2.5 inch lift questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kyleTRDtaco12, Feb 23, 2014.
  1. Feb 24, 2014 at 2:32 PM
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    You cannot set bilstein 5100 shocks at 2.5, let alone 1.75, with either of these "lift" springs. They are meant to lift the truck without pre-loading the coil like you would with a stock coil. You can set the billies to .85 with eibachs to get about 2.5" of lift. 884 coils in billies set at 0" will give you about 2" of lift and eibachs with setting at 0" will give about 1.6" of lift
  2. Feb 24, 2014 at 2:38 PM
    MagnumTaco
    MagnumTaco Well-Known Member
    Tony
    New Mexico
    Supercharger, Baja Suspension, TRD exhuast, Stealth pulley.
    Mine is set at .85 and all I have is 1.75 lift. I have the Baja set up.
  3. Feb 24, 2014 at 2:41 PM
    MTopp
    05 SR5 4x4
    What coils are you using? The baja uses different style bilstein 5100s from what I've seen
  4. Feb 24, 2014 at 2:42 PM
    MagnumTaco
    Tony
    New Mexico
    The ride height adjustable. Unless I have my height marks wrong. The spring is on the second mark, isn't that the .85? The red Eibach
  5. Feb 24, 2014 at 2:43 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Do some searching, you'll find that is the consensus. On the 2nd gens it doesn't really drop it, it more rotates it and doesn't net much gain in CV angles but exposes the differential to more potential for damage. Here's one thread but there are more: http://www.tacomaworld.com/forum/2nd-gen-tacomas/118545-remove-differential-drop-your-05-tacoma.html
    Yeah, I got the OME CB drop from Wheeler's Off Road when I bought my kit. I have the Dakar leafs though which lifted the truck about 2.5" so not sure if your situation will be exactly the same.
  6. Feb 24, 2014 at 2:47 PM
    MTopp
    05 SR5 4x4
    Yeah it should be and the ride height is adjustable. The OME and Eibach coils are longer and do not need to be pre-loaded to lift, unlike the shorter stock coil springs. I'm just not sure what coil springs you have, its possible to pre-load those springs, just not reccommended.
  7. Feb 24, 2014 at 3:45 PM
    MagnumTaco
    Tony
    New Mexico
    Is there a way to identify the coil springs?
  8. Feb 24, 2014 at 3:56 PM
    MTopp
    05 SR5 4x4
    Hmm, not 100% sure on that, I guess look at pics of each. But if all your suspension is OEM Baja stuff, then I'd guess its whatever comes with the Baja. I do not know much about their suspensions, but they are pretty nice
  9. Feb 24, 2014 at 4:12 PM
    MagnumTaco
    Tony
    New Mexico
    You have me wondering. I didn't order the Baja truck I asked the dealer to order the suspension and install it. I am wondering if I have the correct components. Because the shock is set at the second mark (.85) with the Red Eibach springs with a total of 1.75 inches. I am pretty sure the springs say TRD Eibach on them. Something isn't correct. Either my components are wrong or the Eibach springs set at .85 doesn't equal 2.5 inches?
  10. Feb 24, 2014 at 4:19 PM
    MTopp
    05 SR5 4x4
    Ohhh, hmm. I'd look up what the baja suspension comes with new, I think the eibach coils they use are different from the toytec ones. And I'm not 100% sure on the toytec eibach giving 2.5 lift at .85, but I know its usually more than 1.75. I do believe I read a thread that mentioned the Baja suspension gives you about 1.75" of lift though
  11. Feb 24, 2014 at 4:27 PM
    Drinknmolson
    Drinknmolson Well-Known Member
    Wheat Ridge, CO
    10 DCSB sport
    Get old man emu 885's put your billies to zero the 1.5 aal should sit you level @ 2.5" i have 884's in front and sit raked until loaded but i have a topper and body armor rear bumper. A lil stiffer but it handles really well on & off road.
  12. Feb 24, 2014 at 4:41 PM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Without reading the whole thread, the Toytec kit is quite different than OEM Baja kit AFAIK.
    Here are p/n for the Baja kit.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/277344-because-baja-24.html#post8242835
  13. Feb 24, 2014 at 5:36 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Baja setup does not use 5100s. It uses 9100s up front.
  14. Feb 24, 2014 at 6:01 PM
    bjboucher
    Brad
    San Antonio, Texas
    If you have adjustable front shocks and no external reservoir, you don't have the OEM Baja set-up. Here's what the Baja kit looks like:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/277344-because-baja.html
  15. Feb 24, 2014 at 8:42 PM
    #35
    Bosshoag
    Bosshoag Well-Known Member
    Mr. Doogan
    Virginia Beach, VA
    '20 4X4 TRD Off Road MT
    I'm here for knowledge folks, please feel free to inform me. Expedition Essentials Track Mount Weather Tech floor liners and window vents K&N air filter Summit Dakars in Matte Bronze -25 offset King suspension from Filthy Motorsports MESO customs white/red interior lights and MESO customs gasshole
    So it seems as though we can conclude that putting 884 coilsprings on bilstein 5100's set to zero is the cheapest and probably most similar feel to stock way to achieve 2" of lift in the front of a 2008 Access cab TRD Sport. Am I right?
    I'm not going to sleep tonight until I figure out the answer to this question. I worked 14 hours today and have to again tomorrow guys. please help.
  16. Feb 25, 2014 at 12:33 AM
    #36
    kyleTRDtaco12
    kyleTRDtaco12 [OP] Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    x2 yes, the OEM facroty baja setup front coil over struts are not adjustable and have a signifying 'TRD-Bilstein' sticker on them, and the rears have the same stickers with the 5100 rear shocks with the remote reservoirs
  17. Feb 25, 2014 at 12:42 AM
    #37
    kyleTRDtaco12
    Kyle
    New Jersey
    I second this 100% because this is what I was under the impression of and I was just waiting for somebody to confirm it.... I totally messed up because back when I was doing my 5100 lift in the first place the TSB springs we just becoming standard issue on the 2012 tacos, and I made the mistake of taking the advice of someone who used the .85 setting to perfectly level their 4 cylinder 4x4 access cab taco (being it was a 4 cylinder it only had the 3 leaf pack) but me having a 6 cylinder 4x4 with the 4 leaf TSB springs (and not realizing I had the TSB springs pre installed until after the fact lol) I mistakingly set them at .85 instead of 1.75.... does the alignment still come out ok if the billy's get set to 1.75??
  18. Feb 25, 2014 at 1:00 AM
    #38
    kyleTRDtaco12
    Kyle
    New Jersey
    BTW thanks all for the great replies, you guys are awesome!!
  19. Feb 25, 2014 at 3:42 AM
    #39
    MTopp
    05 SR5 4x4
    The alignment should be alright with that setup, most people would recommend you get new upper control arms if you lift 2.5" or more because that's when your caster starts getting impossible to be adjusted with stock UCAs
  20. Feb 25, 2014 at 5:16 AM
    #40
    Drinknmolson
    Wheat Ridge, CO
    10 DCSB sport
    Yep
