2006 Tacoma PreRunner 2nd Gen Lower Ball Joint Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BandanaBerg, Oct 3, 2017.
  1. Nov 22, 2017 at 8:06 PM
    #41
    BandanaBerg
    BandanaBerg [OP] Yotas Yotas Yotas Pocast
    Phoenix,AZ
    2010 DCLB SR5 4x4
    Up Front; Icon 2.5 Extended w/ Fox 600s, Icon Delta Joint UCAs, Poly Performance Taco Tabs, BAMF Hybrid Bumper, Pelfreybilt Legacy IFS Steel Skid, RCI Transfer Case Skid Out Back: Archive Garage Hammer Hangers w/ High Clearance Cross Bar, OME Dakar Expedition Pack, Icon 2.0 RR, All Pro U-Bolt Flip w/ Super Bumps, All Pro Extended Brake Lines, Trail Gear Rock Assault Bumper w Custom Swing Tire Carrier Wheels & Tires: Pro Comp 5001 Wheels 16" on some 285/75/16 BFG AT KO2, ARB Single Compressor Up Top & Around: RCI 5° Rock Sliders, CaliRaised LED Premium Roof Rack w/ CaliRaised LED Dual Function Light Bar, CaliRaised LED Amber Fogs in CaliRaised LED LED Fog Light Pod Replacement Brackets, Anytime Fog Mod, CaliRaised LED Ditchlight Fogs on CaliRaised LED Low Profile Ditch Light Brackets, Voswitch UV100 Switch Controler, Chineseum Chase Ambers & reverse/camping LEDs Misc Thangs: Tech Deck w Ram Ball Mounts, Expedition Essentials 2nd Gen Rail w/ Ram mounts...
    The pic of the Moog BJ on the OP is how it came out of the box and how I installed it.
  2. Nov 22, 2017 at 8:18 PM
    #42
    TjAlmeida
    TjAlmeida Active Member
    2012 Tacoma
    Ok good to know. I guess ill go back in there tmrw and take off the large boot. I appreciate the response! Did you kit come with large boots or no? May have to bring it up with the shop just to see if they used their own boots or not.
  3. Nov 22, 2017 at 8:31 PM
    #43
    BandanaBerg
    Phoenix,AZ
    2010 DCLB SR5 4x4
    That’s how it came out of the box...
  4. Nov 23, 2017 at 3:48 PM
    #44
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    Post a pic of this outter boot you're talking about
    BandanaBerg[OP] likes this.
  5. Nov 23, 2017 at 4:00 PM
    #45
    TjAlmeida
    2012 Tacoma
    I just got it sorted out today, turns out when the shop ordered in the ball joints they got one of the newer design and one that is the older design. So one looks like a traditions lower ball joint, and the other has this updated integral boot design. I would take a picture but i just cut off the larger dust boot on the new design ball joint. So the shop must have put their own boot on the new design, they had put a boot similar to the one in the picture on the older design on to the ball joint with the new design.
  6. Nov 23, 2017 at 6:45 PM
    #46
    BandanaBerg
    Phoenix,AZ
    2010 DCLB SR5 4x4
    Ahhh...
  7. Nov 24, 2017 at 7:26 AM
    #47
    99TacoDriver
    South Louisiana
    Oooooo aaahhhhhh looks cool
  8. Dec 16, 2017 at 7:02 PM
    #48
    mbroughton02
    mbroughton02 Well-Known Member
    Michael
    Cortland, NY
    07 DCLB
    OME 884, 5100s, Wheeler's 1.5" Progressive AAL, Firestone Ride Rite, Fisher Homesteader 7'4" Plow, Heated Seats, Viper 5806v Remote Start / Alarm.
    Just did this today on my '07 4x4 with about 115k miles. Took all day! Most of that time was spent getting the steering stop off and the old BJ pressed out. We have a lot of salt on our roads in the winter and everything was just so rusted together. I did get the 23 piece kit that others have mentioned- Advance Auto had it. But I had to make a second trip into town to rent a puller from Autozone to get the steering stop off:
    Once I got all the old parts off, reassembly only took an hour or so.
  9. Dec 16, 2017 at 8:31 PM
    #49
    BandanaBerg
    Phoenix,AZ
    2010 DCLB SR5 4x4
    So...
    I recently saw/watched a video on removing the steering stop. Have not tried the technique yet...
    What he did was remove the pin/nut from the ball joint stem before removing the stop from the spindle and then used the jack to push up on the LCA to dislodge the ball joint stem from the stop and then remove the stop from the spindle...
    Looked as though that might be an easier way.
    I will definitely give that a go on my next Ball Joint replacement as I did struggle a little to get that steering stop off with the hammer.
    99TacoDriver likes this.
  10. Jan 4, 2018 at 9:29 PM
    #50
    Muy Grande
    Muy Grande Well-Known Member
    Dallas, TX; RGV, TX
    06 DC TRD
    Suspension: DHoes up front, Dakar and OME out back. Audio: Alpine w205 w/ pair of Alpine Amps, Image Dynamic 6.5 Component Speakers up front and Image Dynamic Subs in the Back. Armor: ARB Bull Bar, Rocktek rear bumper and custom rock sliders. Other: Rigid Industries LED Light Bar, Platinum DieHard Battery, BlueSea Fuse Block, rear lights, bed lights, leds inside.
    Easier way to remove the stop is to take a 2lb hammer or more and give it one nice whack. It'll pop right off. I did buy a ball joint separator and it wouldn't fit so at least i tried the right way.......then I just looked at it and figured it would pop right off with one good hit. Done.....super easy.
  11. Jan 4, 2018 at 9:33 PM
    #51
    Muy Grande
    Dallas, TX; RGV, TX
    06 DC TRD
    Also I'm in the process of doing this project while I wait for my Icons to show up after being rebuilt for the second time within 1 yr. I have learned that taking the lower control arm to a shop and spending $30 to press out the old and press in the new is money well spent. I have done it the old way with the press and destroyed 2 from Auto Zone and took me a while to get the old one off and the new one installed. Lesson learned from doing the first time.
    lo2hi and BandanaBerg[OP] like this.
  12. Jan 5, 2018 at 5:49 PM
    #52
    mbroughton02
    Michael
    Cortland, NY
    07 DCLB
    Yeah...I hit it with a 2 lb hammer about 100 times. And then I moved up to the full on sledgehammer. Didn't work. We have a lot of salt on our roads up here. That thing was not coming off without a puller.
  13. Jan 5, 2018 at 8:55 PM
    #53
    Muy Grande
    Dallas, TX; RGV, TX
    06 DC TRD
    Damn, I live in South Texas so yeah lucky for us we don't have to deal with Salt and we have very mild winters. I can see how this would be a problem.
  14. May 10, 2018 at 5:20 PM
    #54
    BazzokaJoe
    BazzokaJoe Well-Known Member
    Olivier
    Canada,QC
    TRD OffRoad
    Nice job!
    i just got the new moogs how much the boots inflate when you pump greases in it i just dont whant to blow it up lol
  15. May 10, 2018 at 5:42 PM
    #55
    TjAlmeida
    2012 Tacoma
    Until a little comes out the bottom, or visually/hands on. The boot will be fairly firm when you pinch it if it's full.
  16. May 10, 2018 at 6:40 PM
    #56
    BazzokaJoe
    Olivier
    Canada,QC
    TRD OffRoad
    Thanks!
  17. Jun 10, 2018 at 4:23 PM
    #57
    DirtyArmor
    DirtyArmor Active Member
    Paul
    2008 Silver/Black Tacoma 4x4
    Blistein 5100's, 1" add a leaf, frontline grille guard, 265/75r16 coopers, herculined grille/bumpers/fenderflares. TACO truck ;)
    I replaced mine jan of 2017 @ 177,500 miles. Im now at 197,420... almost exactly 20,000 miles and just over a year. Both moog BJ’s bought from an authorized dealer, properly installed and greased at every oil change, have failed.
    The driver side boot (new boot design) tore within a month of the install. I dont offroad often or on any extremely technical trails (although I’d like to). Im extremely disappointed, after the trouble of replacing them, for them to fail so quickly is shit.
    BandanaBerg[OP] and lo2hi like this.
  18. Jun 12, 2018 at 9:59 AM
    #58
    Canoehead
    Canoehead Well-Known Member
    Duncan
    Dartmouth, NS Canada
    2007 DCSB, lots of scratches
    Rearview mirror upside down mod
    Seems to me that there are no aftermarket parts that can compare to the factory assemblies. I am considering replacing my LCAs with Toyota parts next time around, maybe we can get 100k out of the ball joints that are factory mated to the LCAs and sealed?
    Otherwise I figure I am changing lower ball joints every year or two, and I'll make sure I stockpile a few bought at the best rate I can get. I figure the job isn't that bad once you've been through it the first time. Rockauto can get the parts to me for less than $50 per.
  19. Aug 6, 2019 at 8:33 AM
    #59
    Carl_z33
    Carl_z33 Well-Known Member
    Carl
    2014 Toyota Tacoma TRD OR 4x4 DCSB
    When you removed it, what size receiver did you use?? I’m currently struggling with auto zones kit & none of them seem to be a good fit! Either too large or too small
  20. Aug 6, 2019 at 12:28 PM
    #60
    BandanaBerg
    Phoenix,AZ
    2010 DCLB SR5 4x4
    I don’t recall the exact size... it was large enough to allow the BJ to pass through and out of the bottom. I believe I used 2 pieces, one was the multi size base tool & one the pass through cylinders. It doesn’t have to be perfect just large enough for the BJ to fit into it...
