2.7L MPG
Discussion in '4 Cylinder' started by dustinclm, Oct 12, 2010.
  1. Oct 13, 2015 at 3:45 PM
    #461
    EvilBetty
    EvilBetty Well-Known Member
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    New plugs at 145k - Looks like I'm back to original MPG.
  2. Oct 14, 2015 at 11:46 AM
    #462
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    The bed cap is what's killing your fuel economy unfortunately. It essentially gives your pickup truck the aerodynamics of an SUV.
  3. Oct 15, 2015 at 12:06 AM
    #463
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Now that I only drive 5 miles to work, I'm getting around or just under 20 mpg so my average will keep decreasing a bit. Still it's not too bad for a 4200-pound 4x4 in the snowbelt without intentionally hypermiling. 90% of this graph is on cruise control.
    All numbers prior to the N30 speedo gear install that corrected the odometer were adjusted down accordingly (that's why it says added dec 2014, I edited the original mile data in libreoffice and added as a different vehicle after I goofed trying to upload to my original one). It was 4% fast with the stock N29 and factory tire size which artificially inflated mpg. Current best 26.3 mpg, lifetime avg 22.8 mpg over 103 tanks of gas
  4. Oct 17, 2015 at 8:32 PM
    #464
    gofas
    gofas Well-Known Member
    Russell
    Ukiah
    4x4 Timberland Mica Access
    ImMrYo review mirror bracket.
    I drive stop and go with 7 mile freeway bit going fast. I have the hi topper as well.
  5. Oct 18, 2015 at 4:51 AM
    #465
    Big Joe A
    Big Joe A New Member
    2015 AC Barcelona Red
    Greetings,
    My truck is a 2015 4WD AC 5 speed SR5. The truck has about 8000 miles on it and I picked it up in mid August.
    My drive to work is 72 miles each way. All but 4 miles is highway.
    I fill up every three days and my best tank so far is 26.4 and my low is 22.7. The main difference in fuel mileage is traffic issues on the mass turnpike.
    The truck has rear Firestone air bag set up and a K&N air filter.
    I am not familiar with "corrections" but that is calculated off trip A.
    Best regards,
    Joe
  6. Oct 18, 2015 at 5:18 AM
    #466
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    Welcole to TW!
    Is your truck stock? What speed are you driving? Asking because when I do mostly highway I drive around 65mph and don't get better than 23. And 23 is kinda hard to get haha mostly 22.5
  7. Oct 18, 2015 at 6:01 AM
    #467
    gofas
    Russell
    Ukiah
    I thought our speedometer and odometer are 2 separate units for some reason? My speedo is off. I keep buying 245's for tires.
  8. Oct 19, 2015 at 9:25 AM
    #468
    Big Joe A
    Greetings,
    My truck is completely stock with the exception of a K and N air filter, Firestone rear air bag suspension (Manual, no on board air, set at 5-10 PSI) and a tonneau cover.
    I drive between 65 and 70 and occasionally get to 75 -80 to pass or clear traffic. I some times throw the truck in neutral down steep hills.
    If I drive 70-80, the whole week, my mileage drops to 23. Remember in an average week, I drive 720 miles with 680 miles of interstate.
    Easy throttle helps with mileage and I have noticed that on my motorcycles more than my cars....
    Best regards,
    Joe
  9. Oct 21, 2015 at 9:33 PM
    #469
    iroh
    michigander
    tonneau
    With 245/75-R16 tires my speedo was 10% too high and the odometer was 4% fast.
    With the N30 gear it's something like 5-6% high for the speedo and about 0.6% fast on the odometer. Yes, Toyota actually programmed the needle to go up faster than it should... it's not an offset problem with the needle.
  10. Oct 21, 2015 at 9:48 PM
    #470
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    I have a 2001 2.7L regular cab 4X4 5-speed manual. 265/70r16 AT tires. No camper shell but I have a tool box with about 80 lbs. of crap in it. Engine and all drivetrain oils are synthetic. Here is my MPG for every tank since I got my "new" 1st gen:
    Tank 1: Shell 91 octane, 90% city, 10% hwy, pre-deckplate: 20.85 MPG
    Tank 2: Shell 91 octane, 10% city, 20% off-road, 70% hwy, pre-deckplate: 21.10 MPG
    Tank 3: Shell 91 octane 85% city, 15% hwy, deckplate open: 22.95 MPG
    Tank 4: Shell 88 octane 70% city, 10% off-road, 20% hwy, deckplate open: 22.85 MPG
    Tank 5: Sinclair non-ethanol 88 octane: 70% city, 10% off-road, 20% hwy, deckplate open: 24.65 MPG
  11. Nov 5, 2015 at 4:49 PM
    #471
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    2013 AC 2wd auto trans., no top @ 11,500 miles
    stock Dunlop AT20s (P215/70R15): 35 psi front, 35 psi rear
    almost 100% city
    no towing, no heavy loads
    all near sea level
    driving habit: *GGDRS #4-5
    last tankful- 21.6 miles/gal.
    *http://www.tacomaworld.com/forum/per...reporting.html
    Winter gas blend decreasing my mpg? I was averaging 24-25 mpg July into early Sept. Since then I've been averaging about 21.5-23 mpg.
  12. Nov 16, 2015 at 11:16 PM
    #472
    Lt_Dan
    Lt_Dan Well-Known Member
    Daniel
    Cincinnati OH
    2017 TRD OR 4x4 DCSB A/T Super White
    Excuse my ignoranve, but what do you mean when you say "deckplate open"? what deckplate are you talking about? I'm interested because it seems like it improved your mpg
  13. Nov 17, 2015 at 5:14 PM
    #473
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
    2013 AC 2wd auto trans., no top @ 11,800 miles
    80% hwy 20% city
    all near sea level
    last tankful- 24.8 miles/gal.
    Improvement from last tankful, probably due to a lot more highway (interstate at 55 mph) mileage.
  14. Nov 17, 2015 at 5:19 PM
    #474
    DJB1
    Dave
    SLC, UT
    Lt_Dan likes this.
  15. Nov 17, 2015 at 5:28 PM
    #475
    Lt_Dan
    Daniel
    Cincinnati OH
  16. Nov 17, 2015 at 9:21 PM
    #476
    DJB1
    Dave
    SLC, UT
    No tears, @Lt_Dan ....Your 2.7L has a better aftermarket supercharger than mine.
  17. Nov 17, 2015 at 9:47 PM
    #477
    Lt_Dan
    Daniel
    Cincinnati OH
    I wouldn't buy a supercharger for this truck lol
  18. Nov 17, 2015 at 9:53 PM
    #478
    DJB1
    Dave
    SLC, UT
  19. Nov 17, 2015 at 9:56 PM
    #479
    Lt_Dan
    Daniel
    Cincinnati OH
    Jesus Christ, he turned that 4 cyl into a beast. I don't see myself doing that though, my plan is to put 200k miles on this truck (I'm at 116k right now) and then get a brand new one, 6 cyl.
  20. Nov 21, 2015 at 1:05 PM
    #480
    TacoGlenn
    PNW
    '13 MGMAC 2.7L SR5
    2013 AC 2wd auto trans., no top @ 12,400 miles
    90% hwy (a lot of flat interstate at 55 mph mileage) 10% city
    all near sea level
    last tankful- 26.8 miles/gal.
