2008 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rus maru, Mar 7, 2016.
  1. Mar 7, 2016 at 8:04 PM
    rus maru
    rus maru [OP] Member
    bill
    safety harbor, fl 34695
    2008 toyota tacoma
    fan switch only works on hi? Wild bill
  2. Mar 8, 2016 at 7:10 PM
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    T-SB-0149-11
  3. Mar 8, 2016 at 10:27 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  4. Mar 11, 2016 at 7:25 PM
    rus maru
    bill
    2008 toyota tacoma
    some times my a/c light flashes on and off when the air cond is running we correct this by turning thea/c on and off then the light stays on as it should be when a/c is running any help,, thanks rus maru...also we r& r fan resistor it works fine now...
  5. Mar 12, 2016 at 6:01 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    When the AC clutch engages there is a switch that monitors the compressor rotation. If it sees that the AC is On and the Compressor isn't turning it shows that fault code.
    It appears that either your clutch is defective or your compressor is starting to lock up.
