100k miles service?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma2468, Mar 6, 2020.
  1. Mar 6, 2020 at 6:11 AM
    Tacoma2468
    Tacoma2468 [OP] Member
    I have a 2006 Toyota Tacoma with 102000 miles. I'm going to change the oil tomorrow. What else needs to be done? Thanks.
  2. Mar 6, 2020 at 6:15 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    You'll get differing opinions, but I guess it depends on what's been done.
  3. Mar 6, 2020 at 6:29 AM
    Tacoma2468
    I dont know.
    I thought there were recommended things to do at 100l.
  4. Mar 6, 2020 at 6:44 AM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    Blockhead likes this.
  5. Mar 6, 2020 at 6:45 AM
    Tacoma2468
    Is doing spark plugs myself on a second gen hard? Do I just take off the coil packs and then replace the plugs then reconnect the coil packs?
  6. Mar 6, 2020 at 6:47 AM
    Greenedmc
    Daniel
    Elizabethton TN
    Yes there should be some threads on here but it’s an easy job. If you have a 4.0 it’s due every 30k for spark plugs.
    Edit to add: Just use Denso or ngk copper plugs on the 4.0(not sure about the 2.7). And check your gap before you install.
  7. Mar 6, 2020 at 7:28 AM
    Oldewing1800
    Oldewing1800 Well-Known Member
    2006 Double Cab
    Dog hair, lost happy meal parts from Grandkids....
    I do my plugs every 50K, they normally look fine. But I do have some seizing issues, so thats the big reason I do it every 50. Easy job, unplug coil, 10mm bolt, coil comes out. R and R plug. Seems to me, some thing of the driver's side has to move, PVC line or something (it's easy). 4 O engine here.
    I flush the tran at 80K then again at 200K. Went longer as I don't use it to tow anymore.
  8. Mar 6, 2020 at 7:34 AM
    Greenedmc
    Daniel
    Elizabethton TN
    If you have a manual trans a drain and fill is recommended every 60k as well as the rear diff(also front diff and t case if you’re 4wd)
  9. Mar 6, 2020 at 8:05 AM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    Do what the manual suggests. If unsure of when last fluid/spark changes were, then do a full sweep starting with Oil.
    Greenedmc likes this.
  10. Mar 6, 2020 at 12:01 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  11. Mar 6, 2020 at 1:17 PM
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    Yeah manual has most of it. But if you’re looking for things to do....
    check all rubber- serpentine belt, hoses, suspension bushings, cv boots, your spare tire etc,
    Replace, coolant, brake fluid, ps fluid, diff gear oil, check trans fluid, maybe a drain/ refill
    Have a look at that air filter and cabin filter
    Make sure suspension and driveline bolts are torqued and zerks are greased
    Make sure your rear diff breather is clear and not caked in rust or mud
    Front wheel bearings might be about to start going at that point.
    Shocks?
    Pcv valve?
    MAF sensor?
    Check bed bolts are tight
    Spark plugs as mentioned
    have a good look at your frame, you’re past the replacement window but it’s still a good idea to know what’s going on under there, and if nothings ever been done consider coating it in fluid film or something
    there’s a whole host of things you could do to be proactive at that age and mileage, a small list of things that you really should do.
    Markcal likes this.
  12. Mar 6, 2020 at 1:42 PM
    Markcal
    Markcal Well-Known Member
  13. Mar 6, 2020 at 1:49 PM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    I would agree...if you don't know fix it! One of the most forgot items to change out is the PCV valve...so if you're doing sparkplugs do the PCV valve.
    Make a day of it and get to know your truck I say....
