Why?
    The rest of the dash is on any time the truck is on. The enviro controls (and switches) are only on with the headlights, so they last.
    I tried LEDs in my '08, and they were horrible.
    sprung22 likes this.
  12. Dec 30, 2012 at 2:06 AM
    mrbee
    mrbee Member
    The $2 bulb is not so bright compared the the KT928 , Shipping is another few dollars
  13. Dec 30, 2012 at 10:13 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The KT928 is a T5.5, the correct bulb for the 2nd Gen HVAC display is a T4.
    Doughnut Spaghetti likes this.
  14. Jan 1, 2013 at 4:01 PM
    mrbee
    mrbee Member
    There are 3 people in this thread who confirm the KT928 is a direct replacement.
    Try the KT928 and you will see what original brightness looks like.
  15. Jan 1, 2013 at 4:08 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I only see one... Docbrown. The other posts were questioning whether or not it is correct.
    It might be correct for 1st Gen, but it is absolutely not correct for 2nd Gen.
    I am running the clear bulb T4 replacements from Autolumination and they are an exact fit and brightness replacement for the factory bulbs.
    I bought all three... the T3, T4, and T5, because nobody on this forum knew which one would fit and could only offer the $15 dealer part number.
    Trust me... the T5.5 from Candlepower will NOT fit... it is larger than the T5, which won't fit.
    The T4 is the correct lamp.
    becker.adam2 likes this.
  16. Jan 1, 2013 at 4:43 PM
    mrbee
    mrbee Member
  17. Jan 1, 2013 at 5:56 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Whatever man.
    Candlepower is out of stock on them and from what others have been posting, they've been out of stock for most of the year.
    You are just dredging up old, dead threads from early 2012 and 2011 spamming your eBay seller ID.
  18. Jan 2, 2013 at 7:32 AM
    docbrown
    Tampa, FL
    05 Tacoma SR5 4X4
    The KT928 is what I used and it is a direct replacement. I have three that I would be willing to give to anyone that needs it if you don't mind snailmail. LMK via PM. My truck is a 2nd gen (2005). I don't think they changed the lights on later models, but I have no way of verifying it.
  19. Jan 7, 2013 at 9:42 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Hey man, what LEDs did you use?
    Will any of these fit?
    http://www.superbrightleds.com/cat/instrument-cluster-gauge/
  20. Jan 7, 2013 at 9:50 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I tried LEDs first and they sucked.
    The AC display has a lot of acrylic surrounding the lights that transmits the light to the dials. The single-chip LED is too directional and only gets picked up by part of the display.
    I went with regular white lamps.
