2016 OVTune Tacoma 3.5L Manual Transmission / Engine ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 18, 2017.
Thread Status:
Not open for further replies.
  1. Feb 26, 2019 at 6:37 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    If there is still Atkinson timing on the FO tune, but the window is so small anyway, then what was changed to create the FO maps? Trying to understand the difference, sorry.
    Interested in following your progress on the ACIS testing. Thanks for the hard work Mat :thumbsup:
    iexc likes this.
  2. Feb 26, 2019 at 7:08 PM
    Shellshock
    Iowa
    RedBeard1, iexc and mZiggy[QUOTED] like this.
  3. Feb 27, 2019 at 7:55 AM
    su.b.rat
    su.b.rat broken truck
    i for sure hope it's what we think it is. this is all i ever wanted from this motor after i got the picture of the 3500rpm surge. if it can surge at 3500, can it surge from down low and throughout the range? let's find out. i swear i've actually been dreaming about this since before OV even showed up here. i'll never even look at another Atkinson, numbly tuned, or buzzy motor ever again after this.
    iexc, mZiggy, 2001 4x4 and 1 other person like this.
  4. Feb 27, 2019 at 7:57 AM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Speaking of "buzzy", as others have mentioned, with this new FOB tune the engine just sounds happier. Even up to the new redline it sounds happy. Stock, anywhere near redline sounded like it was screaming for help.
    Dogg23, iexc, nxcess and 1 other person like this.
  5. Feb 27, 2019 at 8:00 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There is definitely a change in the sound of the motor. With all the work and all that has been found in the stock tunes, I do feel that OVT is better for the motor and longevity.
    iexc likes this.
  6. Feb 27, 2019 at 8:01 AM
    Shellshock
    Iowa
    I second that. it definitely feels different and sounds happier
  7. Feb 27, 2019 at 8:32 AM
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    Tune for ACIS off. Repeat with on. Compare Dyno graphs. Merge tunes with crossover at torque crossover between the two. Done.
    Tharris242 likes this.
  8. Feb 27, 2019 at 8:36 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Pretty much how it will be tested. We have a truck on the dyno this saturday
    2001 4x4 and lapoltba like this.
  9. Feb 27, 2019 at 9:03 AM
    Double Phister
    Sacramento, CA
    I don't know if it's RPM only. If load is a factor then you'll need to dyno each tune at partial loads as well. Bringing back my gen 1 Hondata days. :sniff:
  10. Feb 27, 2019 at 10:25 AM
    tacogravy
    tacogravy Well-Known Member
    Gravy
    Mantua, Ohio
    17 TRD OR 4x4 Quicksand 6MT
    TRD Pro Grill, TRD Sport Hood, BAMF Sliders, Bilstein 5100's F&B, BF Goodrich KO2 265/75R16, Old Man Emu 887 Front, Head Strong 3 Leaf AAL Rear (Overload Leaf Left In), OVTuned, De-Badged. Accumulator Delete Mod.
    Didn't think of that! Lol
    Can I download with flashmanager and then flash like I normally would (dongle user)?
  11. Feb 27, 2019 at 10:31 AM
    Shellshock
    Iowa
    You'll need tech stream. You can find all the information you need here
    https://www.tacomaworld.com/threads/software-update-for-the-manual.562550/
    If you already have all the tuning software installed, you already have the drivers installed so can skip all those steps and just choose the tactrix adapter.
    Its pretty simple
    tonered and iexc like this.
  12. Feb 27, 2019 at 10:34 AM
    tacogravy
    Gravy
    Mantua, Ohio
    Cool, thank you.
  13. Feb 27, 2019 at 3:04 PM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    So I got the cable in the mail today. Am I ready to go? just identify my ecu and get going? or do I still need to email ovtune and wait?
  14. Feb 27, 2019 at 3:05 PM
    OVTune
    OVTune
    if you did your registration you are good to go, follow flash manager instructions, SKIP registration part
    Wixo[QUOTED] likes this.
  15. Feb 27, 2019 at 3:09 PM
    Wixo
    Hank
    Tint, LED interior
    I did the computer registration, not truck. I just need to id the ecu and flash away then huh? Awesome!
  16. Feb 27, 2019 at 3:11 PM
    OVTune
    OVTune
    Check ID, download tunes, have fun.
    if you get the issue with P5Flash closing automatically / crashing.. do the "install OVTUNE cable drivers" from flash manager menu
  17. Feb 27, 2019 at 3:13 PM
    Wixo
    Hank
    Tint, LED interior
    Awesome bro, thanks!
  18. Feb 27, 2019 at 6:08 PM
    tacogravy
    Gravy
    Mantua, Ohio
    Well I downloaded and installed. Can't get it to take the text code nor do I see where the tactrix adapter is a choice anywhere. To bad there isn't a way to do it using the OV Tune software. Thanks anyway, I'm sure I'm doing something wrong. Especially if it's that simple!
  19. Feb 27, 2019 at 6:19 PM
    Greg19sport
    Greg19sport Well-Known Member
    Greg
    2019 MGM TRDSport 6mt
    ?Hi guys, quick question, I downloaded and flashed the 93fob tune for 04B41-MT. Does this tune have a 6900rpm limit?, I tried it and hit fuel cutoff at 6250. thanks!
  20. Feb 27, 2019 at 6:31 PM
    Shellshock
    Iowa
    Once you get TS to open, that’s when you can go in and select the tactrix interface
    I’d double check you haven’t missed a step in the instructions, lots of people have followed it without issue
    tacogravy[QUOTED] likes this.
Thread Status:
