2014 Access cab sub options?
Discussion in 'Audio & Video' started by Taco D'Voe, Feb 21, 2014.
  1. Feb 21, 2014 at 9:59 PM
    Taco D'Voe
    Taco D'Voe [OP] Active Member
    none so far!
    Hi folks. I'm looking around to see what's available for the '14 access cab design. In my 2010 AC, there was a sub on the back wall and a console in between the back seats but now its just a flat tray and the seat belts. Does anyone have a box suggestion that is known to fit this latest design?
    Thanks in advance!
  2. Feb 22, 2014 at 6:01 AM
    weendoggy
    weendoggy Well-Known Member
    Aptos, CA
    2014 TRD ACOR 4x4
    Access Original Tonneau Cover; Toyota Side Tube Steps; Focal ISS690 front speakers; Clarion XC1410 mini amp; Gentex 453 rearview mirror with Homelink, Compass, Temp and Autodim; Prodigy P2 trailer brake controller, Heated Seats from www.cobraheat.com, BriteAss Fogs, Phillips Extreme LED H/L. Heated mirrors from @Up2NoGood. 5100 Bilstein all four corners.
    You must of had the JBL system in your old truck. I had the same and sound was great but the box/console back there took up room. My new 2014 is like your AC and am looking at converting to a powered sub/woofer combo right now. I've been locally to our stereo shop but I don' t like the LOC he wants me to use. To simple so I'll be back with more info on my truck. I believe we have six (6) output speaker wires and if so I think we'll need a LCQ1 control unit and then a sub/woofer like the Focal iBus series. The sub should fit under the seat. Some are using Sound Ordnance and Kenwood units.
    I need to find out how many speaker wires on our radio's need to be tapped. If it was just two, we can get by with a simple LOC. However, after researching a multi port LOC would be better for tuning the system when done.
    I'll be doing mine in the next month once I have all my info straight and put a post here for others. Right now I'm doing the autodim mirror install.
  3. Feb 24, 2014 at 12:07 PM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    yeah I'd be interested in price/results when you're done. my 2014 has pretty subpar sound. only complaint about the truck...
  4. Feb 28, 2014 at 3:15 PM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Updated Post 3/11/2014
    Following this post http://www.tacomaworld.com/forum/audio-video/318970-line-out-converter-help-needed-harness-wires-tap.html it was discovered that the wiring in my .pdf is not all correct. The colors are correct but the connections are not all correct. The factory "phases" the tweeter or mid-range speaker. So the wiring is neg to pos and pos to neg for it, but pos to pos / neg to neg on the 6x9 speaker. So, I'll be pulling my panels and just changing my 6x9 wiring to be pink + and purple - to the speaker. I've also updated my .pdf attached to this thread.
    I can tell you that I will be using the Focal IBus 2.1 amp/subwoofer when I connect it to the system. Using it means there's no LOC that is needed because it's built into the unit.
    Haven't done the amp/sub install yet, but I did do an upgrade to my speakers. What a difference! I have a short YouTube video here http://youtu.be/DYBBrAOKvu0 to let you hear the difference. I know it's not a professional test, but it was done in good faith. Same before and after settings including the song, ipod, camera and placement. Even my wife noticed the difference. I also have a .pdf document attached that details the install but I've put some photos here to help a little.
    My goodies! Focal ISS 690's, spacers and HushMat kits.
    HushMat installed in door along with the WaveBeater behind speaker area
    Tweeter wiring showing before/after modification and soldering.
    New ISS690 ready to install.
    Tweeters in new brackets.
    Speaker comparison. I think you can tell the difference.
    Door ready to have the panel reinstalled.
    The HushMat really made a difference on how the door sounds now. I know it makes a difference on sound inside as well as its a weather temperature aid. Easy to install but be sure you put it where you want because it STICKS!!! No, I didn't boo boo. Just want you to know.
    My total investment so far is $420.00. I got the speakers for $249.00 which is $150.00 less than Crutchfield. I've seen them on the web from $199 to $399.00.
    TheManSpider and timbobzimbob like this.
  5. Mar 11, 2014 at 6:42 PM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Edited above post and document.
  6. Mar 23, 2014 at 3:39 AM
    deadbird8
    deadbird8 Well-Known Member
    Dallas, TX
    14 4x4
    Thanks for documenting your mods, this really helps. Seems I am a couple of months behind you.
    On the video you posted, how much do you think the Hushmat figured in the equation? I used HM Ultra on all my doors and it made a huge difference wrt road noise and vibration with the stock speakers. I haven't decided on my speaker upgrade yet, but appreciate the time you spent putting this together.
  7. Mar 23, 2014 at 7:15 AM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    To be honest, I don't know as I did the HushMat during the install. However, I do believe I'd still get better sound without it. As of now, the speakers sound good, but I'm going to make them sound great next month with the powered sub/amp. I'm going to install the Focal iBus2.1 just to keep all the same. I also was told the 2.1 doesn't need a LOC which is fantastic. My plan is to install it under the driver seat or at least the passenger seat.
    The doors sound so much better right now and I'm going to put the HushMat in the rear AC doors as well. Those things sound like an empty beer can. I did notice a quieter driving experience as well.
    I'm also going to replace the roof speakers and/or add rear AC door speakers to get a fuller sound. That may be a future project but I have nothing but time (retired). :) I have a few other mods I'm going to install (if you want to call them mods by forum standards).
    TRDSport10 likes this.
  8. Mar 23, 2014 at 7:34 AM
    jfwalsh
    jfwalsh Well-Known Member
    southern california
    2014 Spruce Mica 4wd DCLB TRD Sport
    TRD Exhaust, Front Skid, Running Boards (black)
    Good info... Subbed... Thanks!
  9. Mar 26, 2014 at 7:51 AM
    tony2018
    tony2018 Well-Known Member
    Roof speakers!?!?! What the hell kind of tacoma did you buy?
  10. Mar 26, 2014 at 8:24 AM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    2014 ACOR they all have six speakers. Two in the doors and two in the roof above the headliner. I must admit, the upper roof ones suck big time. On my PreRunner '09 I had the JBL and they sounded great. Now, it'll be me fine tuning my system. I may leave them in and mate them with new rears in the AC doors if I do that mod.
    Norton and TRDSport10 like this.
  11. Mar 26, 2014 at 9:02 AM
    looking4vr
    looking4vr Well-Known Member
    Brad
    Lusby, MD
    17 DCSB TRD OffRoad 6MT
    Bone Stock, for now
    That was very, very well written tutorial. Kudos to you sir, and good work!
  12. Nov 5, 2014 at 5:42 AM
    nxrunner
    nxrunner Well-Known Member
    Nick
    Lafayette La.
    2015 Tacoma Double Cab 6 Speed
    Those focal components look amazing. Same set im going with. Do you plan on putting an amp to them?
  13. Nov 7, 2014 at 11:24 AM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Yes, installed a Clarion XC1410 mini amp and placed it under the front seat. Perfect, out of the way and does plenty of uuuummmmpppphhhh!
    I have a few posts here: I have a detailed .pdf found here http://www.tacomaworld.com/forum/aud...b-options.html see post #4, and I would use this wire http://www.sonicelectronix.com/item_...y-Scosche.html to run your amp to/from the stock HU. Believe me, I just did this and it's the only way to fly. My install is here http://www.tacomaworld.com/forum/aud...-speakers.html post #14
    Base Camp likes this.
  14. Nov 8, 2014 at 11:23 PM
    Tatonka777
    Tatonka777 Active Member
    Marty
    Washington State
    '21 TRD Sport ordered
    Are you using the stock HU? How does it sound with the upgraded speakers and amp? I have an ALPINE KTP-445U power pack that I hooked up to the stock speakers and promptly removed until I can put in better speakers. The stock speakers just couldn't handle it...no surprise. I already have some Focal 6x9's for the front and just need to get some 6 1/2 or 6 3/4 for the rear doors plus some tweets for the fronts.
  15. Nov 9, 2014 at 9:40 AM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Yes, using the stock HU. Sound...GREAT with the Focal's and Clarion amp. You should have the same results with the Alpine unit. I have mine set to the higher frequency on the Clarion and it sound real good at a lower volume but doesn't distort at higher volume. The combo turned out better than I expected without dumping a lot of $$ into a system. I have plenty of clean sound. It'll blow me out of the cab if I needed to. I never tried the setup with the stock speakers so I can't comment on that sound. I did notice the Focal's with the stock HU sounded o.k. but after the amp was installed they sounded fantastic. I don't think you'll be disappointed.
  16. Dec 30, 2014 at 1:44 PM
    SilverComa
    SilverComa Active Member
    Austin, TX
    2012 Silver Tacoma Pre
    Does your HU have Bluetooth?
    I'm interested in doing pretty much exactly what you've done here, but my install guy told me I would have noticeable hiss due to the bluetooth microphone in my unit.
    Thoughts?
  17. Dec 31, 2014 at 6:26 AM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Yes I have Bluetooth and use it for my phone/text calls mostly. I haven't streamed music from my phone because I use the USB port if I want it. Mostly use my iPod Classic through the USB or Satellite for music. Either way, I don't have any hiss or feedback with either setup.
  18. Dec 31, 2014 at 12:38 PM
    SilverComa
    Austin, TX
    OK cool, it's probably nothing too noticeable anyway. He's probably just being precautious for those customers who nitpick things most people wouldn't notice.
    thanks man!
  19. Dec 31, 2014 at 1:48 PM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Took the truck out today and did a Bluetooth music sample from my phone. Worked like a charm. No hiss and clear as the radio or iPod. The iPod and Satellite are much better than the Bluetooth phone, but at least it works without a hiss. Hope this helps.
  20. Jan 1, 2015 at 12:29 PM
    SilverComa
    Austin, TX
    When you installed that Clarion mini amp did you use an LOC, a DSP, or just tap into the stock wires and use the high level inputs on the device?
