2007 lsd?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kirkofwimbo, Jul 17, 2010.
  1. Jul 17, 2010 at 8:21 PM
    kirkofwimbo
    kirkofwimbo [OP] Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Im looking at buying a 2007 tacoma. Its a 4wd SR5. My only question about it is if it has an lsd or not. the only toggle it has to the left of the steering wheel is the one for the fog lamps. I know that it comes with EBD but am not sure what all the EBD entails. any info would be greatly appreciated
    Kirk
  2. Jul 17, 2010 at 8:33 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    If it's a TRD Sport, then it will have the LSD. But if it's simply an SR5, then you'll need to look underneath to tell. The LSD has a sticker on the back that says LSD Oil Only.
    As far as EBD, here's a link to Toyota's glossary of all their electronic gizmo/doodads. It gives a good description for the EBD:
    http://www.toyota.com.au/glossary
  3. Jul 17, 2010 at 8:43 PM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Ok so it EBD has nothing to do with the lsd?? The guy at the dealership told me that it had a system that uses the brakes to mimic an lsd...is that not true?
  4. Jul 17, 2010 at 10:16 PM
    myname150
    myname150 Well-Known Member
    Hahahah that is the biggest load of crap ive ever heard. Alot of these sales people just want your money. Like one time i called my local toyota dealer asking about rear lockers and ALSDs on the Tundras. i asked to speak with a sales rep, and all he did was just repeat what ive already read on the brochure and on the tundra's website
    EBD (Electronic Brake Force Distribution) Helps reduce body movement when brakeing by adjusting how much brake pressure goes to each of the wheels, thus reducing stopping distance...
    While toyota's ALSD (Automatic Limited Slip Differential) works by using the brakes and ABS system to apply brake pressure to the slipping wheel. So that the wheel with traction gets the power, not the one thats slipping.
    You can simulate an LSD or a rear locker on a truck with out that, just push down on the parking brake pedal enough so it will grab and not allow the rear wheels to spin at different speeds. In essence simulating a rear locker. Ive tried it and it kinddaa works lol.
  5. Jul 18, 2010 at 5:12 AM
    05Moose
    Jim
    He's talking about how the 09+ tacomas all have a simulated LSD which uses the brakes (but that isn't the same as EBD). EBD has to do with braking, LSD has to do with traction during acceleration. Two totally different situations.
    If you're looking at an '07 like you said, then it could have a mechanical LSD (05-08 Tacomas). The mechanical LSD has hardware in the rear differential, whereas the simulated LSD in later years doesn't. And if you're wondering about differences in the two, here's people's opinions:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/81272-mechanical-lsd-vs-auto-lsd.html
  6. Jul 18, 2010 at 5:16 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    the mechanical LSD on an 07 should have a sticker on the rear diff that is white and has "LSD OIL" written on it. look at the rear diff from under the truck at the tailgate. like stated above, if it's a sport, it has the LSD
  7. Jul 18, 2010 at 6:25 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    A mechanical LSD, like those made by Torsen or Quaife, cannot be disabled by a button on the dash.
  8. Jul 18, 2010 at 8:21 AM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    cool thanks for the info guys. i just found it kind of hard to imagine that there is a nice 4 wheel drive truck with open diffs but it is looking like that is the case, kinda pointless if you ask me.
  9. Jul 18, 2010 at 8:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not unusual. Nissan, Ford, Izuzu, Dodge all have 4x4 trucks with open rear diffs. I think Chevy is the only one that has a traction aid as standard equipment.
  10. Jul 18, 2010 at 10:56 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    They all have open diffs unless you pay extra to get limited slip or locker. Nobody puts standard because majority of people dont want to pay extra. and the small % that buys them specifically asks either for limited slip or a locker.
    I have 07 and I specifically requested to have Limited slip (mechanical) I made salesman to show me on all invoices that truck has one.
