  1. Jul 31, 2023 at 2:22 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
  2. Jul 31, 2023 at 2:30 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Whatevers the best solution here I'm open to. Don't want to go out to a parts store in this heat if the maf isn't the culprit. Shits just scary when it goes limp mode on the road
  3. Jul 31, 2023 at 2:34 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    They’re acting like that many weights is normal. I’m fighting them on it but am I crazy?
    I’ve literally never seen that many before on a good wheel/tire combo. They can’t find my key either so that’s fun.
    Kwikvette likes this.
  4. Jul 31, 2023 at 2:52 PM
    Wulf
    rock raisin
    It's an artifact of the early 5VZE, only a handful of trucks had them. No idea about deleting it :notsure:
    Das it mang and 04Pre_Runner like this.
  5. Jul 31, 2023 at 2:53 PM
    eon_blue
    Azusa, CA
    don't buy a cheap aftermarket MAF, these old trucks don't like them
    You tried cleaning the one on the truck? Cleaning the one on my 4runner really helped with a wonky idle and throttle lag I was having
  6. Jul 31, 2023 at 3:05 PM
    Wulf
    rock raisin
    honestly it's worth teeing the lines together and trying to bypass the VSV to find out if that is causing the issue. I'm betting that it's there to help cold starts or something but probably isn't necessary in the southwest
    Das it mang[QUOTED] likes this.
  7. Jul 31, 2023 at 3:09 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    I taped it all back down and it still was doing it. (The vsv line) Already cleaned the maf sensor and still nothing. Happy coolant isnt going anywhere, but the maf comes as one unit like this:
    I bought the bse one from autozone. Will try it later, meh
  8. Jul 31, 2023 at 3:15 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Weird because as soon as I let off the throttle the truck starts again.
  9. Jul 31, 2023 at 3:17 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Sometimes you can rotate the tire on the wheel to offset each other a bit and reduce the number of weights
    jubei and Wulf like this.
  10. Jul 31, 2023 at 3:18 PM
    Speedytech7
    Send me your part number, I have my OEM one and it might be right for you truck
  11. Jul 31, 2023 at 3:20 PM
    eon_blue
    Azusa, CA
    That's the same kind of MAF my 96 T4R has. Different than the later 3.4 years. I was getting real low/near stalling idle occasionally and every once in awhile while accelerating it was like the truck lost 75% power before it would just surge back. Cleaned the MAF and never had either happen again. I would try cleaning it first if you haven't, I don't ever hear good things about those cheap MAFs on these trucks. If they work they don't work for long
  12. Jul 31, 2023 at 3:34 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Will do, lemme verify it's the culprit and ill return the autozone one once we link. Thank you
    It's all i have for now other than risking being rear ended if it dies on me. There's no denso version of this maf sensor, if zane can help me it'll be a good solution
  13. Jul 31, 2023 at 3:35 PM
    Speedytech7
    Wulf and 01x4[QUOTED] like this.
  14. Jul 31, 2023 at 3:40 PM
    eon_blue
    Azusa, CA
    01x4[QUOTED] likes this.
  15. Jul 31, 2023 at 3:41 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Still 5'7" :rofl:
    Good shit, definitely not the shortest king here :fistbump:
    Looks like Dan is
  16. Jul 31, 2023 at 3:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :luvya:
    Abeyancer, eon_blue[QUOTED] and 01x4 like this.
  17. Jul 31, 2023 at 3:50 PM
    04Pre_Runner
    Andrew
    No luck. They tried that and still almost a pound of weights at best. Getting with discount direct for replacement right now.
    And they found my lug key but I had to basically beg them. And it is proprietary compared to any Gorilla lug key they had.
  18. Jul 31, 2023 at 3:50 PM
    Speedytech7
  19. Jul 31, 2023 at 3:59 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Stare them in the eye.
    Clench it with your buttcheeks and flip it with one twerk.
    Assert dominance
    treyus30, Kwikvette and 01x4[QUOTED] like this.
  20. Jul 31, 2023 at 4:01 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Appreciate?
    No way.
    Flipping by hand is standard, any other way is punishable.
    01x4[QUOTED] and Abeyancer like this.
