2005 GEAR SELECTOR ISSUES
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Paulrv6, Oct 10, 2019.
  1. Oct 10, 2019 at 5:25 PM
    Paulrv6
    Paulrv6 [OP] Well-Known Member
    paul
    2005 Tacoma
    If I leave my truck sit for a couple days the shifter is very difficult to move into any gear and sometimes I can't get it into D, and the console light does't show the gear until I wiggle it. It feels like something it just really gummed up and not smooth acting like when it was new. Any known problems with other 05's where this is happening? Once I get it moving it isn't bad but still not as smooth as it used o be. I only have 60K on the truck, not sure if that makes a difference. Thanks for the help.
    paul
  2. Oct 10, 2019 at 7:43 PM
    Muddinfun
    Muddinfun Well-Known Member
    Most likely thing is a corroded up neutral safety switch on the right side of the transmission. Hose it down with your favorite penetrating oil. If that frees it up, you need a new one.
    gearcruncher, Jimmyh and TnShooter like this.
  3. Oct 10, 2019 at 7:55 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  4. Oct 12, 2019 at 6:25 AM
    Paulrv6
    paul
    2005 Tacoma
    Is there a written procedure to follow for replacing the NSS? Do you have the P/N for a new one? Just planning ahead for my next project. Thanks allot.
    paul
  5. Oct 12, 2019 at 7:56 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Look at the picture in the linked post...
  6. Oct 12, 2019 at 9:44 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    1. unplug electrical connector.
    2. Pry the lock fingers back away from the lock nut corroded over the shaft and loosen nut.
    3. remove the switch retaining bolt
    4. remove old switch
    5. install new switch reverse order
    Note you may have to loosen the bolt in #3 and adjust/align the switch so that when shifter is in neutral the shaft (longer sides) are aligned with the vertical line on the switch housing (between electrical connector and bolt) and then tighten the retainer bolt.
  7. Oct 13, 2019 at 7:03 AM
    Paulrv6
    paul
    2005 Tacoma
    Is it best to stick with OEM or go aftermarket? Do you know the P/N if I go with Toyota? Thanks
  8. Oct 13, 2019 at 11:26 AM
    muddog321
    FL
    As in the pic they said it was in above.
    Around $100 dealer online.
    The vehicle options this part fits:
    Production Date: 09/2004-09/2011
    Fitting Vehicle Options: GRN245, 250, 265, 270.. 5FC
    Toyota Part No.: 84540-04010
    SWITCH ASSY, NEUTRAL START
    Jimmyh likes this.
  9. Oct 13, 2019 at 8:06 PM
    Paulrv6
    paul
    2005 Tacoma
    I see that now, sorry. What about any adjustments after the install? Are there certain things that have to line up? Thank you
    paul
  10. Oct 13, 2019 at 8:43 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Muddinfun likes this.
  11. Mar 28, 2020 at 9:28 AM
    Paulrv6
    paul
    2005 Tacoma
    I was just going to order this part. Before I do I wanted to check and see if I wouls need anything else to go along with it from the dealer, fasteners, etc? Thanks
    paul
  12. Mar 28, 2020 at 3:47 PM
    Paulrv6
    paul
    2005 Tacoma
    Do you need any new bolts, etc from the toyota dealer? Thanks
    paul
  13. Mar 29, 2020 at 6:32 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    You shouldn't unless you strip or break one.
  14. Mar 29, 2020 at 6:45 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
  15. Mar 29, 2020 at 10:21 AM
    Paulrv6
    paul
    2005 Tacoma
    Any idea why the link no worky?
  16. Mar 29, 2020 at 7:02 PM
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    OP ... I have a 2005 with only 50,000 miles and have experienced the same thing as you. What I found is that is that I normally park on the right side of my driveway and it has a reasonable decline. People here who are far smarter than me might have a better explanation but I found that once I back out of the driveway, level out and drive for 10 minutes everything is back to smooth. Probably not the same problem that you have but it might be worth parking on a level surface and seeing if you still have the problem. As soon as I started parking on the street the problem disappeared. If that makes sense.
  17. Mar 30, 2020 at 7:18 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes it doesn't work any longer as they killed the web site that hosted the old files... :(
  18. Mar 30, 2020 at 7:28 AM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    Apologies for going off topic, but you have 60k and another one above mentions 50k miles for a 2005. My 2005 has 160k miles and I thought that was low :) Awesome I hope the NSS fixes your issue.
  19. Mar 30, 2020 at 8:00 AM
    averagejp
    Work in progress
    Ha! I got lucky when I bought mine used a few years ago. It was purchased by a guy out on Long Island who only drove it to the beach and back when he was surfing so it had super low miles. I only drive on the weekends so my mileage is really low. And -- 160K is low! :).
    Sad thing is I am looking to sell because it is an AC (which I like) and with my growing kid and soon to be two dogs (plus wife) it is getting pretty cramped.
    I am following this thread in case I have this problem. How is yours holding up?
  20. Mar 30, 2020 at 11:17 AM
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    i'll be actively looking for a 2nd gen AC in 2 years for my kids so i'll archive this and check back -- maybe you'll still have it. Ha. Mine's great. Trouble free and I like the fact that I can tinker with it, learn, and be comfortable that I have this great resource when I screw up.
