2010 radio tone volume issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by widget, Jan 28, 2010.
  1. Jan 28, 2010 at 8:51 PM
    widget
    widget [OP] Well-Known Member
    TN
    2010 Prerunner double cab
    Has anyone experienced a "change" in the tone dynamics and/or volume on the basic factory CD (not changer) unit? I've hearing good range and then it will flatten out and the volume seems to drop a bit and then it will pick back up. It's bugging me and I'm not sure what to make of this since it doesn't seem to do it all the time. Could this be a "known issue" and someone out there can advise the best way to address? - thanks in advance!
  2. Jan 29, 2010 at 7:30 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Are you sure the automatic volume control isn't on? I think it's call ASL(?). It will increase the volume at high speed and lower it at low speeds.
  3. Jan 29, 2010 at 5:26 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    ASL x2
  4. Jan 29, 2010 at 6:11 PM
    braggman7
    braggman7 Well-Known Member
    GA
    '23 Trail Edition
    22/m/nc
    sorry couldnt resist
  5. Jan 29, 2010 at 6:47 PM
    widget
    TN
    Thanks so much for the feedback, I'll ck out the ASL option but am a bit surprised that it would alter the tone to such a degree. Will report back with results.
  6. Jan 30, 2010 at 9:22 AM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    Does the base single-CD radio even have ASL? I don't think so. Mine ('09) doesn't anyway. I have noticed the "tone" change you describe when listening to the radio (not CD or my iPod via the AUX input). It sounds more like the unit switching from stereo to mono to me. These radios are garbage... mine has terrible FM reception. HERE'S a 12-page thread of people complaining about defective base model radios. My original went bad the second day I owned the truck - and the replacement went bad within a couple of months. It's still intermittent, so I'm still using it - but the next replacement will be a decent aftermarket unit.
  7. Jan 30, 2010 at 9:26 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    wouldn't it be
    22/m/nc
    22/m/nc
    He did ask for it twice!! lol!
    but yeah, If the volume comes down at a light, or stop sign I would think it to be the auto something limiter.
    My 09" single disk has it.
  8. Jan 30, 2010 at 10:30 AM
    OZ-T
    Peter North
    British Columbia
    HA HA , very good ,
    OZ
  9. Feb 3, 2010 at 7:51 PM
    widget
    TN
    For the record, 2010 basic radio/CD does have the ASL option and it was on. I turned this option off and have not noticed the tone or volume fluctuation. I appreciate the feedback! Now I'd like to figure out the deal on the sat radio: 1. why is it so high through the dealer option - is it somehow built in to the existing tuner or 2. are they just selling you an add on radio and wiring it into the head unit. Toyota option info is very vague.
  10. Feb 3, 2010 at 7:59 PM
    TexasTacoma37
    The radio comes satellite capable, and all of the wiring for the antenna is there. All you need is the the xm "tuner", and a "fit kit" (which is a bunch of wires with the correct connectors). You can get these on trdparts4u.com for around $300. The install doesn't even require removing the dash! the wires just plug into some jacks under the kick plate of the driver side door. It took me less than 20 minutes to complete.
  11. Feb 3, 2010 at 8:05 PM
    widget
    TN
    Do you know if the tuner kit you reference, is it something that can be bought from the XM site? It seems to be terribly expensive from toyota (or even trdparts4u) when you compare it to the cost of xm radios.
    Also, you mentioned the kick plate install on the driver side door - is there any instruction/direction available online to possibly illustrate and assist?
  12. Feb 4, 2010 at 5:49 AM
    TexasTacoma37
    You can buy a tuner from XM, but it wont have the connections for plug and play into the truck. You'll just have a more tedious install, more like an aftermarket radio would be.
    Here are the instructions for the install of the toyota kit.
  13. Feb 4, 2010 at 6:44 PM
    widget
    TN
    That's what I don't want, aftermarket type thing. (I see pics here of radios clipped to air vents or in mounted in the compartment above the drink holders and really want to avoid something like that if at all possible.) I don't understand why Toyota is so vague/non-descrip about this option. About the only info I could find previous to here was just an XM logo and reference back to a dealer. And to me, this isn't a cheap $20-$50 option.
    THANKS SO MUCH KPT for all the info and especially the PDF, YOU ROCK!
  14. Feb 4, 2010 at 6:59 PM
    TexasTacoma37
    No problem. PM me if you need help with the install.
  15. Feb 4, 2010 at 7:40 PM
    Raven65
    Camden, SC
    Please pass the crow. My radio DOES, in fact, have ASL (although it was turned off).
