1st Gen A/C System Replacement How-To (Seized Compressor)
Discussion in '1st Gen. Tacomas (1995-2004)' started by geodude, Aug 31, 2013.
  1. Aug 31, 2018 at 10:17 AM
    #61
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Oh I gotcha. I just priced out the evap, compressor, EV and condenser and it was $30 cheaper on Amazon. Just make damn sure what you are getting is legit.
  2. Aug 31, 2018 at 11:00 AM
    #62
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    That compressor is identical to factory down to the last detail. They come with a bit pf pressure to prevent intrusion of anything while it sits on the shelf. The valve core under the gray cap in the "blank" shipping plate is the same size as the service valves on the truck. It does come with both line o-rings and the plate seal. The receiver also comes with o-rings.
    It is a heck of a price and a very satisfying part to buy. Fun to just look at it on the bench. It's complete, neat, compact, hefty, kind of a shame to bury it on the truck.
    cruiserguy and ThunderOne like this.
  3. Sep 1, 2018 at 8:16 PM
    #63
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Had my system evacuated Friday.
    Replacing the Compressor, condenser, drier, and expansion valve tomorrow. All Denso except for the condenser.
    I’m a bit conflicted about the oil. The Denso comes with oil and says to drain both and match the volume of the new with the old. But I only got about 30ml. That’s far less than stated in this tread. I’m also curious if I should add any to the evaporator since it’s gonna be reused.
    If anyone could explain what I should do and why I’d really appreciate it.
  4. Sep 1, 2018 at 9:35 PM
    #64
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Were you turning the clutch while dumping the oil?
    No need to add oil to evap if reusing. I would say you need 80-100cc of oil in the compressor. If only 30cc came out then that's low. Not sure why you're replacing but if it grenaded or got noisy then that's probably why. Supposedly the compressor leaks a slight amount of oil over time in order to lubricate the shaft seal. I'm not sure if that applies to these compressors, or if so, how much that equates to over a long period. But I would not "match" the amount of oil if it's that low. It's better to have a little more oil and maybe some decreased AC performance than to have too little and decrease the life of the components. When I spilled the oil out of my old compressor even while turning the clutch, only 15cc came out. I dumped the oil from the new one and 100cc came out. I added back in 100cc of PAG 46 with ICE (supposedly a lubricity additive) oil into the new compressor and it's been great, quiet, and cold/ in spec.
    According to Denso, approx 40-50% of the oil in your AC system resides in the compressor, the total amount of oil in a Tacoma AC system is 229cc.
    Check out my thread
    https://www.tacomaworld.com/threads...-compressor-how-much-oil-to-add.551444/page-2
  5. Sep 1, 2018 at 9:37 PM
    #65
    tony2018
    tony2018 Well-Known Member
    Ah yes, ac work. God I hated it.
    Don't forget new o-rings and add nylog to them.
  6. Sep 1, 2018 at 10:03 PM
    #66
    Shortman5
    Supercharged TRD
    I was trying to turn it. It’s tough to do holding the compressor with one hand and turning the clutch. Gets heavy quick.
    The reason why I’m changing is when the clutch engaged it wobbled. Even though the pulley turns true at all times. The only time it didn’t wobble was when I gave it enough RPM. It was weird.
    Looking at the compressors side by side the clutch gap on the old one is bigger. I suppose it’s possible a previous owner changed the clutch and messed up, or the spacer wore out. Rather than deal with a bits in the system after a failure or attempting to just change the clutch I just go a new one. It’s about time anyway at 120k.
  7. Sep 1, 2018 at 10:43 PM
    #67
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I gotcha. Well I would be on the conservative side when adding oil but I would still put in 60-80cc of oil into the new one. Then just follow the specs for the FSM when replacing the other components.
  8. Sep 2, 2018 at 10:55 AM
    #68
    Shortman5
    Supercharged TRD
    Oh. And I got 75ml of oil out of my new Denso compressor. I guess I’ll still add 100ml?
  9. Sep 2, 2018 at 2:49 PM
    #69
    Dirty Pool
    99 XCAB V6 MT TRD
    Same here, went with 100.
    ThunderOne likes this.
  10. Sep 2, 2018 at 7:39 PM
    #70
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I think you'd be good with that. 80-100cc.
  11. Sep 2, 2018 at 7:54 PM
    #71
    Shortman5
    Supercharged TRD
    Ended up going with 110 in compressor. Added 45 to condenser, 20 in drier, and just poured a little into the original evap. Might have a little too much. Should be okay I guess
  12. Sep 2, 2018 at 8:01 PM
    #72
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    That should leave 54 cc left in the system so if you only put a little in the evap you should be good.
  13. Sep 2, 2018 at 8:14 PM
    #73
    Shortman5
    Supercharged TRD
    Shit. I just measured what I had left over in a 8oz bottle. 100ml. Unless this stuff sucks in humidity being left out in a cup most the day somethings up.
  14. Sep 3, 2018 at 12:15 AM
    #74
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    No you are fine. That oil does soak up moisture quite fast though (which isn't good). Don't add any more.
  15. Sep 3, 2018 at 11:53 AM
    #75
    Shortman5
    Supercharged TRD
    So the OP mentioned that he didn’t close the manifold gauges when checking for leaks. Only the vacuum pump. The first time around I vacuumed down and closed the manifold then the pump. No leak for 30min.
    Next I did exactly that OP did except this time I get a pretty quick leak. Probably in less than 5 minutes it would be at zero. How do I know this is the truck and not the manifold or pump?
    I replaced every o ring and oiled each one. I didn’t hulk anything down either. It seems like it would almost have to be a pinhole in the brand new condenser or old evaporator for it to leak down that fast.
  16. Sep 3, 2018 at 7:11 PM
    #76
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    If you have a UV dye in your system you might have to check and see if there is a leak that way. Seems odd to me. Maybe get a shop to do a pressure test and see if they can come up with the same results
  17. Sep 3, 2018 at 7:36 PM
    #77
    Shortman5
    Supercharged TRD
    Not 100% sure but it would have to be the pump. The fact that you get any reading at all on the high side with the valve closed and charging tells you that you do get accurate readings with both sides set closed. Or at least I think so. I went ahead and charged it anyway. If I have an issue I’ll have to take it in. I was getting 50 degrees when all done.
  18. Sep 3, 2018 at 8:53 PM
    #78
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    50F idling or driving? Should be getting in the 40s
  19. Sep 3, 2018 at 9:01 PM
    #79
    Shortman5
    Supercharged TRD
    Both. I’ll have to check it again tomorrow. I don’t know that the deal could be.
  20. Sep 3, 2018 at 9:08 PM
    #80
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Might be too much oil or not enough R134... what was ambient temp at the time? What tool are you using to read temp? Checking from center vents?
