$1500 lift 2-3"
Discussion in 'Suspension' started by Boris20, Jul 21, 2017.
  1. Jul 21, 2017 at 8:47 AM
    Boris20
    Boris20 [OP] Well-Known Member
    Jordan
    Oklahoma
    17 Tacoma TRD OR Quicksand
    If no one has any real objection, or insight as to it being a problem setting say the fox level 1 to max lift setting, I will probably go this route. As smitty mentioned to me on a PM, he does not think setting the 6112's to max lift will hinder the quality much at all or longevity of the shock.
    I wish someone who has went from medium setting the max setting with one of these adjustable coilovers could chime in and share their experience.
    scottalot likes this.
  2. Jul 21, 2017 at 8:52 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Kings it is, that's what I want as my next set, will be selling the old IFPs. They have about 25K on them, no leaks right now.
    scottalot[QUOTED] likes this.
  3. Jul 21, 2017 at 8:53 AM
    Boris20
    Jordan
    Oklahoma
    yeah if i were to ever adjust them it would be while on the truck. Ive used spring compressors several times and will not be doing that again. Ill pay someone to do it before ill mess with that.
  4. Jul 21, 2017 at 8:55 AM
    Boris20
    Jordan
    Oklahoma
    you guys stop this Kings talk. Making me have wild thoughts of blue in my fender wells.
    EatSleepTacos and scottalot like this.
  5. Jul 21, 2017 at 9:03 AM
    Mully
    CA
    Agreed on the fine threads on fox body, spanner wrench will also hurt your hand and doesn't work on the new IFPS. I have the very first production version, ordered them before they were on the market. If you look at the adjusters on mine, I have the locking ring. The new ones have an Allen bolt locking the ring down. I was able to adjust mine on my Truck, but they do now say to use a spring compressor. Moving onto Kings. Done.
  6. Jul 21, 2017 at 9:11 AM
    Boris20
    Jordan
    Oklahoma
    wrenched down like that did you notice any difference in ride?
  7. Jul 21, 2017 at 9:14 AM
    Boris20
    Jordan
    Oklahoma
    Thats the mentality I am having. Not sure how i feel about preloading them that much to get 2" lift for a permanent deal.
  8. Jul 21, 2017 at 9:16 AM
    Mully
    CA
    I am adding a Pelfreybilt steel bumper, skids, and 10K winch. New shocks with 700lbs springs I think are going to be a must get. What do you think?
  9. Jul 21, 2017 at 9:21 AM
    Mully
    CA
    I am thinking that I will just add 700s to the IFPs and try that 1st. Trying to save up for gears, lockers, wheels and tires right now. Thanks for the info, really appreciate the advice man.
  10. Jul 21, 2017 at 9:23 AM
    Boris20
    Jordan
    Oklahoma
    I havent done this, but from what Ive read yes
    Mully[QUOTED] and scottalot like this.
  11. Jul 21, 2017 at 9:25 AM
    Mully
    CA
    Did, about 2 or 3 turns. Had no issues with alignment or driving.
  12. Jul 21, 2017 at 10:10 AM
    Boris20
    Jordan
    Oklahoma
    Going to pop up another thread in regards to the Fox lvl 1 kid and maxing it for 2" lift and see if i cant get some more info on this, I am coming up short using the search function.
  13. Jul 21, 2017 at 1:44 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so much @scottalot and @EatSleepTacos ! I hope you guys are have an awesome Friday!!
  14. Jul 21, 2017 at 1:44 PM
    HeadStrong Off-Road
    Looks like so much FUN!!!! :headbang:
    Mully[QUOTED] likes this.
  15. Jul 23, 2017 at 10:26 AM
    #35
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Sub'd
    Curious to see where OP goes with this
  16. Jul 23, 2017 at 11:14 AM
    #36
    Boris20
    Jordan
    Oklahoma
    Still tossing ideas around TBH. Pretty much between these
    OME full set up 887 coils, OME shocks
    Fox 2.0 or 2.5
    6112's max settings
    All seem to be solid ideas.
    Will do the ECGS Bushing during install.
    If I can get the fox to 2" without "maxing" them out, thats the route I will most likely go.
    Rear I will either do HS 3 leaf AAL or Dekar.
    For now I am not doing UCAs as these should keep it around 2" front.
    I want to maintain atleast a 1" rake, so may end up having to do the Dekar. Plus I sometimes haul a trailer with remodeling supplies.
  17. Jul 24, 2017 at 11:38 AM
    #37
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
  18. Jul 24, 2017 at 11:54 AM
    #38
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    Yeah I'm in to see where the OP goes with this too.
  19. Jul 24, 2017 at 12:00 PM
    #39
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    He can go nuts with his budget but for a daily driver that sees as much time on the road as he says, my recommendation should work for him. No preloading springs, no spacers, no UCAs, no alignment issues and no coilover adjustments / maintenance / rebuilding for just over half his budget.
    It even compensates for possible Taco lean with the 1/4 inch spacer on the driver side.
    If he wants to go higher he can swap to 887 springs but the rake will be reduced.
    Very pleased with the performance of my truck and the tires still look proportional.
    Boris20[OP] and Rome604 like this.
  20. Jul 24, 2017 at 12:25 PM
    #40
    Boris20
    Jordan
    Oklahoma
    sweet man. Thanks for sharing that with me. I think the 885's will be what I go with.
    How does it ride compared to stock?
    How much has it settled since lift? ( i see youve only had it on a few days so hard to say yet I am sure)
    I have zero weight in my bed or rear end. I will most likely not leave the Overload leaf in.
    Love the truck. Looks great.
